DID to SIP
sameermunj
Level 7
Level 7
HEllo ,
As local Telco, going to upgrade voice technology from DiD to SIP..what the changes to be done in the existing configuration
We are using 1 E1 PRI currently on Cisco2921 voice gateway
5 Replies 5
R0g22
Jaime Valencia
Not sure why you mention "from DID to SIP"one is a phone service/feature and the other is a protocol.
You can have DIDs in SIP
java
if this helps, please rate
Hello Jaime,
WE are going to change from E1 PRI to SIP trunk ..currently using cisco Voice gateway ..is there any document that we can refer for SIP trunk configuration
Hi Sameer
This document will give you little insight about CUBE (ip-ip gw) and how to set it up.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_fund/configuration/xe-3s/cube-fund-xe-3s-book/voi-cube-overview.html
You can check the interop guides from the link that I added initially and see if it covers your ISP. They are usually comprehensive.
