Dial Peer Voip Vs Pots
Jeremy Lizzotte
Ive been looking around in alot of treads and I would like to confirm this: We have Nexvortex as an ITSP and it is obviously voip so its been my understanding when we use CCA to setup the systems we do the dial peer xxxx voip. is this correct? we do not use PRI or t1, or POTS, we dont have FXO or anything, so we do nothing with dial peer xxxx pots, is that correct? obviiusly there are incoming and outgoing calls to POTS lines but we use sip as a provider.
Chris Deren
Correct, any IP connection will need to be configured with voip dial-peer.
HTH, please rate all usuful posts!
Chris
