dial-peer matching
WorldVentures
I cannot figure out dial-peer matching.  I'm trying to point a phone number at a new place.  Unfortunately, the wildcard match for all of our numbers keeps matching.  I don't understand why.  I thought the longest match wins.
dial-peer voice 2001 voip
tone ringback alert-no-PI
preference 5
destination-pattern 432555....
progress_ind setup enable 3
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target ipv4:10.10.0.10
dtmf-relay rtp-nte
ip qos dscp cs4 signaling
no vad
dial-peer voice 2007 voip
preference 1
destination-pattern 4325551212
voice-class codec 1
session target ipv4:10.29.1.41
dtmf-relay rtp-nte
no vad
2001 keeps matching.  What gives?
Brandon Buffin
What is the inbound dial peer that is matching? What called number is the router seeing? You can run "debug voip dialpeer" to see these.
Brandon
