IP Telephony and Phones
Labels
Dear Cisco Team and All, I am confused because each telephone line is working fine on single direct telephone.but i am installing 4-Four lines on VIC card  but unfortunately its not working,  so after that all line is not working...i am getting ring...
    I just implement CMC code to restrict users being making calls without enter the CMC code. But I faced problem that when the users prompted to enter the code or password, the code appears so anybody can see it. Does anybody know how to make that ...
We have Cisco Catalyst 6500 Series Switch with CMM Module and Supervisor Engine 32, infra team will replace the SUP 32 with new one 720 with new IOS will this affect the CMM function , i know the CMM is compatible with SUP 720 but what about new IOS ...
I have a number of Cisco 7906 handsets configured with Tel2 SIP provider. Everything works well 90% of the time but occasionally traffic seems to get blocked and we have to switch to using port 50600 instead of port 5060. I am using SEPXXXXXXXXXXXX.c...
Hi, Could someone please confirm if the Cisco 1921 supports VoIP? From what i can tell the Cisco 1921 router does not support VoIP, even with a VWIC3 card installed. This diagram (from  http://www.cisco.com/c/en/us/products/collateral/routers/2800-s...
Hi All, I have an analog gateway connect to analog line to call to other country. The pattern is: When user dial "123", user can hear tone (This is the tone connect to the gateway) Then user dial "2" mean connect to country A. Then user dial "567" f...
osw200051 by Level 1
  • 215 Views
  • 1 replies
