IP Phone 7937 can we give audio input connection from laptop
If I want to extend the audio output of my laptop can I connect audio output signal of laptop to Cisco IP phone 7937 to its Audio Auxiliary Port"
6 Replies 6
Jitender Bhandari
Hi Manoj
Admin Guide says below
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/7937g/6_0/english/administration/guide/37adm60.pdf
Audio Auxiliary Port The side of the conference station includes this port: • Audio auxiliary port—Labeled with stenciled audio input/output symbol The audio auxiliary port is on the right side of the conference station under a flap you flip open. Use the audio serial port to facilitate full-duplex connections to an optional mobile conference station device. You must use a straight-through cable on this port. Figure 3-4 shows how to connect the optional device to the conference station.
So you should be, but as far as i know Cisco by default does not provide any such cable.
(Rate if it helps)
JB
Thanks for the reply, may I know the specifications of the cable for purchasing the port looks smaller than 3.5mm. Please suggest
That sounds correct
JB
Please let me know the specifications of the socket.
Is below is what you are looking for.
http://www.polycom.com/products-services/voice/accessories/computer-calling-kit.html
JB
Hi Manoj,
Did above link help, you can update the forum if it does, so that it would be helpful to someone in future.
JB
