Dial-peer to remove leading 9
techguy
Level 4
Level 4
I just want to know that below rule would remove 9 from incoming number. Now i am using CUCM 7 with h323 gateway. Telco is sending last 4 digits and poiting to CTI route point.
Now at above scenario, whats the use? and where shall i call that profile ( Either inn dial-peer or in voice port)
voice translation-rule 1
rule 1 /^9/ //
voice translation-profile 1
translate called 1
8 Replies 8
islam.kamal
Level 10
Level 10
9 is used for outgoing call , but if your teleco send 9XXXX , please clarrify . Please use the below:-
rule 1 /^9\ (....\)/ /\1/
voice translation-profile DID
translate called 1
voice-port 0/1/0:23        /If you use T1 , and based on your ISDN connection and port/
translation-profile incoming   DID
Thank you
please rate all useful information
Telco is not sending 9 digit with last four digits. In this case whats the usage of above rule?
Hi Omerpal,
If telco is not sending the leading digit 9 along with the incoming called number then there is no use of that given rule.
As per my view it might be applied for the outgoing called numbers.
This if you get a call starts with 9XXX , then you can use the rule. If not , the rule will be useless. Can you please share with me more details about your request and i will help you.
Thank you
Actually, i have one issue that when i receive incoming call it comes without 9. And we cant dial this number by just viewing missed calls and press redial because we are using digit 9 for outgoing calls.
ohhhhhhhhh , so please find the below:-
Config t
rule 1 /^.*/ /9&/
or
rule4 /^....$/ /9&/
voice translation-profile INBOUND_PSTN
translate calling 1
voice-port X/X/X
translation-profile incoming INBOUND_PSTN
Thank you
you can also use the below link:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
Thank you
please rate all sueful information
i dont have isdn link there but fxo ports
