ā10-16-2011 11:23 PM - edited ā03-16-2019 07:32 AM
Dear Friends
We are using cucm 6.0 in our organization, the cluster contais one PUB and two SUB's, we are thinking of upgrading the CUCM 6.0 to 8.0, request you to please tell me the major differneces between both the versions.
Muhammad Aamir
ā10-17-2011 12:52 AM
hi
Check the following link..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/install.html
this link has the new and changed information of version 8 call manager. As you know Cisco is adding more and more features with every release so if call manager 6.0 is not enough for your enterprise then you can very well upgrade to 8.0 . Remember you will need software feature license for version 8 and also check the H/W compatibilty matrix, S/W compatibility matrix for the upgrade path and server support.
Also see if other comuunity members can explicitly list the differences.
Tapan
ā10-17-2011 06:02 AM
Major features are here:
Detailed explanation and all features can be reviewed in RNs or the same docs previously posted.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
