I found a problem with matching dial-peers in E.164 format with + sign. There is a pots dial-peer with destination-pattern +370........$. When gateway receives a number +37011111111 from SIP this dial-peer doesn't matches but in show dialplan number +37011111111 I see this peer. I tried to replace destination pattern to ^370........$ and after that the dial-peer match succeeded (number still comes with + sign from SIP). Similar dial-peers works on AS5350/5400 but not working on 2811 with 12.4(23) IOS. Is this a bug and I have to configure workaround or change IOS or I'm doing something wrong?
Maxim
