01-16-2017 09:33 PM - edited 03-17-2019 09:12 AM
Hi Team,
We are unable to make calls to 902XXXXXXX landline numbers since I get immediate disconnect tone after dialing 902 .
As I checked there is a dial peer matching this pattern :
dial-peer voice 902 pots
description LANDLINE CALLS
preference 1
destination-pattern 90[234679].......
port 0/0/0:15
prefix 0
Can anyone help in isolating this problem ? We have UAE number pattern .
01-16-2017 09:57 PM
can you attach a file with below debugs and calling and called number.
debug ISDN q931
debug voice ccapi inout
JB
01-17-2017 02:10 AM
Hi Jitender,
Regret for delayed reply .PFB logs . let me know if any other outputs needed.
009814: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=9026100514, Peer Info Type=DIALPEER_INFO_SPEECH
009815: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9026100514
009816: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=9026100514, Expanded String=9026100514, Calling Number=
Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
009817: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=902 Is Matched
009818: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=903 Is Matched
009819: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
009820: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=9026100514, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
009821: Jan 17 09:54:17.481: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=902
2: Dial-peer Tag=903
009831: Jan 17 09:56:47.581: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
009832: Jan 17 09:56:47.581: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
009833: Jan 17 09:56:47.581: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
009834: Jan 17 09:56:47.585: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
009835: Jan 17 09:56:47.585: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
009836: Jan 17 09:56:47.585: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
009837: Jan 17 09:56:47.585: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
009838: Jan 17 09:56:47.585: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
01-17-2017 02:36 AM
Looks like it dint capture the full debug. Can you do another test call and collect the same information
Also mention calling called number
JB
01-17-2017 09:55 PM
Hi, I have tried taking debug multiple times , but this call is not coming in logs .
Now the 902xxxxxxx is reachable from phone on-hook mode . If I take the receiver there is a disconnect tone after 902 . Also unable to send faxes to 902xxxxxxx numbers as it prompts busy always . should I log case with service provider for this ?
01-17-2017 10:17 PM
Can you attach the show run.
Also, can you attach a working (on hook mode) and non-working debug.
Also, is 043517215 the correct number being sent to the PSTN?
Please rate and mark if helpful
Adarsh Chauhan
01-18-2017 12:28 AM
01-18-2017 12:40 AM
Below is what i can see in log
024029: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpAssociateIncomingPeerCore:
Calling Number=045182222, Called Number=902444190, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
024030: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=300
024031: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
024032: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpAssociateIncomingPeerCore:
024033: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpAssociateIncomingPeerCore:
024034: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchSafModulePlugin:
024035: Jan 18 06:23:22.564: //-1/80EE039B6701/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x3E779674; count=1
024036: Jan 18 06:23:22.564: //-1/80EE039B6701/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x27947FC0
024037: Jan 18 06:23:22.564: //-1/80EE039B6701/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x3E779674; count=1
024038: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersCore:
Calling Number=, Called Number=902444190, Peer Info Type=DIALPEER_INFO_SPEECH
024039: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=902444190
024040: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
024041: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchSafModulePlugin:
dialstring=902444190, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
024042: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
024043: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersCore:
024044: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersCore:
024045: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersCore:
024046: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchSafModulePlugin:
024047: Jan 18 06:23:22.564: //-1/80EE039B6701/DPM/dpMatchPeersMoreArg:
Did you dial 902444190 or 9024444190, because it is not matching any dial-peer.
(Rate if it helps)
JB
01-18-2017 01:00 AM
01-18-2017 01:33 AM
can you attach Show run.
JB
01-18-2017 02:19 AM
Thank you all for supporting me .
Finally issue has been resolved . but cause was really funny . someone added one of our new location's RP partition to this location CSS , and its VG is not up . this didn't come in call trace till I try different number .
