Dialpeer not matching
Xiang Qing Mai
I have two CUCM servers,one Publisher and one subscriber.
Pub+Sub--->VG--->PSTN
when two CUCMs are working,and all ip phone were are registered to Publisher,I can make a call from the voice gateway and matched destination-pattern 96T, but when i disconnect Publisher,all ip phone are registered to Subscriber,when i made the same call from the voice gateway again,it doesn't match destination-pattern 96T.
Calling number:674    Called number:96008615989015194
I don't know why,can somebody figure it out?
As per the debugs shared, I can see below
Working Call :-
Incoming Dial-peer selected is 0     [Default DP]
Outgoing Dial-peer selected is 100 [Pots]
Faulty DP call :-
Outgoing Dial-peer selected is 20217
Try to make the changes in VOIP DPs or create new one for incoming called-number .  or 9T , to make sure that default Dial-Peer 0 is not selected.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Thanks Abhay,i will try it.
Best Regards,
Mai
Rajan
Hi Xiang,
As pointed by Abhay, the failed scenario is matching Outgoing Dial-peer 20217. 20XXX dial-peers are usually the virtual dial-peers created for sccp phones by CME/SRST. Can you also provide us the output of "show dial-peer voice summary" when the call is failing and hitting this dial-peer to see where this is routed.
Rajan
Pls rate all useful posts
