dial peers and translation rules
SBjohnk
I'm trying to understand out how to route calls using dial peers and translation rules and I'm just going in circles and getting a headache.
I need to match incoming calls from my SIP provider, They send 11 digits to me.
I need to route outgoing calls from my phones and pots ports to my sip provider.
I can't have my users dial a prefix to get out, if they want to call 5203825968 they should be able to dial it as 3825968, 5203825968 or 15203825968 and it gets rewritten to 15203825968 to send to the carrier.
voice translation-rule 1
 rule 1 /^1/ //
voice translation-rule 2
 rule 1 /5204792894/ /101/
 rule 2 /5204792896/ /100/
 rule 3 /5202827081/ /201/
voice translation-rule 10
 rule 1 /100/ /5204792896/
 rule 2 /101/ /5204792894/
 rule 3 /201/ /5202827081/
voice translation-rule 20
 rule 1 /\([2-9]......$\)/ /520\1/
voice translation-profile CONVERT_TO_XTN
 translate called 2
voice translation-profile EXTENSION_TO_CID
 translate calling 10
 translate called 20
voice translation-profile STRIP-1
 translate called 1
voice class sip-profiles 1
 request ANY sip-header Diversion remove
 request INVITE sip-header Diversion remove
dial-peer voice 1 voip
 description Incoming 11 digit calls from carrier
 translation-profile outgoing STRIP-1
 preference 1
 destination-pattern 1..........
 translate-outgoing called 101
 session protocol sipv2
 session target ipv4:192.168.100.1
 incoming called-number 1..........
 voice-class sip profiles 1
dial-peer voice 2 voip
 description Redirected 10 digit incoming calls
 translation-profile incoming CONVERT_TO_XTN
 preference 2
 destination-pattern ..........
 session target sip-server
 incoming called-number ..........
dial-peer voice 7 voip
 description 7 Digit Dial
 translation-profile outgoing EXTENSION_TO_CID
 destination-pattern [2-9]......
 codec g711ulaw
24 Replies 24
Based on the running config you shared, I suggest you apply the below changes and test again. In case the issue still persists, please share the output of "debug ccsip messages" and "debug voice ccapi inout". BTW, this time I used different dial peer tags and xlation rule tags so the change won't overwrite your existing configs. This makes it easier to revert the changes if needed.
voice service voip
sip
sip-profiles 1
sip-profiles 1 inbound
voice translation-rule 30
rule 1 /15204792894/ /101/
rule 2 /15204792896/ /100/
rule 3 /15202827081/ /201/
***Note: Make sure the prefix 1 is there. This is a new xlation rule with the tag 30 so it won't overwrite the exiting rule 2.
voice translation-profile DID_To_Ext
translate called 30
voice class uri 1 sip
host 1.1.1.1
*** Very IMPORTANT Note: Replace 1.1.1.1 with with host address in the via header of the incoming invites from the carrier
dial-peer voice 30 voip
description Incoming Calls from the Carrier
incoming uri via 1
translation-profile incoming DID_To_Ext
voice-class sip profiles 1 inbound
codec g711ulaw
no vad
*** This dial peer accepts all calls from the carrier based on the host address in the via header of the incoming invite.
dial-peer voice 40 voip
description Outgoing dial-peer to the Carrier
destination-pattern .T
codec g711ulaw
no vad
*** This dial peer sends call to the carrier. Calling numbers get xlated to 10 digits and called numbers to 11 digits. 9911 gets xlated to just 911 before routing to the carrier. If users dial 911 the digits route without any xlation.
Important Note: Before you begin testing, shutdown dial peers below and disable dial-peer inbound selection command.
shutdown
shutdown
shutdown
no dial-peer inbound selection sip-trunk
After you are done testing and the new configs do not work, you can revert the changes buy shutting down dial peers 30 and 40, and unshut dial peers 1 and 2, then re-enable dial-peer inbound selection command.
VOIP(config-register-global)#sip
VOIP(config-sip-ua)#sip-profiles 1
% Invalid input detected at '^' marker.
VOIP(config-sip-ua)#sip-profiles 1 inbound
VOIP(config-dial-peer)#voice-class sip profiles 1 inbound
Logs are attached below, I've given up on obfuscating IP's and other information.
VOIP#debug voice ccapi inout
voip ccapi inout debugging is on
VOIP#
Feb 6 11:40:26.655: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:15202827081@192.168.100.1:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bKnri4l00008u2m98je3e0.1
Contact: <sip:173.244.45.246:5065;transport=udp>
CSeq: 12017 INVITE
Content-Length: 364
Content-Type: application/sdp
Call-ID: SDnc71301-57991cff97dac8d8c6ab4dff32a5e431-ao1agu3010
From: "Simply Bits" <sip:15205457285@173.244.45.246:5065>;tag=SDnc71301-S06T20230206184026U13894846_DID15202827081
To: sip:15202827081@64.119.40.170:64013;transport=udp
Diversion: sip:15202827081@null;reason=unconditional
Max-Forwards: 65
Priority: normal
Session-Expires: 1800;refresher=uac
Allow: INVITE
Allow: ACK
Allow: PRACK
Allow: CANCEL
Allow: BYE
Allow: REFER
Allow: NOTIFY
Allow: OPTIONS
Allow: MESSAGE
Allow: INFO
Allow: REGISTER
Allow: SUBSCRIBE
Supported: timer
v=0
o=CPE2_Media_Cluster 711554334 711554335 IN IP4 173.244.45.248
s=b84a1c25-8ec1-4d4b-96ca-fe14d8195a4d/3ad46762-5da1-4287-949b-aadaa28539e5
c=IN IP4 173.244.45.248
t=0 0
m=audio 28628 RTP/AVP 0 18 101 13
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
Feb 6 11:40:26.667: //-1/8EB09200801C/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=15205457285
----- ccCallInfo IE subfields -----
cisco-ani=15205457285
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=15202827081
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=15202827081
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=15 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Feb 6 11:40:26.671: //-1/8EB09200801C/CCAPI/cc_api_call_setup_ind_common:
Interface=0x67F2AA7C, Call Info(
Calling Number=15205457285,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=15202827081(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=40, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=122
Feb 6 11:40:26.671: //-1/8EB09200801C/CCAPI/ccCheckClipClir:
In: Calling Number=15205457285(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=15205457285(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb 6 11:40:26.671: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 6 11:40:26.671: :cc_get_feature_vsa malloc success
Feb 6 11:40:26.671: cc_get_feature_vsa count is 1
Feb 6 11:40:26.671: :FEATURE_VSA attributes are: feature_name:0,feature_time:1765153088,feature_id:5
Feb 6 11:40:26.671: //122/8EB09200801C/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=15205457285(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=15202827081(TON=Unknown, NPI=Unknown))
Feb 6 11:40:26.675: //122/8EB09200801C/CCAPI/cc_process_call_setup_ind:
Event=0x685C1A20
Feb 6 11:40:26.675: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 15202827081
Feb 6 11:40:26.679: //122/8EB09200801C/CCAPI/ccCallSetContext:
Context=0x6947A3F8
Feb 6 11:40:26.679: //122/8EB09200801C/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 122 with tag 40 to app "_ManagedAppProcess_Default"
Feb 6 11:40:26.679: //122/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 06 Feb 2023 18:40:26 GMT
CSeq: 12017 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Feb 6 11:40:26.683: //122/8EB09200801C/CCAPI/ccCallProceeding:
Feb 6 11:40:26.687: //122/8EB09200801C/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=40, Params=0x6947B908, Progress Indication=NULL(0)
Feb 6 11:40:26.687: //122/8EB09200801C/CCAPI/ccCheckClipClir:
Destination Pattern=.T, Called Number=152015202827081, Digit Strip=FALSE
Called Number=152015202827081(TON=Unknown, NPI=Unknown),
Redirect Number=15202827081, Display Info=Simply Bits
Account Number=15205457285, Final Destination Flag=TRUE,
Guid=8EB09200-A584-11ED-801C-D958B280208A, Outgoing Dial-peer=40
Feb 6 11:40:26.687: //122/8EB09200801C/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=152015202827081
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Feb 6 11:40:26.691: //122/8EB09200801C/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x67F2AA7C, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=15205457285,(Calling Name=Simply Bits)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=152015202827081(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=40, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb 6 11:40:26.691: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 6 11:40:26.691: :cc_get_feature_vsa malloc success
Feb 6 11:40:26.691: cc_get_feature_vsa count is 2
Feb 6 11:40:26.691: :FEATURE_VSA attributes are: feature_name:0,feature_time:1765152640,feature_id:6
Feb 6 11:40:26.695: //123/8EB09200801C/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Feb 6 11:40:26.695: //123/8EB09200801C/CCAPI/ccCallSetContext:
Context=0x6947B8B8
Feb 6 11:40:26.695: //122/8EB09200801C/CCAPI/ccSaveDialpeerTag:
Feb 6 11:40:26.699: //123/8EB09200801C/CCAPI/cc_api_call_proceeding:
Interface=0x67F2AA7C, Progress Indication=NULL(0)
Feb 6 11:40:26.707: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:152015202827081@siptrunk.p2.alianza.com:5065 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.1:5060;branch=z9hG4bK7826E0
From: "Simply Bits" <sip:15205457285@siptrunk.p2.alianza.com>;tag=3A4320-218D
To: <sip:152015202827081@siptrunk.p2.alianza.com>
Call-ID: 8EB6ACC1-A58411ED-8022D958-B280208A@192.168.100.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2393936384-2776895981-2149374296-2994741386
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1675708826
Contact: <sip:15205457285@192.168.100.1:5060>
Expires: 180
Max-Forwards: 64
Content-Disposition: session;handling=required
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 5708 6053 IN IP4 192.168.100.1
s=SIP Call
c=IN IP4 192.168.100.1
t=0 0
m=audio 17876 RTP/AVP 0
a=ptime:20
Feb 6 11:40:26.819: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.100.1:5060;received=64.119.40.170;branch=z9hG4bK7826E0;rport=64013
CSeq: 101 INVITE
Content-Length: 0
Feb 6 11:40:26.827: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <sip:152015202827081@siptrunk.p2.alianza.com>;tag=SDiavoa99-lignup-4063-63e1499a
CSeq: 101 INVITE
Content-Length: 0
WWW-Authenticate: Digest nonce="MDAxNjc1NzA4ODI2OjUwNDczOTEwOGJVN0VqNkVrQyt1eFdyOXJEWUV6SlE9PQA=",realm="Alianza"
Feb 6 11:40:26.835: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:152015202827081@siptrunk.p2.alianza.com:5065 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 6 11:40:26.839: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.100.1:5060;branch=z9hG4bK791D03
Min-SE: 1800
CSeq: 102 INVITE
Expires: 180
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:152015202827081@siptrunk.p2.alianza.com:5065",response="126d0cb5b0e0e7993c6e1d0696c08456",nonce="MDAxNjc1NzA4ODI2OjUwNDczOTEwOGJVN0VqNkVrQyt1eFdyOXJEWUV6SlE9PQA=",algorithm=md5
Max-Forwards: 64
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb 6 11:40:27.335: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Feb 2023 18:40:27 GMT
Min-SE: 1800
CSeq: 102 INVITE
Timestamp: 1675708827
Expires: 180
Max-Forwards: 64
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb 6 11:40:27.495: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.100.1:5060;received=64.119.40.170;branch=z9hG4bK791D03;rport=64013
CSeq: 102 INVITE
Content-Length: 0
Feb 6 11:40:27.539: //123/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
To: <sip:152015202827081@siptrunk.p2.alianza.com>;tag=SDiavoa99-lignup-4a59-63e1499b
CSeq: 102 INVITE
Content-Length: 0
Feb 6 11:40:27.539: //123/8EB09200801C/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x67F2AA7C, Call Id=123
Feb 6 11:40:27.543: //123/8EB09200801C/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Feb 6 11:40:27.543: //122/8EB09200801C/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Feb 6 11:40:27.543: //123/8EB09200801C/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=123
Feb 6 11:40:27.543: //123/8EB09200801C/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Feb 6 11:40:27.547: //123/8EB09200801C/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x67F2AA7C, Tag=0x0, Call Id=123,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Feb 6 11:40:27.547: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 6 11:40:27.547: :cc_free_feature_vsa freeing 69361778
Feb 6 11:40:27.547: vsacount in free is 1
Feb 6 11:40:27.551: //122/8EB09200801C/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb 6 11:40:27.555: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
VOIP#
Feb 6 11:40:27.555: //122/8EB09200801C/SIP/Msg/ccsipDisplayMsg:
Sent:
To: sip:15202827081@64.119.40.170:64013;transport=udp;tag=3A4670-5B4
CSeq: 12017 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Feb 6 11:40:27.692: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:15202827081@192.168.100.1:5060 SIP/2.0
CSeq: 12017 ACK
To: <sip:15202827081@64.119.40.170:64013>;transport=udp;tag=3A4670-5B4
Max-Forwards: 65
Content-Length: 0
Feb 6 11:40:27.696: //122/8EB09200801C/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x67F2AA7C, Tag=0x0, Call Id=122,
Feb 6 11:40:27.696: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 6 11:40:27.700: :cc_free_feature_vsa freeing 69361938
Feb 6 11:40:27.700: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 6 11:40:27.700: vsacount in free is 0
VOIP#
Feb 6 11:41:35.203: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:siptrunk.p2.alianza.com:5065 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.1:5060;branch=z9hG4bK7A17A7
From: <sip:101@siptrunk.p2.alianza.com>;tag=3B4E98-B04
To: <sip:101@siptrunk.p2.alianza.com>
Date: Mon, 06 Feb 2023 18:41:35 GMT
Call-ID: A5F570EE-14EE11CC-8004D958-B280208A
Max-Forwards: 70
Timestamp: 1675708895
CSeq: 34 REGISTER
Contact: <sip:101@192.168.100.1:5060>
Expires: 3600
Supported: path
Content-Length: 0
Feb 6 11:41:35.295: //124/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.1:5060;received=64.119.40.170;branch=z9hG4bK7A17A7;rport=64013
To: <sip:101@siptrunk.p2.alianza.com>;tag=aprqvui9h28e4bo67-rr4gjs0000042
CSeq: 34 REGISTER
Contact: <sip:101@192.168.100.1:5060>;expires=181
Content-Length: 0
VOIP#
Feb 6 11:41:45.287: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.100.1:5060;branch=z9hG4bK7B12E4
From: <sip:100@siptrunk.p2.alianza.com>;tag=3B75F8-1788
To: <sip:100@siptrunk.p2.alianza.com>
Date: Mon, 06 Feb 2023 18:41:45 GMT
Call-ID: A5F4D4C6-14EE11CC-8003D958-B280208A
Max-Forwards: 70
Timestamp: 1675708905
CSeq: 45 REGISTER
Contact: <sip:100@192.168.100.1:5060>
Expires: 3600
Supported: path
Content-Length: 0
Feb 6 11:41:45.295: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.100.1:5060;branch=z9hG4bK7CA7E
From: <sip:ciscoiad1@siptrunk.p2.alianza.com>;tag=3B75FC-79
To: <sip:ciscoiad1@siptrunk.p2.alianza.com>
Call-ID: A5D5B40B-14EE11CC-8002D958-B280208A
Max-Forwards: 70
CSeq: 45 REGISTER
Contact: <sip:ciscoiad1@192.168.100.1:5060>
Expires: 3600
Supported: path
Content-Length: 0
Feb 6 11:41:45.411: //126/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.1:5060;received=64.119.40.170;branch=z9hG4bK7CA7E;rport=64013
To: <sip:ciscoiad1@siptrunk.p2.alianza.com>;tag=aprqvui9h28e4bo67-79k6gl10000q2
CSeq: 45 REGISTER
Contact: <sip:ciscoiad1@192.168.100.1:5060>;expires=121
Content-Length: 0
Feb 6 11:41:45.411: //125/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.1:5060;received=64.119.40.170;branch=z9hG4bK7B12E4;rport=64013
To: <sip:100@siptrunk.p2.alianza.com>;tag=aprqvui9h28e4bo67-78us4v20000q2
CSeq: 45 REGISTER
Contact: <sip:100@192.168.100.1:5060>;expires=121
Content-Length: 0
Sorry.  I made a typing error in my previous post but I fixed now. The inbound sip profile should be applied as below.
voice service voip
sip
sip-profiles 1
Also, from the logs you shared, I see that the incoming call matches dial peer 40 instead of dial peer 30. Please make sure
you add the IP address of the carrier under the voice class uri 1 as below.
host 173.244.45.246
Not sure why you can't add the inbound sip profile under the dial peer. It may be not be supported on your router's version of IOS but I guess that is ok as far as you can enable it globally using the config I shared near the top of this post.
Please share your running config again after applying all the changes.
Doesn't look like my IOS supports a inbound profile. How about matching on a carrier-id? I've found references to that but can't find a good example, I've tried adding a voice source-group where I define a carrier-id.
VOIP(config)#voice service voip
VOIP(conf-voi-serv)#sip
VOIP(conf-serv-sip)#sip-profiles 1
VOIP(conf-serv-sip)#sip-profiles 1 inbound
VOIP(conf-serv-sip)#voice class uri 1 sip
VOIP(config-voice-uri-class)#host 173.244.45.246
host 173.244.45.246 already present
Config:
! Last configuration change at 12:16:31 MST Mon Feb 6 2023 by johnk
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname VOIP
boot-start-marker
boot system slot0:c2430-ik9o3s-mz.151-4.M10.bin
boot-end-marker
card type t1 1
logging buffered 4096
enable secret 5 $1$zwo8$nA2odUimH/BICmKTnI9rl.
enable password 7 121C0B16100709
aaa new-model
aaa session-id common
clock timezone MST -7 0
clock summer-time MDT recurring
network-clock-participate T1 1/0
network-clock-select 1 T1 1/0
ip source-route
no ip routing
no ip cef
ip domain name simplybits.net
ip name-server 8.8.8.8
no ip dhcp use vrf connected
ip dhcp pool PHONES
 network 192.168.100.0 255.255.255.0
 default-router 192.168.100.1
 option 150 ip 192.168.100.1
 dns-server 8.8.8.8
no ipv6 cef
voice hunt user-busy
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
 no ip address trusted authenticate
 allow-connections sip to sip
 redirect ip2ip
 sip
  bind control source-interface FastEthernet0/1
  bind media source-interface FastEthernet0/1
  registrar server expires max 1200 min 300
  sip-profiles 1
  no call service stop
voice class uri ALIANZA sip
 host 173.254.188.208
 host 173.244.45.246
voice class sip-hdr-passthrulist 1
voice class sip-copylist 1
voice register global
 mode cme
 source-address 192.168.100.1 port 5060
 max-dn 10
 max-pool 8
 load 7965 SCCP45.9-4-2SR3-1S
 authenticate register
 authenticate realm simplybits.net
 dialplan-pattern 1 1.. extension-length 3
 tftp-path slot0:
 file text
 create profile sync 0005026636280538
 ntp-server 17.253.16.125 mode unicast
voice source-group Alianza
 access-list 99
 carrier-id source Alianza
 rule 1 /^1/ //
 rule 1 /\([2-9]......$\)/ /1520\1/
 rule 2 /\([2-9]..[2-9]......$\)/ /1\1/
 rule 3 /9911/ /911/
 translate called 2
 translate called 30
 translate called 20
 translate called 1
voice-card 0
archive
 log config
  hidekeys
 path slot0:
 maximum 14
 write-memory
username johnk password 7 030752180500
username admin privilege 15 secret 5 $1$C4oN$vJsaf4xiVPK4CbEac31YR/
username itech privilege 15 secret 5 $1$T7UO$BzcKLoYxC.69TBSRQ.jqS.
controller T1 1/0
 channel-group 0 timeslots 1-24
ip ftp username ciscoftp
ip ftp password 7 0822455D0A49544541
ip ssh version 2
interface Loopback0
 no ip address
interface FastEthernet0/0
 ip address dhcp
 no ip route-cache
 duplex auto
 speed auto
 ip address 192.168.100.1 255.255.255.0
 no ip route-cache
 duplex auto
 speed auto
 ntp broadcast
interface Serial1/0:0
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path slot0:cme-gui-8.6.0
logging source-interface Loopback0
access-list 99 permit 198.204.63.0 0.0.0.255
access-list 99 permit 208.93.8.0 0.0.0.255
access-list 99 permit 173.254.188.0 0.0.0.255
access-list 99 permit 173.244.45.0 0.0.0.255
tftp-server flash:apps45.9-4-2ES26.sbn
tftp-server flash:cnu45.9-4-2ES26.sbn
tftp-server flash:cvm45sccp.9-4-2ES26.sbn
tftp-server flash:dsp45.9-4-2ES26.sbn
tftp-server flash:jar45sccp.9-4-2ES26.sbn
tftp-server flash:SCCP45.9-4-2SR3-1S.loads
tftp-server flash:term65.default.loads
tftp-server flash:B016-1-0-4-2.SBN
tftp-server flash:music-on-hold.au
tftp-server flash:term45.default.loads
tftp-server flash:SCCP45.9-2-1S.loads
tftp-server flash:jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp45.9-2-1TH1-13.sbn
tftp-server flash:cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:cnu45.9-2-1TH1-13.sbn
tftp-server flash:apps45.9-2-1TH1-13.sbn
control-plane
voice-port 2/0
 no supervisory disconnect lcfo
 no battery-reversal
voice-port 2/1
 no battery-reversal
 caller-id enable
voice-port 2/2
 no battery-reversal
voice-port 2/3
 no battery-reversal
voice-port 2/4
 no battery-reversal
voice-port 2/5
 no battery-reversal
voice-port 2/6
 no battery-reversal
voice-port 2/7
 no battery-reversal
voice-port 2/8
 no battery-reversal
voice-port 2/9
 no battery-reversal
voice-port 2/10
 no battery-reversal
voice-port 2/11
 no battery-reversal
voice-port 2/12
 no battery-reversal
voice-port 2/13
 no battery-reversal
voice-port 2/14
 no battery-reversal
voice-port 2/15
 no battery-reversal
mgcp profile default
dial-peer voice 200 pots
 destination-pattern 200
 port 2/0
 no sip-register
dial-peer voice 201 pots
 destination-pattern 201
 port 2/1
 no sip-register
dial-peer voice 202 pots
 destination-pattern 202
 port 2/2
 no sip-register
dial-peer voice 203 pots
 destination-pattern 203
 port 2/3
 no sip-register
dial-peer voice 204 pots
 destination-pattern 204
 port 2/4
 no sip-register
dial-peer voice 205 pots
 destination-pattern 205
 port 2/5
 no sip-register
 description Incoming 11 digit calls from Alianza
 preference 1
 shutdown
 modem passthrough nse codec g711ulaw
 incoming uri via 1
 incoming uri from ALIANZA
 dtmf-relay rtp-nte digit-drop h245-alphanumeric
 fax-relay ecm disable
 fax-relay sg3-to-g3
 fax nsf 000000
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
 no vad
 preference 2
 shutdown
 shutdown
 codec g711ulaw
 incoming uri via 1
 codec g711ulaw
 no vad
 codec g711ulaw
 no vad
gateway
 timer receive-rtp 1200
sip-ua
 credentials username ciscoiad1 password 7 15100F5855737A252A61 realm all
 credentials username ciscoiad1 password 7 15100F5855737A252A61 realm siptrunk.p2.alianza.com
 authentication username ciscoiad1 password 7 04590F525E781D4F0B4B
 no remote-party-id
 registrar dns:siptrunk.p2.alianza.com:5065 expires 3600
 sip-server dns:siptrunk.p2.alianza.com:5065
telephony-service
 no auto-reg-ephone
 max-ephones 30
 max-dn 150
 ip source-address 10.169.197.102 port 2000
 timeouts interdigit 2
 cnf-file perphone
 max-conferences 4 gain -6
 call-park system application
 call-forward pattern .T
 moh flash:music-on-hold.au
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
ephone-dn  10
 number 100
 label x100
 allow watch
ephone-dn  11
 number 101
 label x101
 allow watch
ephone  1
 device-security-mode none
 mac-address C025.5C43.0CDD
 type 7965
 button  1:10
ephone  2
 mac-address 2893.FE13.4C0A
 type 7965
 button  1:11
line con 0
line aux 0
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 transport input all
ntp master
ntp peer time.apple.com
end
Does the outbound calls work? I doubt it because your router is behind NAT and you don't have any outbound sip profiles in your configs. You need an outbound sip profile to xlate the private IP of the router to its public IP. Please add the sip profile 40 and apply it to dial peer 40 as below.
voice class sip-profiles 40
request ANY sip-header From modify "192.168.100.1" "64.119.40.170"
request ANY sip-header Via modify "192.168.100.1" "64.119.40.170"
request ANY sip-header Remote-Party-ID modify "192.168.100.1" "64.119.40.170"
request ANY sip-header Contact modify "192.168.100.1" "64.119.40.170"
response ANY sip-header Contact modify "192.168.100.1" "64.119.40.170"
response ANY sip-header Remote-Party-ID modify "192.168.100.1" "64.119.40.170"
request ANY sdp-header Audio-Connection-Info modify "192.168.100.1" "64.119.40.170"
request ANY sdp-header Connection-Info modify "192.168.100.1" "64.119.40.170"
request ANY sdp-header Session-Owner modify "192.168.100.1" "64.119.40.170"
response ANY sdp-header Session-Owner modify "192.168.100.1" "64.119.40.170"
response ANY sdp-header Connection-Info modify "192.168.100.1" "64.119.40.170"
response ANY sdp-header Audio-Connection-Info modify "192.168.100.1" "64.119.40.170"
request ANY sip-header Call-Info modify "192.168.100.1" "64.119.40.170"
request ANY sip-header P-Asserted-Identity modify "192.168.100.1" "64.119.40.170"
voice-class sip profiles 40
For inbound calls:
I still see "dial-peer inbound selection sip-trunk" in your configs. I believe this command won't allow the inbound calls from the carrier to correctly match dial-peer 30. Please remove using "no dial-peer inbound selection sip-trunk" for now.
If the inbound calls still don't work then try this (just for testing).
no incoming uri via 1
incoming called-number 15202827081
If using this method, you should obviously test your inbound calls by dialing 15202827081.
Yeah, I didn't have working RTP earlier, but as this is only a test configuration in my lab I wasn't worried about that yet.
I just removed a bunch of the stuff I had been trying from my configuration to try and get it down to just what you want me to work with and here's what I have.
Incoming calls to 15202827081 are ringing through to my POTS port and can be answered.
Here's a log of that: -------------------------
Feb  6 15:54:38.547: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:15202827081@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bKohl2sn005g58folgj5b0.1
CSeq: 15584 INVITE
Content-Length: 366
Call-ID: SD456t201-edfc22c9c7cc284d1434598dba86160c-ao1a0u3050
From: "Simply Bits" <sip:15205457285@173.244.45.246:5065>;tag=SD456t201-S07T20230206225438U14385267_DID15202827081
To: sip:15202827081@64.119.40.170:60577;transport=udp
Max-Forwards: 65
Priority: normal
Allow: INVITE
Allow: ACK
Allow: PRACK
Allow: CANCEL
Allow: BYE
Allow: REFER
Allow: NOTIFY
Allow: OPTIONS
Allow: MESSAGE
Allow: INFO
Allow: REGISTER
Allow: SUBSCRIBE
Supported: timer
v=0
o=CPE2_Media_Cluster 1196888226 1196888227 IN IP4 173.244.45.188
s=95c2740f-55b9-4caa-9bc5-14bef6860e8a/e3cfb46e-5550-442c-89bf-62fda3165153
c=IN IP4 173.244.45.188
t=0 0
m=audio 21822 RTP/AVP 0 18 101 13
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
Feb  6 15:54:38.563: //-1/11872C9E805D/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=15202827081
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  6 15:54:38.567: //-1/11872C9E805D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x67F2B37C, Call Info(
   Incoming Dial-peer=30, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=76
Feb  6 15:54:38.567: //-1/11872C9E805D/CCAPI/ccCheckClipClir:
Feb  6 15:54:38.567: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 15:54:38.567: :cc_get_feature_vsa malloc success
Feb  6 15:54:38.567:  cc_get_feature_vsa count is 1
Feb  6 15:54:38.567: :FEATURE_VSA attributes are: feature_name:0,feature_time:1721144048,feature_id:27
Feb  6 15:54:38.567: //76/11872C9E805D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Feb  6 15:54:38.571: //76/11872C9E805D/CCAPI/cc_process_call_setup_ind:
   Event=0x685C2E18
Feb  6 15:54:38.571: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Feb  6 15:54:38.571: //76/11872C9E805D/CCAPI/ccCallSetContext:
   Context=0x69535430
   >>>>CCAPI handed cid 76 with tag 30 to app "_ManagedAppProcess_Default"
Feb  6 15:54:38.575: //76/11872C9E805D/CCAPI/ccCallProceeding:
Feb  6 15:54:38.579: //76/11872C9E805D/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=201, Params=0x69536940, Progress Indication=NULL(0)
Feb  6 15:54:38.579: //76/11872C9E805D/CCAPI/ccCheckClipClir:
   Destination Pattern=201, Called Number=201, Digit Strip=TRUE
   Called Number=201(TON=Unknown, NPI=Unknown),
   Guid=11872C9E-A5A8-11ED-805D-ACF0AF83D342, Outgoing Dial-peer=201
Feb  6 15:54:38.579: //76/11872C9E805D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=201
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  6 15:54:38.583: //76/11872C9E805D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x68611614, Interface Type=6, Destination=, Mode=0x0,
   Called Number=201(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=201, Call Count On=FALSE,
Feb  6 15:54:38.583: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 15:54:38.583: :cc_get_feature_vsa malloc success
Feb  6 15:54:38.583:  cc_get_feature_vsa count is 2
Feb  6 15:54:38.583: :FEATURE_VSA attributes are: feature_name:0,feature_time:1721143824,feature_id:28
Feb  6 15:54:38.583: //77/11872C9E805D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Feb  6 15:54:38.583: //77/11872C9E805D/CCAPI/ccCallSetContext:
   Context=0x695368F0
Feb  6 15:54:38.583: //76/11872C9E805D/CCAPI/ccSaveDialpeerTag:
Feb  6 15:54:38.591: //77/11872C9E805D/CCAPI/cc_api_call_proceeding:
   Interface=0x68611614, Progress Indication=NULL(0)
Feb  6 15:54:38.591: //77/11872C9E805D/CCAPI/cc_api_call_cut_progress:
   Interface=0x68611614, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Feb  6 15:54:38.595: //76/11872C9E805D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 06 Feb 2023 22:54:38 GMT
CSeq: 15584 INVITE
Content-Length: 0
Feb  6 15:54:38.595: //76/11872C9E805D/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Feb  6 15:54:38.595: //76/11872C9E805D/CCAPI/ccConferenceCreate:
   (confID=0x696289E0, callID1=0x4C, gcid=118864EE-A5A811ED-8060ACF0-AF83D342, tag=0x0)
Feb  6 15:54:38.595: //77/11872C9E805D/CCAPI/ccConferenceCreate:
   (confID=0x696289E0, callID2=0x4D, gcid=118864EE-A5A811ED-8060ACF0-AF83D342, tag=0x0)
   Conference Id=0x696289E0, Call Id1=76, Call Id2=77, Tag=0x0
Feb  6 15:54:38.599: //76/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  6 15:54:38.599: cc_api_get_xcode_stream : 4702
Feb  6 15:54:38.599: //76/11872C9E805D/CCAPI/cc_api_bridge_done:
   Conference Id=0x9, Source Interface=0x67F2B37C, Source Call Id=76,
   Destination Call Id=77, Disposition=0x0, Tag=0x0
Feb  6 15:54:38.599: //77/11872C9E805D/CCAPI/cc_api_bridge_done:
   Conference Id=0x9, Source Interface=0x68611614, Source Call Id=77,
   Destination Call Id=76, Disposition=0x0, Tag=0xFFFFFFFF
Feb  6 15:54:38.603: //76/11872C9E805D/CCAPI/cc_generic_bridge_done:
Feb  6 15:54:38.603: //76/11872C9E805D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x9, Destination Call Id=77)
Feb  6 15:54:38.603: //77/11872C9E805D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x9, Destination Call Id=76)
Feb  6 15:54:38.603: //77/11872C9E805D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x67F2B37C, Destination Call Id=76, Source Call Id=77,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb  6 15:54:38.603: //76/11872C9E805D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x68611614, Destination Call Id=77, Source Call Id=76,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Feb  6 15:54:38.603: //76/11872C9E805D/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=2027)
Feb  6 15:54:38.607: //77/11872C9E805D/CCAPI/cc_api_caps_ack:
Feb  6 15:54:38.607: //76/11872C9E805D/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=76
Feb  6 15:54:38.611: //76/11872C9E805D/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x9, Call Id1=76, Call Id2=77
Feb  6 15:54:38.615: //77/11872C9E805D/CCAPI/cc_api_voice_mode_event:
   Call Id=77
   Call Entry(Context=0x695368F0)
Feb  6 15:54:38.615: //76/11872C9E805D/CCAPI/cc_api_event_indication:
   Event=90, Call Id=76
   Event Is Sent To Conferenced SPI(s) Directly
Feb  6 15:54:38.615: //76/11872C9E805D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: sip:15202827081@64.119.40.170:60577;transport=udp;tag=1120B0-87B
CSeq: 15584 INVITE
A
VOIP#llow-Events: telephone-event
Contact: <sip:15202827081@10.169.197.102:5060>
Supported: sdp-anat
Content-Length: 197
v=0
o=CiscoSystemsSIP-GW-UserAgent 5939 7195 IN IP4 10.169.197.102
s=SIP Call
c=IN IP4 10.169.197.102
t=0 0
m=audio 17118 RTP/AVP 0
a=ptime:20
VOIP#
Feb  6 15:54:42.156: //77/11872C9E805D/CCAPI/cc_api_voice_mode_event:
   Call Id=77
Feb  6 15:54:42.941: //77/11872C9E805D/CCAPI/cc_api_call_connected:
   Interface=0x68611614, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb  6 15:54:42.941: //76/11872C9E805D/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Feb  6 15:54:42.945: //76/11872C9E805D/CCAPI/ccCallNotify:
Feb  6 15:54:42.953: //76/11872C9E805D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 15584 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 197
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb  6 15:54:43.173: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#ACK sip:15202827081@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bK22l2sk00eo4jp6h3nls0.1
CSeq: 15584 ACK
Content-Length: 0
Max-Forwards: 70
VOIP#
Feb  6 15:54:44.774: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:101@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bKq5dthl300881urtgpfj0
From: <sip:101@siptrunk.p2.alianza.com:5065>;tag=a96
Date: Mon, 06 Feb 2023 22:45:34 GMT
Call-ID: dcf4c412111ea51c1c7ee9216155beab010@173.244.45.246
Max-Forwards: 69
Timestamp: 1675723534
CSeq: 11 OPTIONS
Expires: 3600
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:siptrunk.p2.alianza.com:5065",response="2fc280628a101c713310198c056cafdd",nonce="MDAxNjc1NzIzNTM0OjUxNDQxNDkwM1gwamF3cktuSnBWYWJHYmh6aEFva0E9PQA=",algorithm=md5
Content-Length: 0
Feb  6 15:54:44.790: //78/153D496E8063/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:101@siptrunk.p2.alianza.com>;tag=1138C8-E97
Date: Mon, 06 Feb 2023 22:54:44 GMT
CSeq: 11 OPTIONS
Accept: application/sdp
Supported
VOIP#: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 170
v=0
o=CiscoSystemsSIP-GW-UserAgent 4470 9964 IN IP4 64.119.40.170
s=SIP Call
c=IN IP4 64.119.40.170
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
VOIP#
Feb  6 15:54:49.616: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:15202827081@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bK22l2sk00eo4jp6h3nls0cd000ojg3.1
CSeq: 15585 BYE
Content-Length: 0
Supported: timer
Max-Forwards: 69
Feb  6 15:54:49.620: //77/11872C9E805D/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=77
Feb  6 15:54:49.620: //76/11872C9E805D/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x67F2B37C, Call Id=76
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Feb  6 15:54:49.624: //76/11872C9E805D/CCAPI/ccConferenceDestroy:
   Conference Id=0x9, Tag=0x0
Feb  6 15:54:49.624: //76/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  6 15:54:49.624: cc_api_get_xcode_stream : 4702
Feb  6 15:54:49.624: //77/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  6 15:54:49.624: //76/11872C9E805D/CCAPI/cc_api_bridge_drop_done:
Feb  6 15:54:49.628: //77/11872C9E805D/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=76, Disposition=0x0, Tag=0x0
Feb  6 15:54:49.628: //76/11872C9E805D/CCAPI/cc_generic_bridge_done:
Feb  6 15:54:49.628: //76/11872C9E805D/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Feb  6 15:54:49.632: //76/11872C9E805D/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Feb  6 15:54:49.632: //77/11872C9E805D/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb  6 15:54:49.632: //77/11872C9E805D/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Feb  6 15:54:49.640: //76/11872C9E805D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67F2B37C, Tag=0x0, Call Id=76,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Feb  6 15:54:49.644: //76/11872C9E805D/CCAPI/cc_api_call_disconnect_done:
Feb  6 15:54:49.644: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 15:54:49.644: :cc_free_feature_vsa freeing 669692E8
Feb  6 15:54:49.644:  vsacount in free is 1
Feb  6 15:54:49.644: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
VOIP#SIP/2.0 200 OK
Date: Mon, 06 Feb 2023 22:54:49 GMT
CSeq: 15585 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=371,OS=59360,PR=0,OR=0,PL=0,JI=1,LA=0,DU=6
Content-Length: 0
VOIP#
Feb  6 15:54:50.736: //77/11872C9E805D/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x68611614, Call Id=77
Feb  6 15:54:50.740: //77/11872C9E805D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68611614, Tag=0x0, Call Id=77,
Feb  6 15:54:50.740: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 15:54:50.740: :cc_free_feature_vsa freeing 66969208
Feb  6 15:54:50.740:  vsacount in free is 0
Feb  6 15:54:51.785: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK448CC
From: <sip:101@siptrunk.p2.alianza.com>;tag=115420-12E
Date: Mon, 06 Feb 2023 22:54:51 GMT
Call-ID: A5FF349E-14EE11CC-8004ACF0-AF83D342
Max-Forwards: 70
Timestamp: 1675724091
CSeq: 17 REGISTER
Contact: <sip:101@10.169.197.102:5060>
Expires:  3600
Supported: path
Content-Length: 0
Feb  6 15:54:52.061: //79/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK448CC;rport=60577
To: <sip:101@siptrunk.p2.alianza.com>;tag=aprqvui9hs8e4bo67-13u7je1000021
CSeq: 17 REGISTER
Contact: <sip:101@10.169.197.102:5060>;expires=161
Content-Length: 0
Outgoing calls are not connecting, I see multiple INVITE messages going out but nothing coming back from the carrier.
Feb  6 15:55:58.837: //-1/4161DC828065/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
Feb  6 15:55:58.841: //-1/4161DC828065/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x68611614, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=201, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Feb  6 15:55:58.841: //-1/4161DC828065/CCAPI/ccCheckClipClir:
   In: Calling Number=201(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=201(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb  6 15:55:58.841: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 15:55:58.841: :cc_get_feature_vsa malloc success
Feb  6 15:55:58.841:  cc_get_feature_vsa count is 1
Feb  6 15:55:58.841: :FEATURE_VSA attributes are: feature_name:0,feature_time:1721143824,feature_id:29
Feb  6 15:55:58.841: //83/4161DC828065/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=201(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Feb  6 15:55:58.845: //83/4161DC828065/CCAPI/cc_process_call_setup_ind:
   Event=0x685C2E18
Feb  6 15:55:58.845: //83/4161DC828065/CCAPI/ccCallSetContext:
   Context=0x69537DB0
   >>>>CCAPI handed cid 83 with tag 201 to app "_ManagedAppProcess_Default"
Feb  6 15:55:58.849: //83/4161DC828065/CCAPI/ccCallSetupAck:
   Call Id=83
Feb  6 15:55:58.849: //83/4161DC828065/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Feb  6 15:55:58.849: //83/4161DC828065/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=83
Feb  6 15:55:58.849: //83/4161DC828065/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Feb  6 15:55:58.849: //83/4161DC828065/CCAPI/ccCallReportDigits:
   (callID=0x53, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=83
VOIP#
Feb  6 15:55:58.849: //83/4161DC828065/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x68611614, callID=0x53, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x68611614, Call Id=83
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Feb  6 15:55:59.886: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=83, Digit=5, DigitBeginFlags=0x1,
   Rtp Timestamp=0x17F145A1, Rtp Expiration=0x0
Feb  6 15:56:00.006: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=5, Duration=157,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Feb  6 15:56:00.534: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
VOIP#Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=83, Digit=4, DigitBeginFlags=0x1,
   Rtp Timestamp=0x17F159F6, Rtp Expiration=0x0
Feb  6 15:56:00.686: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=4, Duration=182,
Feb  6 15:56:00.814: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x17F162AE, Rtp Expiration=0x0
Feb  6 15:56:00.954: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=5, Duration=180,
Feb  6 15:56:01.146: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
   Source Call Id=83, Digit=7, DigitBeginFlags=0x1,
   Rtp Timestamp=0x17F16CFE, Rtp Expiration=0x0
Feb  6 15:56:01.226: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=7, Duration=120,
Feb  6 15:56:01.454: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
   Source Call Id=83, Digit=2, DigitBeginFlags=0x1,
   Rtp Timestamp=0x17F176B1, Rtp Expiration=0x0
Feb  6 15:56:01.614: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=2, Duration=197,
Feb  6 15:56:01.794: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
   Source Call Id=83, Digit=8, DigitBeginFlags=0x1,
   Rtp Timestamp=0x17F18153, Rtp Expiration=0x0
Feb  6 15:56:01.954: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=8, Duration=195,
Feb  6 15:56:02.074: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x17F18A0E, Rtp Expiration=0x0
Feb  6 15:56:02.187: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=5, Duration=150,
VOIP#
Feb  6 15:56:08.289: //83/4161DC828065/CCAPI/cc_api_call_digit_begin:
   Source Call Id=83, Digit=#, DigitBeginFlags=0x1,
   Rtp Timestamp=0x17F24C1E, Rtp Expiration=0x0
Feb  6 15:56:08.357: //83/4161DC828065/CCAPI/cc_api_call_digit_end:
   Source Call Id=83, Digit=#, Duration=110,
Feb  6 15:56:08.361: //83/4161DC828065/CCAPI/ccCallReportDigits:
   (callID=0x53, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  6 15:56:08.361: //83/4161DC828065/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x68611614, callID=0x53, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  6 15:56:08.361: //83/4161DC828065/CCAPI/ccCallProceeding:
Feb  6 15:56:08.369: //83/4161DC828065/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=40, Params=0x695392C0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb  6 15:56:08.369: //83/4161DC828065/CCAPI/ccCheckClipClir:
   In: Calling Number=5202827081(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=5202827081(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=.T, Called Number=15205457285, Digit Strip=FALSE
   Calling Number=5202827081(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=15205457285(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=4161DC82-A5A8-11ED-8065-ACF0AF83D342, Outgoing Dial-peer=40
Feb  6 15:56:08.369: //83/4161DC828065/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=5202827081
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=15205457285
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  6 15:56:08.373: //83/4161DC828065/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x67F2B37C, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=5202827081,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=15205457285(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=40, Call Count On=FALSE,
Feb  6 15:56:08.373: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 15:56:08.373: :cc_get_feature_vsa malloc success
Feb  6 15:56:08.373:  cc_get_feature_vsa count is 2
Feb  6 15:56:08.373: :FEATURE_VSA attributes are: feature_name:0,feature_time:1721144048,feature_id:30
Feb  6 15:56:08.373: //84/4161DC828065/CCAPI/ccIFCallSetupRequestPrivate:
Feb  6 15:56:08.373: //84/4161DC828065/CCAPI/ccCallSetContext:
   Context=0x69539270
Feb  6 15:56:08.373: //83/4161DC828065/CCAPI/ccSaveDialpeerTag:
Feb  6 15:56:08.377: //84/4161DC828065/CCAPI/cc_api_call_proceeding:
   Interface=0x67F2B37C, Progress Indication=NULL(0)
Feb  6 15:56:08.389: //84/4161DC828065/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:15205457285@siptrunk.p2.alianza.com:5065 SIP/2.0
Via: SIP/2.0/UDP 64.119.40.170:5060;branch=z9hG4bK471164
From: <sip:5202827081@siptrunk.p2.alianza.com>;tag=127F38-B5D
To: <sip:15205457285@siptrunk.p2.alianza.com>
Date: Mon, 06 Feb 2023 22:56:08 GMT
Call-ID: 4711952C-A5A811ED-806AACF0-AF83D342@10.169.197.102
Min-SE:  1800
Cisco-Guid: 1096932482-2779255277-2154147056-2944652098
Allow: INVITE
VOIP#, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675724168
Contact: <sip:5202827081@64.119.40.170:5060>
Expires: 180
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 6830 8549 IN IP4 64.119.40.170
s=SIP Call
t=0 0
m=audio 19308 RTP/AVP 0
a=ptime:20
Feb  6 15:56:08.893: //84/4161DC828065/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
Allow: INVITE
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb  6 15:56:09.894: //84/4161DC828065/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Feb 2023 22:56:09 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675724169
Expires: 180
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
VOIP#
Feb  6 15:56:11.895: //84/4161DC828065/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Feb 2023 22:56:11 GMT
Min-SE:  1800
Allow: INVITE
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675724171
Expires: 180
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
VOIP#
Feb  6 15:56:15.896: //84/4161DC828065/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Feb 2023 22:56:15 GMT
Min-SE:  1800
Allow: INVITE
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675724175
Expires: 180
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
VOIP#
Feb  6 15:56:23.900: //84/4161DC828065/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Feb 2023 22:56:23 GMT
Min-SE:  1800
Allow: INVITE
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675724183
Expires: 180
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
VOIP#
Feb  6 15:56:31.507: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:100@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bKdtguhk2098u23rnqe7g0
From: <sip:100@siptrunk.p2.alianza.com:5065>;tag=a98
Date: Mon, 06 Feb 2023 22:47:15 GMT
Call-ID: 133be9112df974663dfb311027d7fb5b050@173.244.45.246
Max-Forwards: 69
Timestamp: 1675723635
CSeq: 12 OPTIONS
Expires: 3600
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:siptrunk.p2.alianza.com:5065",response="154357687d52bf72d7b4bf0f47823c7f",nonce="MDAxNjc1NzIzNjM1OjUxNzI2NDg4MXNyN2MvMXFDWlFlWUxEV3BTbW54Nnc9PQA=",algorithm=md5
Content-Length: 0
Feb  6 15:56:31.523: //85/54DB894E806B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:100@siptrunk.p2.alianza.com>;tag=12D988-43A
Date: Mon, 06 Feb 2023 22:56:31 GMT
CSeq: 12 OPTIONS
Supported
Content-Length: 170
v=0
o=CiscoSystemsSIP-GW-UserAgent 6246 5962 IN IP4 64.119.40.170
s=SIP Call
t=0 0
VOIP#
Feb  6 15:56:39.479: //83/4161DC828065/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x68611614, Call Id=83
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Feb  6 15:56:39.479: //84/4161DC828065/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Feb  6 15:56:39.483: //83/4161DC828065/CCAPI/ccCallDisconnect:
Feb  6 15:56:39.483: //83/4161DC828065/CCAPI/cc_api_get_transfer_info:
Feb  6 15:56:39.491: //83/4161DC828065/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68611614, Tag=0x0, Call Id=83,
VOIP#
Feb  6 15:56:39.491: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 15:56:39.491: :cc_free_feature_vsa freeing 66969208
Feb  6 15:56:39.491:  vsacount in free is 1
Feb  6 15:56:39.907: //84/4161DC828065/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Feb 2023 22:56:39 GMT
Min-SE:  1800
Allow: INVITE
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675724199
Expires: 180
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
VOIP#
Feb  6 15:56:44.521: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK482585
From: <sip:100@siptrunk.p2.alianza.com>;tag=130C50-144E
Date: Mon, 06 Feb 2023 22:56:44 GMT
Call-ID: A5FE9876-14EE11CC-8003ACF0-AF83D342
Max-Forwards: 70
Timestamp: 1675724204
CSeq: 19 REGISTER
Contact: <sip:100@10.169.197.102:5060>
Expires:  3600
Supported: path
Content-Length: 0
Feb  6 15:56:44.669: //86/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK482585;rport=60577
To: <sip:100@siptrunk.p2.alianza.com>;tag=aprqvui9hs8e4bo67-hppo2u2000061
CSeq: 19 REGISTER
Contact: <sip:100@10.169.197.102:5060>;expires=131
Content-Length: 0
I disabled voice-class sip profiles 40 on dial-peer voice 40 voip and now I can at least dial out even if there is no RTP still.
Feb  6 15:57:28.452: //-1/76CBF4F6806C/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  6 15:57:28.456: //-1/76CBF4F6806C/CCAPI/cc_api_call_setup_ind_common:
Feb  6 15:57:28.456: //-1/76CBF4F6806C/CCAPI/ccCheckClipClir:
Feb  6 15:57:28.456: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 15:57:28.456: :cc_get_feature_vsa malloc success
Feb  6 15:57:28.456:  cc_get_feature_vsa count is 1
Feb  6 15:57:28.456: :FEATURE_VSA attributes are: feature_name:0,feature_time:1721144048,feature_id:31
Feb  6 15:57:28.456: //88/76CBF4F6806C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Feb  6 15:57:28.460: //88/76CBF4F6806C/CCAPI/cc_process_call_setup_ind:
   Event=0x685C2E18
Feb  6 15:57:28.460: //88/76CBF4F6806C/CCAPI/ccCallSetContext:
   Context=0x6953BBF0
   >>>>CCAPI handed cid 88 with tag 201 to app "_ManagedAppProcess_Default"
Feb  6 15:57:28.464: //88/76CBF4F6806C/CCAPI/ccCallSetupAck:
   Call Id=88
Feb  6 15:57:28.464: //88/76CBF4F6806C/CCAPI/cc_api_set_transfer_info:
Feb  6 15:57:28.464: //88/76CBF4F6806C/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=88
Feb  6 15:57:28.464: //88/76CBF4F6806C/CCAPI/ccSetDigitTimeouts:
Feb  6 15:57:28.464: //88/76CBF4F6806C/CCAPI/ccCallReportDigits:
   (callID=0x58, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=88
VOIP#
Feb  6 15:57:28.464: //88/76CBF4F6806C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x68611614, callID=0x58, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x68611614, Call Id=88
Feb  6 15:57:28.468: //88/76CBF4F6806C/CCAPI/cc_api_call_report_digits_done:
VOIP#
Feb  6 15:57:29.668: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=88, Digit=5, DigitBeginFlags=0x1,
   Rtp Timestamp=0x26A46ACD, Rtp Expiration=0x0
Feb  6 15:57:29.748: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
   Source Call Id=88, Digit=5, Duration=112,
Feb  6 15:57:30.268: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=88, Digit=4, DigitBeginFlags=0x1,
   Rtp Timestamp=0x26A47D88, Rtp Expiration=0x0
Feb  6 15:57:30.348: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
   Source Call Id=88, Digit=4, Duration=117,
Feb  6 15:57:30.460: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x26A4837D, Rtp Expiration=0x0
Feb  6 15:57:30.540: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
Feb  6 15:57:30.681: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=88, Digit=7, DigitBeginFlags=0x1,
   Rtp Timestamp=0x26A48A55, Rtp Expiration=0x0
Feb  6 15:57:30.761: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
   Source Call Id=88, Digit=7, Duration=120,
Feb  6 15:57:30.909: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=88, Digit=2, DigitBeginFlags=0x1,
   Rtp Timestamp=0x26A49188, Rtp Expiration=0x0
Feb  6 15:57:30.989: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
   Source Call Id=88, Digit=2, Duration=117,
Feb  6 15:57:31.129: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=88, Digit=8, DigitBeginFlags=0x1,
   Rtp Timestamp=0x26A4986D, Rtp Expiration=0x0
Feb  6 15:57:31.241: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
   Source Call Id=88, Digit=8, Duration=142,
Feb  6 15:57:31.349: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x26A49F4D, Rtp Expiration=0x0
Feb  6 15:57:31.429: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
Feb  6 15:57:31.789: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_begin:
   Source Call Id=88, Digit=#, DigitBeginFlags=0x1,
   Rtp Timestamp=0x26A4AD0A, Rtp Expiration=0x0
Feb  6 15:57:31.869: //88/76CBF4F6806C/CCAPI/cc_api_call_digit_end:
   Source Call Id=88, Digit=#, Duration=115,
Feb  6 15:57:31.869: //88/76CBF4F6806C/CCAPI/ccCallReportDigits:
   (callID=0x58, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  6 15:57:31.873: //88/76CBF4F6806C/CCAPI/ccCallReportDigits:
Feb  6 15:57:31.873: //88/76CBF4F6806C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x68611614, callID=0x58, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  6 15:57:31.873: //88/76CBF4F6806C/CCAPI/ccCallProceeding:
Feb  6 15:57:31.877: //88/76CBF4F6806C/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=40, Params=0x6953A780, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb  6 15:57:31.881: //88/76CBF4F6806C/CCAPI/ccCheckClipClir:
Feb  6 15:57:31.881: //88/76CBF4F6806C/CCAPI/ccCallSetupRequest:
   Guid=76CBF4F6-A5A8-11ED-806C-ACF0AF83D342, Outgoing Dial-peer=40
Feb  6 15:57:31.881: //88/76CBF4F6806C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=15205457285
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  6 15:57:31.881: //88/76CBF4F6806C/CCAPI/ccIFCallSetupRequestPrivate:
Feb  6 15:57:31.881: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 15:57:31.885: :cc_get_feature_vsa malloc success
Feb  6 15:57:31.885: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
VOIP#
Feb  6 15:57:31.885:  cc_get_feature_vsa count is 2
Feb  6 15:57:31.885: :FEATURE_VSA attributes are: feature_name:0,feature_time:1721143824,feature_id:32
Feb  6 15:57:31.885: //89/76CBF4F6806C/CCAPI/ccIFCallSetupRequestPrivate:
Feb  6 15:57:31.885: //89/76CBF4F6806C/CCAPI/ccCallSetContext:
   Context=0x6953A730
Feb  6 15:57:31.885: //88/76CBF4F6806C/CCAPI/ccSaveDialpeerTag:
Feb  6 15:57:31.889: //89/76CBF4F6806C/CCAPI/cc_api_call_proceeding:
Feb  6 15:57:32.093: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4A25FE
From: <sip:5202827081@siptrunk.p2.alianza.com>;tag=13C610-B6C
Date: Mon, 06 Feb 2023 22:57:32 GMT
Call-ID: 78D878D3-A5A811ED-8071ACF0-AF83D342@10.169.197.102
Min-SE:  1800
Cisco-Guid: 1993078006-2779255277-2154605808-2944652098
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675724252
Contact: <sip:5202827081@10.169.197.102:5060>
Expires: 180
Content-Length: 197
v=0
o=CiscoSystemsSIP-GW-UserAgent 9070 3303 IN IP4 10.169.197.102
s=SIP Call
t=0 0
m=audio 19238 RTP/AVP 0
a=ptime:20
Feb  6 15:57:32.289: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK4A25FE;rport=60577
CSeq: 101 INVITE
Content-Length: 0
Feb  6 15:57:32.297: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:15205457285@siptrunk.p2.alianza.com>;tag=SDer8vb99-lignup-31c0-63e185db
CSeq: 101 INVITE
Content-Length: 0
WWW-Authenticate: Digest nonce="MDAxNjc1NzI0MjUxOjQzOTM5MTExNlhEY3FhTDVWWUl0MG5ZdWRyUjRjOGc9PQA=",realm="Alianza"
Feb  6 15:57:32.305: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:15205457285@siptrunk.p2.alianza.com:5065 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4B1770
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:15205457285@siptrunk.p2.alianza.com:5065",response="f60ca5aa34a819dd916e09820a9d194f",nonce="MDAxNjc1NzI0MjUxOjQzOTM5MTExNlhEY3FhTDVWWUl0MG5ZdWRyUjRjOGc9PQA=",algorithm=md5
Content-Length: 197
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb  6 15:57:32.409: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK4B1770;rport=60577
CSeq: 102 INVITE
Content-Length: 0
Feb  6 15:57:33.049: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:15205457285@siptrunk.p2.alianza.com>;tag=SDer8vb99-lignup-2506-63e185dc
CSeq: 102 INVITE
Content-Length: 239
Require: 100rel
RSeq: 1
Allow: INVITE
Allow: ACK
Allow: PRACK
Allow: CANCEL
Allow: BYE
Allow: REFER
Allow: NOTIFY
Allow: OPTIONS
Allow: MESSAGE
Allow: INFO
Allow: REGISTER
Allow: SUBSCRIBE
v=0
o=CPE2_Media_Cluster 1202456901 1202456902 IN IP4 173.244.45.188
s=606f9bc7-5262-4cdd-ad0b-faea70c86615/18b34228-f255-4ce3-a4c3-4ee55c630cb9
t=0 0
m=audio 25888 RTP/AVP 0
a=ptime:20
Feb  6 15:57:33.053: //89/76CBF4F6806C/CCAPI/cc_api_call_cut_progress:
   Interface=0x67F2B37C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
Feb  6 15:57:33.057: //88/76CBF4F6806C/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
Feb  6 15:57:33.061: //88/76CBF4F6806C/CCAPI/ccGenerateToneInfo:
Feb  6 15:57:33.061: //88/76CBF4F6806C/CCAPI/ccConferenceCreate:
   (confID=0x69628A28, callID1=0x58, gcid=76CBF4F6-A5A811ED-806CACF0-AF83D342, tag=0x0)
Feb  6 15:57:33.061: //89/76CBF4F6806C/CCAPI/ccConferenceCreate:
   (confID=0x69628A28, callID2=0x59, gcid=76CBF4F6-A5A811ED-806CACF0-AF83D342, tag=0x0)
   Conference Id=0x69628A28, Call Id1=88, Call Id2=89, Tag=0x0
Feb  6 15:57:33.061: //88/76CBF4F6806C/CCAPI/cc_api_bridge_done:
   Conference Id=0xA, Source Interface=0x68611614, Source Call Id=88,
   Destination Call Id=89, Disposition=0x0, Tag=0xFFFFFFFF
Feb  6 15:57:33.061: //89/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  6 15:57:33.061: cc_api_get_xcode_stream : 4702
Feb  6 15:57:33.065: cc_api_get_xcode_stream : 4702
Feb  6 15:57:33.065: //89/76CBF4F6806C/CCAPI/cc_api_bridge_done:
   Conference Id=0xA, Source Interface=0x67F2B37C, Source Call Id=89,
   Destination Call Id=88, Disposition=0x0, Tag=0x0
Feb  6 15:57:33.065: //88/76CBF4F6806C/CCAPI/cc_generic_bridge_done:
Feb  6 15:57:33.065: //88/76CBF4F6806C/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xA, Destination Call Id=89)
Feb  6 15:57:33.065: //89/76CBF4F6806C/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xA, Destination Call Id=88)
Feb  6 15:57:33.065: //88/76CBF4F6806C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x67F2B37C, Destination Call Id=89, Source Call Id=88,
Feb  6 15:57:33.069: //89/76CBF4F6806C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x68611614, Destination Call Id=88, Source Call Id=89,
Feb  6 15:57:33.069: //89/76CBF4F6806C/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=6137)
Feb  6 15:57:33.069: //88/76CBF4F6806C/CCAPI/cc_api_caps_ack:
Feb  6 15:57:33.074: //88/76CBF4F6806C/CCAPI/cc_api_voice_mode_event:
   Call Id=88
   Call Entry(Context=0x6953BBF0)
Feb  6 15:57:33.074: //88/76CBF4F6806C/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xA, Call Id1=88, Call Id2=89
Feb  6 15:57:33.078: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:173.244.45.246:5065;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4C9E8
CSeq: 103 PRACK
RAck: 1 102 INVITE
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:173.244.45.246:5065;tr
VOIP#ansport=udp",response="58bb6c605d8d5114606e0a81d91b51e4",nonce="MDAxNjc1NzI0MjUxOjQzOTM5MTExNlhEY3FhTDVWWUl0MG5ZdWRyUjRjOGc9PQA=",algorithm=md5
Max-Forwards: 70
Content-Length: 0
Feb  6 15:57:33.326: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK4C9E8;rport=60577
CSeq: 103 PRACK
Content-Length: 0
VOIP#
Feb  6 15:57:38.180: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 INVITE
Content-Length: 239
Allow: INVITE
Allow: ACK
Allow: PRACK
Allow: CANCEL
Allow: BYE
Allow: REFER
Allow: NOTIFY
Allow: OPTIONS
Allow: MESSAGE
Allow: INFO
Allow: REGISTER
Allow: SUBSCRIBE
Session-Expires: 1800;refresher=uas
Supported: timer
v=0
t=0 0
a=ptime:20
Feb  6 15:57:38.184: //89/76CBF4F6806C/CCAPI/cc_api_call_connected:
   Interface=0x67F2B37C, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
Feb  6 15:57:38.188: //88/76CBF4F6806C/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
Feb  6 15:57:38.196: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Sent:
VOIP#ACK sip:173.244.45.246:5065;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4DD9B
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
VOIP#
Feb  6 15:57:43.782: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4EDA0
From: <sip:ciscoiad1@siptrunk.p2.alianza.com>;tag=13F3B4-AF3
Date: Mon, 06 Feb 2023 22:57:43 GMT
Call-ID: A5DBCECC-14EE11CC-8002ACF0-AF83D342
Max-Forwards: 70
Timestamp: 1675724263
CSeq: 18 REGISTER
Contact: <sip:ciscoiad1@10.169.197.102:5060>
Expires:  3600
Supported: path
Content-Length: 0
Feb  6 15:57:43.970: //90/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK4EDA0;rport=60577
To: <sip:ciscoiad1@siptrunk.p2.alianza.com>;tag=aprqvui9hs8e4bo67-rjv9je2000041
CSeq: 18 REGISTER
Contact: <sip:ciscoiad1@10.169.197.102:5060>;expires=121
Content-Length: 0
VOIP#
Feb  6 15:57:45.027: //88/76CBF4F6806C/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x68611614, Call Id=88
Feb  6 15:57:45.027: //88/76CBF4F6806C/CCAPI/ccConferenceDestroy:
   Conference Id=0xA, Tag=0x0
Feb  6 15:57:45.027: //88/76CBF4F6806C/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=89, Disposition=0x0, Tag=0x0
Feb  6 15:57:45.027: //89/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  6 15:57:45.027: cc_api_get_xcode_stream : 4702
Feb  6 15:57:45.027: //88/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  6 15:57:45.031: cc_api_get_xcode_stream : 4702
Feb  6 15:57:45.031: //89/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  6 15:57:45.031: //89/76CBF4F6806C/CCAPI/cc_api_bridge_drop_done:
Feb  6 15:57:45.031: //88/76CBF4F6806C/CCAPI/cc_generic_bridge_done:
Feb  6 15:57:45.031: //88/76CBF4F6806C/CCAPI/ccCallDisconnect:
Feb  6 15:57:45.031: //88/76CBF4F6806C/CCAPI/cc_api_get_transfer_info:
Feb  6 15:57:45.035: //89/76CBF4F6806C/CCAPI/ccCallDisconnect:
Feb  6 15:57:45.051: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:173.244.45.246:5065;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4F816
Max-Forwards: 70
Timestamp: 1675724265
CSeq: 104 BYE
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:173.244.45.246:5065;transport=udp",response="06fdbadd50f0d0112cf862a2259b445e",nonce="MDAxNjc1NzI0MjUxOjQzOTM5MTExNlhEY3FhTDVWWUl0MG5ZdWRyUjRjOGc9PQA=",algorithm=md5
P-RTP-Stat: PS=596,OS=95360,PR=0,OR=0,PL=0,JI=1,LA=0,DU=6
Content-Length: 0
Feb  6 15:57:45.071: //88/76CBF4F6806C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68611614, Tag=0x0, Call Id=88,
Feb  6 15:57:45.071: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 15:57:45.071: :cc_free_feature_vsa freeing 669692E8
Feb  6 15:57:45.071:  vsacount in free is 1
Feb  6 15:57:45.135: //89/76CBF4F6806C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK4F816;rport=60577
CSeq: 104 BYE
Content-Length: 0
Supported: timer
VOIP#
Feb  6 15:57:45.139: //89/76CBF4F6806C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67F2B37C, Tag=0x0, Call Id=89,
Feb  6 15:57:45.139: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 15:57:45.139: :cc_free_feature_vsa freeing 66969208
Feb  6 15:57:45.139:  vsacount in free is 0
incoming calls to 15204792894 return a 404 not found which I think is expected as our dial-peer voice 30 voip is only matching on the one incoming called-number.
Feb  6 15:58:52.508: //93/A84A34ED8072/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bK9c1e3f102ooot10jfb90.1
From: "Simply Bits" <sip:15205457285@173.244.45.246:5065>;tag=SDlk75301-S03T20230206225851U14295293_DID15204792894
To: sip:15204792894@64.119.40.170:60577;transport=udp;tag=15000C-1E07
Date: Mon, 06 Feb 2023 22:58:51 GMT
Call-ID: SDlk75301-c1bbae99451d34956610e704227daeb4-ao1a0u3
CSeq: 22804 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Here is the full config:
! Last configuration change at 15:57:27 MST Mon Feb 6 2023 by johnk
! NVRAM config last updated at 15:48:29 MST Mon Feb 6 2023 by johnk
version 15.1
hostname VOIP
boot-start-marker
boot-end-marker
card type t1 1
aaa new-model
ip source-route
no ip routing
no ip cef
ip dhcp pool PHONES
 dns-server 8.8.8.8
no ipv6 cef
voice rtp send-recv
voice service voip
 redirect ip2ip
 sip
  sip-profiles 1
voice class sip-profiles 1
 request ANY sip-header Diversion remove
 request INVITE sip-header Diversion remove
 request ANY sip-header From modify "10.169.197.102" "64.119.40.170"
 request ANY sip-header Via modify "10.169.197.102" "64.119.40.170"
 request ANY sip-header Remote-Party-ID modify "10.169.197.102" "64.119.40.170"
 request ANY sip-header Contact modify "10.169.197.102" "64.119.40.170"
 response ANY sip-header Contact modify "10.169.197.102" "64.119.40.170"
 response ANY sip-header Remote-Party-ID modify "10.169.197.102" "64.119.40.170"
 request ANY sip-header Call-Info modify "10.169.197.102" "64.119.40.170"
 request ANY sip-header P-Asserted-Identity modify "10.169.197.102" "64.119.40.170"
 request ANY sdp-header Audio-Connection-Info modify "10.169.197.102" "64.119.40.170"
 request ANY sdp-header Connection-Info modify "10.169.197.102" "64.119.40.170"
 request ANY sdp-header Session-Owner modify "10.169.197.102" "64.119.40.170"
 response ANY sdp-header Session-Owner modify "10.169.197.102" "64.119.40.170"
 response ANY sdp-header Connection-Info modify "10.169.197.102" "64.119.40.170"
 response ANY sdp-header Audio-Connection-Info modify "10.169.197.102" "64.119.40.170"
 mode cme
 source-address 10.169.197.102 port 5060
 max-dn 10
 max-pool 8
 tftp-path slot0:
 file text
 create profile sync 000502663628053A
voice translation-rule 1
 rule 1 /^1/ //
voice translation-rule 2
 rule 1 /5204792894/ /101/
 rule 2 /5204792896/ /100/
 rule 3 /5202827081/ /201/
voice translation-rule 10
 rule 1 /100/ /5204792896/
 rule 2 /101/ /5204792894/
 rule 3 /201/ /5202827081/
voice translation-rule 20
 rule 3 /9911/ /911/
voice translation-rule 30
 rule 1 /15204792894/ /101/
 rule 2 /15204792896/ /100/
 rule 3 /15202827081/ /201/
voice translation-profile CONVERT_TO_XTN
 translate called 2
voice translation-profile DID_To_Ext
 translate called 30
voice translation-profile EXTENSION_TO_CID
 translate calling 10
 translate called 20
voice translation-profile STRIP-1
 translate called 1
voice-card 0
archive
 log config
  hidekeys
 path slot0:
 maximum 14
 write-memory
controller T1 1/0
ip ssh version 2
interface Loopback0
 no ip address
 ip address dhcp
 no ip route-cache
 duplex auto
 speed auto
 no ip route-cache
 duplex auto
 speed auto
 ntp broadcast
 no ip address
ip http server
control-plane
voice-port 2/0
 no battery-reversal
voice-port 2/1
 no battery-reversal
 caller-id enable
voice-port 2/2
 no battery-reversal
voice-port 2/3
 no battery-reversal
voice-port 2/4
 no battery-reversal
voice-port 2/5
 no battery-reversal
voice-port 2/6
 no battery-reversal
voice-port 2/7
 no battery-reversal
voice-port 2/8
 no battery-reversal
voice-port 2/9
 no battery-reversal
voice-port 2/10
 no battery-reversal
voice-port 2/11
 no battery-reversal
voice-port 2/12
 no battery-reversal
voice-port 2/13
 no battery-reversal
voice-port 2/14
 no battery-reversal
voice-port 2/15
 no battery-reversal
 port 2/0
 no sip-register
 port 2/1
 no sip-register
 port 2/2
 no sip-register
 port 2/3
 no sip-register
 port 2/4
 no sip-register
 port 2/5
 no sip-register
 description Incoming Calls from the Carrier
 translation-profile incoming DID_To_Ext
 session protocol sipv2
 session target sip-server
 codec g711ulaw
 no vad
 description Outgoing dial-peer to the Carrier
 translation-profile outgoing EXTENSION_TO_CID
 destination-pattern .T
 codec g711ulaw
 no vad
gateway
sip-ua
 no remote-party-id
telephony-service
 no auto-reg-ephone
 max-ephones 30
 max-dn 150
 cnf-file perphone
 transfer-pattern .T
ephone-dn  1
ephone-dn  10
 number 100
 label x100
 allow watch
ephone-dn  11
 number 101
 label x101
 allow watch
ephone  1
 type 7965
 button  1:10
ephone  2
 type 7965
 button  1:11
line con 0
line aux 0
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 transport input all
ntp master
end
From the logs, I see that the outbound calls succeed when dial peer 40 is not using sip profile 40 and fail it does use this profile. I believe we should not modify the via header and contact header. The from field uses an FQDN so it is ok to remove that rule from sip profiles s well.
That being said, let's use the commands below to remove the rules that we don't need.
no request ANY sip-header From modify "10.169.197.102" "64.119.40.170"
no request ANY sip-header Via modify "10.169.197.102" "64.119.40.170"
no request ANY sip-header Contact modify "10.169.197.102" "64.119.40.170"
no response ANY sip-header Contact modify "10.169.197.102" "64.119.40.170"
Then let's make sure our revised sip profiles 40 is applied to dial peer 40 as shown below. I also added a line for DTMF to the dial peer.
dtmf-relay rtp-nte
As for inbound, the call seems to go through but you need to apply sip profiles 40 to dial peer 30 as well. Let's change the incoming called-number to a dot and also add the dtmf-relay rtp-nte command as shown below.
incoming called-number .
dtmf-relay rtp-nte
Please test again and let me know.
Incoming calls are working to the pots port and I can call out from the pots port, Still no RTP but that's not a problem I care about still.
Incoming calls are working to the SCCP phones, and I can call out from the SCCP phones, The Diversion header I need to remove is present and affecting incoming calling.
When I called out the SDP still looks wrong to me, Multiple connection entries with the same IP that hasn't been translated.
Feb  7 10:18:40.942: //19/496935E9800E/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK10D55
From: <sip:5202827081@siptrunk.p2.alianza.com>;tag=66D40-674
Date: Tue, 07 Feb 2023 17:18:40 GMT
Call-ID: 4C92E276-A64211ED-80139558-EE629EF9@10.169.197.102
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1231631849-2789347821-2148439384-3999440633
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1675790320
Expires: 180
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:15205457285@siptrunk.p2.alianza.com:5065",response="e0942d75563f4c1ac6336cec505c967d",nonce="MDAxNjc1NzkwMzIwOjYwMjI3ODY1YStQbjBQbVdOUW90b1pVSDhldHpNdz09AA==",algorithm=md5
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 8224 7759 IN IP4 10.169.197.102
s=SIP Call
t=0 0
m=audio 17634 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
7 digit outbound dialing is working but not 10 or 11, Those are getting rewritten incorrectly it appears.
Feb  7 10:43:18.374: //-1/BDAEF9998040/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   final_redirectNumber =
   hunt_group_timeout =0
Feb  7 10:43:18.374: //-1/BDAEF9998040/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x69316158, Call Info(
   Calling Number=100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Incoming Dial-peer=20002, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Feb  7 10:43:18.374: //-1/BDAEF9998040/CCAPI/ccCheckClipClir:
   In: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb  7 10:43:18.374: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  7 10:43:18.374: :cc_get_feature_vsa malloc success
Feb  7 10:43:18.374:  cc_get_feature_vsa count is 1
Feb  7 10:43:18.378: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  7 10:43:18.378: :FEATURE_VSA attributes are: feature_name:0,feature_time:1766343832,feature_id:17
Feb  7 10:43:18.378: //79/BDAEF9998040/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Feb  7 10:43:18.378: //79/BDAEF9998040/CCAPI/cc_process_call_setup_ind:
   Event=0x685BE7A0
Feb  7 10:43:18.378: //79/BDAEF9998040/CCAPI/ccCallSetContext:
   Context=0x6953E174
   >>>>CCAPI handed cid 79 with tag 20002 to app "_ManagedAppProcess_Default"
Feb  7 10:43:18.382: //79/BDAEF9998040/CCAPI/ccCallSetupAck:
   Call Id=79
Feb  7 10:43:18.382: //79/BDAEF9998040/CCAPI/cc_api_set_transfer_info:
Feb  7 10:43:18.382: //79/BDAEF9998040/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=79
Feb  7 10:43:18.382: //79/BDAEF9998040/CCAPI/ccSetDigitTimeouts:
Feb  7 10:43:18.382: //79/BDAEF9998040/CCAPI/ccCallReportDigits:
   (callID=0x4F, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=79
Feb  7 10:43:18.386: //79/BDAEF9998040/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x69316158, callID=0x4F, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x69316158, Call Id=79
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=2000(ms))
Feb  7 10:43:18.839: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=79, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x12C898, Rtp Expiration=0x0
Feb  7 10:43:18.839: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
   Source Call Id=79, Digit=1, Duration=100,
Feb  7 10:43:19.039: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
VOIP#Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=79, Digit=5, DigitBeginFlags=0x0,
   Rtp Timestamp=0x134598, Rtp Expiration=0x0
Feb  7 10:43:19.039: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
   Source Call Id=79, Digit=5, Duration=100,
Feb  7 10:43:19.239: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Source Call Id=79, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x13C298, Rtp Expiration=0x0
Feb  7 10:43:19.239: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
   Source Call Id=79, Digit=2, Duration=100,
Feb  7 10:43:19.439: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Source Call Id=79, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0x143F98, Rtp Expiration=0x0
Feb  7 10:43:19.439: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
   Source Call Id=79, Digit=0, Duration=100,
Feb  7 10:43:19.639: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x14BC98, Rtp Expiration=0x0
Feb  7 10:43:19.639: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
Feb  7 10:43:19.839: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Source Call Id=79, Digit=4, DigitBeginFlags=0x0,
   Rtp Timestamp=0x153998, Rtp Expiration=0x0
Feb  7 10:43:19.839: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
   Source Call Id=79, Digit=4, Duration=100,
Feb  7 10:43:20.039: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x15B698, Rtp Expiration=0x0
Feb  7 10:43:20.039: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
Feb  7 10:43:20.239: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x163398, Rtp Expiration=0x0
Feb  7 10:43:20.239: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
Feb  7 10:43:20.439: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x16B098, Rtp Expiration=0x0
Feb  7 10:43:20.439: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
Feb  7 10:43:20.639: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x172D98, Rtp Expiration=0x0
Feb  7 10:43:20.639: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
Feb  7 10:43:20.839: //79/BDAEF9998040/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x17AA98, Rtp Expiration=0x0
Feb  7 10:43:20.839: //79/BDAEF9998040/CCAPI/cc_api_call_digit_end:
VOIP#
Feb  7 10:43:22.840: //79/BDAEF9998040/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Feb  7 10:43:22.840: //79/BDAEF9998040/CCAPI/ccCallReportDigits:
   (callID=0x4F, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  7 10:43:22.840: //79/BDAEF9998040/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x69316158, callID=0x4F, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  7 10:43:22.844: //79/BDAEF9998040/CCAPI/ccCallProceeding:
Feb  7 10:43:22.848: //79/BDAEF9998040/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=40, Params=0x6953F684, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb  7 10:43:22.848: //79/BDAEF9998040/CCAPI/ccCheckClipClir:
   In: Calling Number=5204792896(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=5204792896(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=.T, Called Number=152015205450400, Digit Strip=FALSE
   Calling Number=5204792896(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=152015205450400(TON=Unknown, NPI=Unknown),
   Guid=BDAEF999-A645-11ED-8040-9558EE629EF9, Outgoing Dial-peer=40
Feb  7 10:43:22.848: //79/BDAEF9998040/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=5204792896
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=152015205450400
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  7 10:43:22.852: //79/BDAEF9998040/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x67F277FC, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=5204792896,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=152015205450400(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb  7 10:43:22.852: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  7 10:43:22.852: :cc_get_feature_vsa malloc success
Feb  7 10:43:22.852:  cc_get_feature_vsa count is 2
Feb  7 10:43:22.852: :FEATURE_VSA attributes are: feature_name:0,feature_time:1766344056,feature_id:18
Feb  7 10:43:22.852: //80/BDAEF9998040/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Feb  7 10:43:22.856: //80/BDAEF9998040/CCAPI/ccCallSetContext:
   Context=0x6953F634
Feb  7 10:43:22.856: //79/BDAEF9998040/CCAPI/ccSaveDialpeerTag:
Feb  7 10:43:22.860: //80/BDAEF9998040/CCAPI/cc_api_call_proceeding:
   Interface=0x67F277FC, Progress Indication=NULL(0)
Feb  7 10:43:23.004: //80/BDAEF9998040/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:152015205450400@siptrunk.p2.alianza.com:5065 SIP/2.0
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4AF02
From: <sip:5204792896@siptrunk.p2.alianza.com>;tag=1D0D7C-1C1C
To: <sip:152015205450400@siptrunk.p2.alianza.com>
Date: Tue, 07 Feb 2023 17:43:23 GMT
Call-ID: C05CABDB-A64511ED-80459558-EE629EF9@10.169.197.102
Min-SE:  1800
Cisco-Guid: 3182360985-2789544429-2151716184-3999440633
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1675791803
Contact: <sip:5204792896@10.169.197.102:5060>
Expires: 180
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 9548 1355 IN IP4 10.169.197.102
s=SIP Call
t=0 0
m=audio 19300 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Feb  7 10:43:23.104: //80/BDAEF9998040/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK4AF02;rport=60234
CSeq: 101 INVITE
Content-Length: 0
Feb  7 10:43:23.112: //80/BDAEF9998040/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <sip:152015205450400@siptrunk.p2.alianza.com>;tag=SDr2cnd99-lignup-4932-63e28dba
CSeq: 101 INVITE
Content-Length: 0
WWW-Authenticate: Digest nonce="MDAxNjc1NzkxODAyOjUyMzc4MTIzOGFnTEdJL21RT0RXWTlLMHJEdkwrT3c9PQA=",realm="Alianza"
Contact: <sip:173.244.45.246:5065;transport=udp>
Feb  7 10:43:23.120: //80/BDAEF9998040/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:152015205450400@siptrunk.p2.alianza.com:5065 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 10.169.197.102:5060;branch=z9hG4bK4B119E
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Authorization: Digest username="ciscoiad1",realm="Alianza",uri="sip:152015205450400@siptrunk.p2.alianza.com:5065",response="78da3fd140d1612dd0ace9ec53f4b95f",nonce="MDAxNjc1NzkxODAyOjUyMzc4MTIzOGFnTEdJL21RT0RXWTlLMHJEdkwrT3c9PQA=",algorithm=md5
Content-Type: appli
VOIP#cation/sdp
Content-Length: 253
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Feb  7 10:43:23.236: //80/BDAEF9998040/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.169.197.102:5060;received=64.119.40.170;branch=z9hG4bK4B119E;rport=60234
CSeq: 102 INVITE
Content-Length: 0
Feb  7 10:43:23.256: //80/BDAEF9998040/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
To: <sip:152015205450400@siptrunk.p2.alianza.com>;tag=SDr2cnd99-lignup-6ade-63e28dba
CSeq: 102 INVITE
Content-Length: 0
Feb  7 10:43:23.260: //80/BDAEF9998040/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x67F277FC, Call Id=80
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Feb  7 10:43:23.260: //79/BDAEF9998040/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Feb  7 10:43:23.260: //80/BDAEF9998040/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=80
Feb  7 10:43:23.260: //80/BDAEF9998040/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Feb  7 10:43:23.264: //80/BDAEF9998040/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67F277FC, Tag=0x0, Call Id=80,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb  7 10:43:23.264: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  7 10:43:23.264: :cc_free_feature_vsa freeing 69484570
Feb  7 10:43:23.268: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  7 10:43:23.268:  vsacount in free is 1
Feb  7 10:43:23.268: //79/BDAEF9998040/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb  7 10:43:23.272: //79/BDAEF9998040/CCAPI/cc_api_get_transfer_info:
Feb  7 10:43:23.276: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
VOIP#ACK sip:152015205450400@siptrunk.p2.alianza.com:5065 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
VOIP#
Feb  7 10:43:26.454: //79/BDAEF9998040/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x69316158, Tag=0x0, Call Id=79,
Feb  7 10:43:26.454: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  7 10:43:26.454: :cc_free_feature_vsa freeing 69484490
Feb  7 10:43:26.454:  vsacount in free is 0
Working incoming call, But with a Diversion header I need to remove
Feb  7 10:44:17.882: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:15204792896@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bK4n3qvj30c0d1cdd4p990.1
CSeq: 32691 INVITE
Content-Length: 366
Call-ID: SDvs8pf01-422ee44da0de54db5096dfc8b5ad2de5-ao1a0v3020
From: "Simply Bits" <sip:15205457285@173.244.45.246:5065>;tag=SDvs8pf01-S02T20230207174417U14998173_DID15204792896
To: sip:15204792896@64.119.40.170:60234;transport=udp
Diversion: sip:15204792896@null;reason=unconditional
Max-Forwards: 65
Priority: normal
Session-Expires: 1800;refresher=uac
Allow: INVITE
Allow: ACK
Allow: PRACK
Allow: CANCEL
Allow: BYE
Allow: REFER
Allow: NOTIFY
Allow: OPTIONS
Allow: MESSAGE
Allow: INFO
Allow: REGISTER
Allow: SUBSCRIBE
Supported: timer
v=0
o=CPE2_Media_Cluster 3353715606 3353715607 IN IP4 173.244.45.186
s=d49df936-a333-4c54-a67d-b47b302ce91f/a64420fd-67fa-4807-88c2-f5af21298a87
c=IN IP4 173.244.45.186
t=0 0
m=audio 31362 RTP/AVP 0 18 101 13
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
Feb  7 10:44:17.898: //-1/E128E41B8046/CCAPI/cc_api_display_ie_subfields:
   cisco-username=15205457285
   cisco-ani=15205457285
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=15204792896
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdn=15204792896
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
Feb  7 10:44:17.902: //-1/E128E41B8046/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x67F277FC, Call Info(
   Calling Number=15205457285,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=15204792896(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=30, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=81
Feb  7 10:44:17.902: //-1/E128E41B8046/CCAPI/ccCheckClipClir:
   In: Calling Number=15205457285(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=15205457285(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb  7 10:44:17.902: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  7 10:44:17.902: :cc_get_feature_vsa malloc success
Feb  7 10:44:17.902:  cc_get_feature_vsa count is 1
Feb  7 10:44:17.902: :FEATURE_VSA attributes are: feature_name:0,feature_time:1766343832,feature_id:19
Feb  7 10:44:17.902: //81/E128E41B8046/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=15205457285(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=15204792896(TON=Unknown, NPI=Unknown))
Feb  7 10:44:17.906: //81/E128E41B8046/CCAPI/cc_process_call_setup_ind:
   Event=0x685BDCA8
Feb  7 10:44:17.906: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 15204792896
Feb  7 10:44:17.906: //81/E128E41B8046/CCAPI/ccCallSetContext:
   Context=0x69540AF4
   >>>>CCAPI handed cid 81 with tag 30 to app "_ManagedAppProcess_Default"
Feb  7 10:44:17.910: //81/E128E41B8046/CCAPI/ccCallProceeding:
Feb  7 10:44:17.914: //81/E128E41B8046/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20002, Params=0x69542004, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb  7 10:44:17.914: //81/E128E41B8046/CCAPI/ccCheckClipClir:
   Destination Pattern=100$, Called Number=100, Digit Strip=TRUE
   Called Number=100(TON=Unknown, NPI=Unknown),
   Redirect Number=15204792896, Display Info=Simply Bits
   Account Number=15205457285, Final Destination Flag=TRUE,
   Guid=E128E41B-A645-11ED-8046-9558EE629EF9, Outgoing Dial-peer=20002
Feb  7 10:44:17.914: //81/E128E41B8046/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=100
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  7 10:44:17.918: //81/E128E41B8046/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x69316158, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=15205457285,(Calling Name=Simply Bits)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=100(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20002, Call Count On=FALSE,
Feb  7 10:44:17.918: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  7 10:44:17.918: :cc_get_feature_vsa malloc success
Feb  7 10:44:17.918:  cc_get_feature_vsa count is 2
Feb  7 10:44:17.918: :FEATURE_VSA attributes are: feature_name:0,feature_time:1766344056,feature_id:20
Feb  7 10:44:17.918: //82/E128E41B8046/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Feb  7 10:44:17.918: //82/E128E41B8046/CCAPI/ccCallSetContext:
   Context=0x69541FB4
Feb  7 10:44:17.918: //81/E128E41B8046/CCAPI/ccSaveDialpeerTag:
Feb  7 10:44:17.922: //82/E128E41B8046/CCAPI/cc_api_update_call_info:
   Interface=0x69316158, Call Id=0x52
Feb  7 10:44:17.926: //82/E128E41B8046/CCAPI/cc_api_call_proceeding:
   Interface=0x69316158, Progress Indication=NULL(0)
Feb  7 10:44:17.934: //82/E128E41B8046/CCAPI/cc_api_call_alert:
   Interface=0x69316158, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Feb  7 10:44:17.934: //81/E128E41B8046/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Feb  7 10:44:17.938: //82/E128E41B8046/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=82
Feb  7 10:44:17.938: //81/E128E41B8046/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=81
Feb  7 10:44:17.942: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 100
Feb  7 10:44:17.946: //81/E128E41B8046/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 07 Feb 2023 17:44:17 GMT
CSeq: 32691 INVITE
Content-Length: 0
Sent:
VOIP#SIP/2.0 180 Ringing
To: sip:15204792896@64.119.40.170:60234;transport=udp;tag=1DE404-1B19
CSeq: 32691 INVITE
Contact: <sip:15204792896@10.169.197.102:5060>
Content-Length: 0
VOIP#
Feb  7 10:44:19.830: //82/E128E41B8046/CCAPI/cc_api_call_connected:
   Interface=0x69316158, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
Feb  7 10:44:19.834: //81/E128E41B8046/CCAPI/ccConferenceCreate:
   (confID=0x696277F0, callID1=0x51, gcid=E12A1D04-A64511ED-80499558-EE629EF9, tag=0x0)
Feb  7 10:44:19.834: //82/E128E41B8046/CCAPI/ccConferenceCreate:
   (confID=0x696277F0, callID2=0x52, gcid=E12A1D04-A64511ED-80499558-EE629EF9, tag=0x0)
   Conference Id=0x696277F0, Call Id1=81, Call Id2=82, Tag=0x0
Feb  7 10:44:19.838: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  7 10:44:19.838: cc_api_get_xcode_stream : 4702
Feb  7 10:44:19.838: //81/E128E41B8046/CCAPI/cc_api_bridge_done:
   Conference Id=0x7, Source Interface=0x67F277FC, Source Call Id=81,
   Destination Call Id=82, Disposition=0x0, Tag=0x0
Feb  7 10:44:19.842: //82/E128E41B8046/CCAPI/cc_api_bridge_done:
   Conference Id=0x7, Source Interface=0x69316158, Source Call Id=82,
   Destination Call Id=81, Disposition=0x0, Tag=0xFFFFFFFF
Feb  7 10:44:19.842: //81/E128E41B8046/CCAPI/cc_generic_bridge_done:
Feb  7 10:44:19.842: //81/E128E41B8046/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x7, Destination Call Id=82)
Feb  7 10:44:19.842: //82/E128E41B8046/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x7, Destination Call Id=81)
Feb  7 10:44:19.842: //82/E128E41B8046/CCAPI/cc_api_caps_ind:
   Destination Interface=0x67F277FC, Destination Call Id=81, Source Call Id=82,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x0, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb  7 10:44:19.842: //81/E128E41B8046/CCAPI/cc_api_caps_ind:
   Destination Interface=0x69316158, Destination Call Id=82, Source Call Id=81,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Feb  7 10:44:19.842: //81/E128E41B8046/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=2)
Feb  7 10:44:19.846: //82/E128E41B8046/CCAPI/cc_api_caps_ack:
Feb  7 10:44:19.846: //81/E128E41B8046/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
Feb  7 10:44:19.850: //82/E128E41B8046/CCAPI/ccCallFeature:
Feb  7 10:44:19.850: //81/E128E41B8046/CCAPI/ccCallNotify:
Feb  7 10:44:19.854: //81/E128E41B8046/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x7, Call Id1=81, Call Id2=82
Feb  7 10:44:19.858: //82/E128E41B8046/CCAPI/cc_api_voice_mode_event:
   Call Id=82
   Call Entry(Context=0x69541FB4)
Feb  7 10:44:19.866: //81/E128E41B8046/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 32691 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 5784 4712 IN IP4 10.169.197.102
s=SIP Call
c=IN IP4 10.169.197.102
t=0 0
m=audio 16540 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Feb  7 10:44:20.059: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
VOIP#ACK sip:15204792896@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bKio9dc6000o9unt1vuiq0.1
CSeq: 32691 ACK
Content-Length: 0
Max-Forwards: 70
VOIP#
Feb  7 10:44:24.160: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:15204792896@10.169.197.102:5060 SIP/2.0
Via: SIP/2.0/UDP 173.244.45.246:5065;branch=z9hG4bKio9dc6000o9unt1vuiq0cd000u7q2.1
CSeq: 32692 BYE
Content-Length: 0
Supported: timer
Max-Forwards: 69
Feb  7 10:44:24.160: //82/E128E41B8046/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=82
Feb  7 10:44:24.164: //81/E128E41B8046/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x67F277FC, Call Id=81
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Feb  7 10:44:24.164: //81/E128E41B8046/CCAPI/ccConferenceDestroy:
   Conference Id=0x7, Tag=0x0
Feb  7 10:44:24.164: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  7 10:44:24.164: cc_api_get_xcode_stream : 4702
Feb  7 10:44:24.164: //82/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  7 10:44:24.168: cc_api_get_xcode_stream : 4702
Feb  7 10:44:24.168: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb  7 10:44:24.168: //81/E128E41B8046/CCAPI/cc_api_bridge_drop_done:
Feb  7 10:44:24.168: //82/E128E41B8046/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=81, Disposition=0x0, Tag=0x0
Feb  7 10:44:24.168: //81/E128E41B8046/CCAPI/cc_generic_bridge_done:
Feb  7 10:44:24.172: //81/E128E41B8046/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Feb  7 10:44:24.172: //82/E128E41B8046/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb  7 10:44:24.172: //82/E128E41B8046/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Feb  7 10:44:24.180: //82/E128E41B8046/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x69316158, Call Id=82
Feb  7 10:44:24.184: //81/E128E41B8046/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67F277FC, Tag=0x0, Call Id=81,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Feb  7 10:44:24.184: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  7 10:44:24.184: :cc_free_feature_vsa freeing 69484490
Feb  7 10:44:24.188:  vsacount in free is 1
Feb  7 10:44:24.200: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 07 Feb 2023 17:44:24 GMT
CSeq: 32692 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=208,OS=33280,PR=0,OR=0,PL=0,JI=0,LA=0,DU=4
Content-Length: 0
Feb  7 10:44:24.204: //82/E128E41B8046/CCAPI/cc_api_call_disconnect_done:
VOIP#Disposition=0, Interface=0x69316158, Tag=0x0, Call Id=82,
Feb  7 10:44:24.204: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  7 10:44:24.204: :cc_free_feature_vsa freeing 69484570
Feb  7 10:44:24.204:  vsacount in free is 0
SBjohnk
Great news, I've managed to get everything working except for RTP!
To get rid of the Diversion header my provider is sending me I ended up needing multiple translation-profiles and dial-peers, Maybe there's a better way to do this but this is what I came up with, it appears my sip-profile configuration only applies when the call is looped back into the router, Not sure why.
Incoming calls from my provider come in and hit Peer 30 with an incoming-number of 1.
Peer 30 translates the number from 11 digits inbound to a 10 digit number prefixed with ABCD
The call then is then sent to Peer 35 which has a destination pattern of ABCDT and it sends the traffic out to the external IP of the router.
Peer 36 receives the incoming calls with a incoming called-number of ABCDT and it uses a incoming transition profile to rewrite from the prefixed number to the extension it's destined from.
VOIP#show run
Building configuration...
Current configuration : 9794 bytes
! Last configuration change at 18:11:38 MST Tue Feb 7 2023 by johnk
! NVRAM config last updated at 18:11:52 MST Tue Feb 7 2023 by johnk
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname VOIP
boot-start-marker
boot system slot0:c2430-ik9o3s-mz.151-4.M10.bin
boot-end-marker
card type t1 1
logging buffered 4096
enable secret 5 $1$zwo8$nA2odUimH/BICmKTnI9rl.
enable password 7 121C0B16100709
aaa new-model
aaa session-id common
clock timezone MST -7 0
clock summer-time MDT recurring
network-clock-participate T1 1/0
network-clock-select 1 T1 1/0
ip source-route
no ip routing
no ip cef
ip domain name simplybits.net
ip name-server 8.8.8.8
no ip dhcp use vrf connected
ip dhcp pool PHONES
 network 192.168.100.0 255.255.255.0
 default-router 192.168.100.1
 option 150 ip 192.168.100.1
 dns-server 8.8.8.8
no ipv6 cef
voice hunt user-busy
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
 no ip address trusted authenticate
 allow-connections sip to sip
 redirect ip2ip
 sip
  registrar server expires max 1200 min 300
  sip-profiles 40
  no call service stop
voice class sip-profiles 40
voice class sip-hdr-passthrulist 1
voice class sip-copylist 1
voice register global
 mode cme
 max-dn 10
 max-pool 8
 load 7965 SCCP45.9-4-2SR3-1S
 authenticate register
 authenticate realm simplybits.net
 dialplan-pattern 1 1.. extension-length 3
 tftp-path slot0:
 file text
 create profile sync 0005026636280534
 ntp-server 17.253.16.125 mode unicast
 rule 1 /^1/ /ABCD\1/
 rule 1 /ABCD5204792894/ /101/
 rule 2 /ABCD5204792896/ /100/
 rule 3 /ABCD5202827081/ /201/
voice translation-rule 5
 rule 1 /^\([2-9]......$\)/ /1520\1/
 rule 2 /^\([2-9]..[2-9]......$\)/ /1\1/
 rule 3 /^9911/ /911/
voice translation-profile ALIANZA_TO_EXTENSION
 translate called 5
voice translation-profile ALIANZA_TO_LOOPBACK
 translate called 1
voice translation-profile FIX_OUTBOUND
voice translation-profile LOOPBACK_TO_EXTENSION
 translate called 2
voice translation-profile OUTBOUND_TO_ALIANZA
 translate called 20
voice-card 0
archive
 log config
  hidekeys
 path slot0:
 maximum 14
 write-memory
username johnk password 7 030752180500
username admin privilege 15 secret 5 $1$C4oN$vJsaf4xiVPK4CbEac31YR/
username itech privilege 15 secret 5 $1$T7UO$BzcKLoYxC.69TBSRQ.jqS.
controller T1 1/0
 channel-group 0 timeslots 1-24
ip ftp username ciscoftp
ip ftp password 7 0822455D0A49544541
ip ssh version 2
interface Loopback0
 no ip address
interface FastEthernet0/0
 ip address dhcp
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.100.1 255.255.255.0
 no ip route-cache
 duplex auto
 speed auto
 ntp broadcast
interface Serial1/0:0
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path slot0:cme-gui-8.6.0
logging source-interface Loopback0
tftp-server flash:apps45.9-4-2ES26.sbn
tftp-server flash:cnu45.9-4-2ES26.sbn
tftp-server flash:cvm45sccp.9-4-2ES26.sbn
tftp-server flash:dsp45.9-4-2ES26.sbn
tftp-server flash:jar45sccp.9-4-2ES26.sbn
tftp-server flash:SCCP45.9-4-2SR3-1S.loads
tftp-server flash:term65.default.loads
tftp-server flash:B016-1-0-4-2.SBN
tftp-server flash:music-on-hold.au
tftp-server flash:term45.default.loads
tftp-server flash:SCCP45.9-2-1S.loads
tftp-server flash:jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp45.9-2-1TH1-13.sbn
tftp-server flash:cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:cnu45.9-2-1TH1-13.sbn
tftp-server flash:apps45.9-2-1TH1-13.sbn
control-plane
voice-port 2/0
 no supervisory disconnect lcfo
 no battery-reversal
voice-port 2/1
 no battery-reversal
 caller-id enable
voice-port 2/2
 no battery-reversal
voice-port 2/3
 no battery-reversal
voice-port 2/4
 no battery-reversal
voice-port 2/5
 no battery-reversal
voice-port 2/6
 no battery-reversal
voice-port 2/7
 no battery-reversal
voice-port 2/8
 no battery-reversal
voice-port 2/9
 no battery-reversal
voice-port 2/10
 no battery-reversal
voice-port 2/11
 no battery-reversal
voice-port 2/12
 no battery-reversal
voice-port 2/13
 no battery-reversal
voice-port 2/14
 no battery-reversal
voice-port 2/15
 no battery-reversal
mgcp profile default
dial-peer voice 200 pots
 destination-pattern 200
 port 2/0
 no sip-register
dial-peer voice 201 pots
 destination-pattern 201
 port 2/1
 no sip-register
dial-peer voice 202 pots
 destination-pattern 202
 port 2/2
 no sip-register
dial-peer voice 203 pots
 destination-pattern 203
 port 2/3
 no sip-register
dial-peer voice 204 pots
 destination-pattern 204
 port 2/4
 no sip-register
dial-peer voice 205 pots
 destination-pattern 205
 port 2/5
 no sip-register
 translation-profile outgoing OUTBOUND_TO_ALIANZA
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
 description Incoming calls from Alianza
 translation-profile incoming ALIANZA_TO_LOOPBACK
 incoming called-number 1.
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 35 voip
 description Loopback-Outgoing
 destination-pattern ABCDT
 session target ipv4:10.169.197.102
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 36 voip
 description Loopback-Incoming
 translation-profile incoming LOOPBACK_TO_EXTENSION
 incoming called-number ABCDT
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
gateway
 timer receive-rtp 1200
sip-ua
 credentials username ciscoiad1 password 7 15100F5855737A252A61 realm all
 credentials username ciscoiad1 password 7 15100F5855737A252A61 realm siptrunk.p2.alianza.com
 authentication username ciscoiad1 password 7 04590F525E781D4F0B4B
 no remote-party-id
 registrar dns:siptrunk.p2.alianza.com:5065 expires 3600
 sip-server dns:siptrunk.p2.alianza.com:5065
telephony-service
 no auto-reg-ephone
 max-ephones 30
 max-dn 150
 ip source-address 192.168.100.1 port 2000
 timeouts interdigit 2
 cnf-file perphone
 max-conferences 4 gain -6
 call-park system application
 call-forward pattern .T
 moh flash:music-on-hold.au
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
ephone-dn  10
 number 100
 label x100
 allow watch
ephone-dn  11
 number 101
 label x101
 allow watch
ephone  1
 device-security-mode none
 mac-address C025.5C43.0CDD
 type 7965
 button  1:10
ephone  2
 mac-address 2893.FE13.4C0A
 type 7965
 button  1:11
line con 0
line aux 0
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 transport input all
ntp master
ntp peer time.apple.com
end
Great Job! That's awesome. Remember that you are dealing with all this complexity because your IOS version does not support some of the most useful features such as inbound sip profiles, e164 pattern maps, uri based routing and etc. It is ok in a lab environment but if it was a prod environment I would suggest upgrading to 17.6.4 and using my first template to configure your gateway.
Anyways, to get the RTP working I would suggest the below changes based on the logs you shared earlier.
Remove the From, Via, and Contact fields from sip-profiles 40 as shown here.
Apply sip-profiles 40 to dial peer 40 as shown here.
Apply sip-profiles 40 to dial peer 30 as shown here.
re-add sip-profiles 1 to you configs and apply it to dial-peer 35.
Hope this helps.
