Digit Manipulation for two sip trunks
sofoszotos
Hello all and thank you for your help in advance.
Im trying to setup two sip trunks one a callmanager/gwy solution and ive been having some issues with translation profiles not working for some reason. To dial the first provider you use 9 and the second you use 8.
Also one sip provider requires registration the other one doesnt.
Furthermore into the problem one sip provider sends a caller ID with +1 hence the second voice translation-rule 2.
First post by the way!!
**1's are used to cover the numbers.
voice translation-rule 1
rule 1 /^9\(.*\)/ /\1/
rule 2 /^8\(.*\)/ /\1/
rule 1 /^.131011111\(..\)$/ /11\1/
voice translation-profile incoming
translate called 2
voice translation-profile outani
translate called 1
dial-peer voice 100 voip
description **Default incoming dial-peer SIP trunk 1**
translation-profile incoming incoming
destination-pattern .T
session protocol sipv2
session target dns:provider1
voice-class codec 1
dtmf-relay sip-notify rtp-nte
no vad
dial-peer voice 101 voip
description **Default incoming dial-peer SIP trunk 2**
session target ipv4:provider2
voice-class codec 1
no vad
dial-peer voice 200 voip
description **Outgoing calls to SIP trunk 1**
translation-profile outgoing outani
destination-pattern 9T
session transport tcp
voice-class codec 1
no vad
dial-peer voice 201 voip
description **Outgoing calls to SIP trunk 2**
destination-pattern 8T
voice-class codec 1
no vad
dial-peer voice 300 voip
description ** To and From CUCM**
destination-pattern ....
session target ipv4:10.xxxxx
voice-class codec 1
no vad
12 Replies 12
paolo bevilacqua
Yu can simpoly all that, e.g.
rule 1 /^,/ //
etc.
You mean rule 1 /^./  // ?
the voice translation works when i test it, however when i put it into the dialpeer it doesnt seem to work.
You can check with "debug ccsip message" and "term mon"
piyujain
Can you make some test calls (inbound and outbound) and share debugs;
debug voice ccapi inout
debug voice translation
debug ccsip all
Cheers !!
Piyush
Ill simplify this:
How can i setup a dial peer that removes +1 from an incoming sip trunk? The main issue is that the sip provider is giving me +1 for called and calling numbers.
Thanks again.
With translation-profile on the incoming DP.
Does this one make sense?
rule 4 /^.1310xxxxx\(..\)$/ /xx\1/
translate called 1
description **Default incoming dial-peer**
session target ipv4:208.xx.xx.xx
incoming called-number .T
voice-class codec 1
no vad
So far its not working. im going to post some debugs soon too. Problem is when i do debug inout cpu gets to 100% :/
oh well thanks.
See debugging below please. On the side of the provider they said that they receive on the SIP header the four digit number and not the full number as they are suppose to. So translation-profiles work but something else is happening wrong!
Thank you guys.
Sep 10 12:43:59.178: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended
Sep 10 19:44:01.878: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+1310xxxx@10.10.10.2:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 208xxxxx:5060;branch=z9hGxxxxxxx5a473c043209a2
To: <310XXXX>
Call-ID: 51xxxx531_127512643@208xxxxx
CSeq: 1963277240 INVITE
Max-Forwards: 70
Allow: INVITE,ACK,CANCEL,BYE,REGISTER,REFER,INFO,SUBSCRIBE,NOTIFY,PRACK,UPDATE,OPTIONS,MESSAGE,PUBLISH
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay,  multipart/mixed
Contact: "ZOTOS SOFOKLIS " <>
P-Preferred-Identity: "ZOTOS SOFOKLIS " <>
Supported: timer,100rel,precondition
Session-Expires: 1800
Min-SE: 90
Content-Length:   244
Content-Disposition: session; handling=required
Content-Type: application/sdp
v=0
o=Sonus_UAC 32xxx22155 2xxx58453 IN IP4 208xxxx
s=SIP Media Capabilities
c=IN IP4 208xxxx
t=0 0
m=audio 51996 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Sep 10 19:44:01.878: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=+1310xxxxxx Called Number=+1310xxxxx, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=+1310xxxxx
   Result=Success(0) after DP_MATCH_DEST
Sep 10 19:44:01.878: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=+1310xxxxx, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep 10 19:44:01.878: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=200
Sep 10 19:44:01.882: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=+1562xxxxx, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=200
Sep 10 19:44:01.882: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Sep 10 19:44:01.882: //-1/2D605F1EA49E/DPM/dpAssociateIncomingPeerCore:
   Calling Number=+1562xxxxx, Called Number=+1310xxxx, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=100
Sep 10 19:44:01.882: //-1/2D605F1EA49E/DPM/dpMatchSafModulePlugin:
Sep 10 19:44:01.886: //9403/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
Sep 10 19:44:01.886: //-1/2D605F1EA49E/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=+1562xxxxx
   ----- ccCallInfo IE subfields -----
   cisco-ani=+1562xxxxx
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=+1310xxxxxx
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Sep 10 19:44:01.886: //-1/2D605F1EA49E/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4AFAFDC8, Call Info(
   Calling Number=+1562xxxxxx,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=+1310xxxxx(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=9403
Sep 10 19:44:01.886: //-1/2D605F1EA49E/CCAPI/ccCheckClipClir:
   In: Calling Number=+1562xxxxxx(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=+1562xxxxxx(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Sep 10 19:44:01.886: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 19:44:01.886: :cc_get_feature_vsa malloc success
Sep 10 19:44:01.886:  cc_get_feature_vsa count is 5
Sep 10 19:44:01.886: :FEATURE_VSA attributes are: feature_name:0,feature_time:1216805616,feature_id:2791
Sep 10 19:44:01.886: //9403/2D605F1EA49E/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=+1562xxxxx(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=+1310xxxxx(TON=Unknown, NPI=Unknown))
Sep 10 19:44:01.890: //-1/2D605F1EA49E/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4D25AFF8; count=1
Sep 10 19:44:01.890: //-1/2D605F1EA49E/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4D8A8A00
Sep 10 19:44:01.890: //9403/2D605F1EA49E/CCAPI/cc_process_call_setup_ind:
   Event=0x4BC309E0
Sep 10 19:44:01.890: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number +1310xxxxx
Sep 10 19:44:01.890: //9403/2D605F1EA49E/CCAPI/ccCaxllSetContext:
   Context=0x4D857B90
   >>>>CCAPI handed cid 9403 with tag 100 to app "_ManagedAppProcess_Default"
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4D25AFF8; count=1
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: number=+1562xxxxx type=unknown plan=unknown numbertype=calling
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: No match: number=+1562xxxx type=unknown plan=unknown
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: number=+1310xxxxx type=unknown plan=unknown numbertype=called
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1310xxxxxxx rule precedence=1
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1310xxxxxxx rule precedence=2
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1310xxxxxxxx rule precedence=3
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_match_internal: Matched with rule 4 in ruleset 1
rule precedence=2
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1310xxxxxx\ rule precedence=3
rule precedence=3
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/sed_subst: Successful substitution; pattern=+1310xxxxx matchPattern=^.1310xxxxx(..)$ replacePattern=12\1 replaced pattern=1254
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
Sep 10 19:44:01.894: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: xlt_number=1254 xlt_type=unknown xlt_plan=unknown
Sep 10 19:44:01.894: //9403/2D605F1EA49E/CCAPI/ccCallProceeding:
Sep 10 19:44:01.894: //-1/2D605F1EA49E/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1254, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1254
Sep 10 19:44:01.894: //-1/2D605F1EA49E/DPM/dpMatchSafModulePlugin:
   dialstring=1254, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Sep 10 19:44:01.894: //-1/2D605F1EA49E/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=303
     2: Dial-peer Tag=200
   Result=SUCCESS(0)
Sep 10 19:44:01.894: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=1254, Called Number=1254, Peer Info Type=DIALPEER_INFO_SPEECH
Sep 10 19:44:01.894: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 10 19:44:01.894: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Sep 10 19:44:01.894: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1254, Called Number=, Voice-Interface=0x0,
Sep 10 19:44:01.898: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=303
Sep 10 19:44:01.898: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sep 10 19:44:01.898: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Sep 10 19:44:01.898: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Sep 10 19:44:01.898: //-1/2D605F1EA49E/DPM/dpMatchPeersCore:
Sep 10 19:44:01.898: //-1/2D605F1EA49E/DPM/dpMatchSafModulePlugin:
   dialstring=1254, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Sep 10 19:44:01.898: //-1/2D605F1EA49E/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Sep 10 19:44:01.898: //-1/2D605F1EA49E/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4D25AFF8; count=2
Sep 10 19:44:01.898: //-1/2D605F1EA49E/RXRULE/regxrule_dp_translate: No profile found in peer 303 for outgoing direction
Sep 10 19:44:01.898: //-1/2D605F1EA49E/RXRULE/regxrule_dp_translate: calling_number=+1562xxxxxxx
calling_octet=0x0
called_number=1254 called_octet=0x0
redirect_number= redirect_type=0 redirect_plan=0          redirect_PI=-1 redirect_SI=-1
Sep 10 19:44:01.898: //9403/2D605F1EA49E/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=303, Params=0x4D85CA80, Progress Indication=NULL(0)
Sep 10 19:44:01.898: //9403/2D605F1EA49E/CCAPI/ccCheckClipClir:
   In: Calling Number=+1562xxxxxxxTON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=12.., Called Number=1254, Digit Strip=FALSE
   Calling Number=+1562xxxxxxxxx(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1254(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=ZOTOS SOFOKLIS
   Account Number=+1562xxxxxxxx, Final Destination Flag=TRUE,
   Guid=2D605F1E-1988-11E3-A49E-DCD9AA2F00AA, Outgoing Dial-peer=303
Sep 10 19:44:01.898: //9403/2D605F1EA49E/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=+1562xxxxxxxxx
   cisco-ani=+1562xxxxxxx
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1254
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep 10 19:44:01.902: //9403/2D605F1EA49E/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4AFAFDC8, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=+1562xxxxxxx,(Calling Name=ZOTOS SOFOKLIS )(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1254(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=303, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sep 10 19:44:01.902: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 19:44:01.902: :cc_get_feature_vsa malloc success
Sep 10 19:44:01.902:  cc_get_feature_vsa count is 6
Sep 10 19:44:01.902: :FEATURE_VSA attributes are: feature_name:0,feature_time:1216802256,feature_id:2792
Sep 10 19:44:01.902: //9404/2D605F1EA49E/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Sep 10 19:44:01.902: //9404/2D605F1EA49E/CCAPI/ccCallSetContext:
   Context=0x4D85CA30
Sep 10 19:44:01.902: //9403/2D605F1EA49E/CCAPI/ccSaveDialpeerTag:
Sep 10 19:44:01.906: //-1/2D605F1EA49E/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4D25AFF8; count=2
Sep 10 19:44:01.906: //-1/2D605F1EA49E/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4D8AF0E8
Sep 10 19:44:01.906: //-1/2D605F1EA49E/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4D25AFF8; count=2
Sep 10 19:44:01.906: //9404/2D605F1EA49E/CCAPI/cc_api_call_proceeding:
   Interface=0x4AFAFDC8, Progress Indication=NULL(0)
Sep 10 19:44:01.910: //9403/2D605F1EA49E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 208xxxxxxx
:5060;branch=z9hG4bK0cBba5a473c043209a2
To: <310XXXXXX>
Date: Tue, 10 Sep 2013 19:44:01 GMT
Call-ID: 51164531_127512643@208xxxxxxxxx
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sep 10 19:44:01.910: //9404/2D605F1EA49E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1254@10.10.10.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.10.2:5060;branch=z9hG4bK2FA214FD
Remote-Party-ID: "ZOTOS SOFOKLIS " <>;party=calling;screen=no;privacy=off
To: <1254>
Call-ID: 2D64A4CE-198811E3-A4A4DCD9-AA2F00AA@10.10.10.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0761290526-0428347875-2761874649-2855207082
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1378842241
Contact: <>
Call-Info: <10.10.10.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 7250 1959 IN IP4 10.10.10.2
s=SIP Call
c=IN IP4 10.10.10.2
t=0 0
m=audio 16486 RTP/AVP 0 101
c=IN IP4 10.10.10.2
a=fmtp:101 0-15
a=ptime:20
Sep 10 19:44:01.914: //9404/2D605F1EA49E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 422 Session Timer too small
From: "ZOTOS SOFOKLIS " <>xxxxxxx@10.10.10.2>;tag=393017F0-1819
Allow-Events: presence
Min-SE:  18000
Content-Length: 0
To: <1254>;tag=976977456
CSeq: 101 INVITE
Sep 10 19:44:01.914: //9404/2D605F1EA49E/CCAPI/cc_api_call_disconnected:
   Cause Value=127, Interface=0x4AFAFDC8, Call Id=9404
   Call Entry(Responsed=TRUE, Cause Value=127, Retry Count=0)
Sep 10 19:44:01.914: //9403/2D605F1EA49E/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Sep 10 19:44:01.914: //9404/2D605F1EA49E/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=9404
Sep 10 19:44:01.914: //9404/2D605F1EA49E/CCAPI/ccCallDisconnect:
   Cause Value=127, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=127)
   Cause Value=127, Call Entry(Responsed=TRUE, Cause Value=127)
Sep 10 12:44:01.918: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 2D605F1E198811E3A49EDCD9AA2F00AA, SetupTime 12:44:01.898 PDT Tue Sep 10 2013, PeerAddress 1254, PeerSubAddress , DisconnectCause 7F  , DisconnectText interworking (127), ConnectTime 12:44:01.918 PDT Tue Sep 10 2013, DisconnectTime 12:44:01.918 PDT Tue Sep 10 2013, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Sep 10 19:44:01.918: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
Sep 10 19:44:01.918: :Inside cc_build_feature_vsa
Sep 10 19:44:01.918:  feature call basic
Sep 10 19:44:01.918: cc_build_feature_vsa attr is fn:TWC,ft:09/10/2013 12:44:01.902,cgn:+1562xxxxxxxx,cdn:1254,frs:0,fid:2792,fcid:2D605F1E198811E3A49EDCD9AA2F00AA,legID:24BC
Sep 10 12:44:01.918: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:09/10/2013 12:44:01.902,cgn:+1562xxxxxxxx,cdn:1254,frs:0,fid:2792,fcid:2D605F1E198811E3A49EDCD9AA2F00AA,legID:24BC,bguid:2D605F1E198811E3A49EDCD9AA2F00AA
Sep 10 19:44:01.918: //9404/2D605F1EA49E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4AFAFDC8, Tag=0x0, Call Id=9404,
   Call Entry(Disconnect Cause=127, Voice Class Cause Code=0, Retry Count=0)
Sep 10 19:44:01.918: //-1/2D605F1EA49E/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
   Call Disconnect Event Sent
Sep 10 19:44:01.918: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 10 19:44:01.918: :cc_free_feature_vsa freeing 4886EDC8
Sep 10 19:44:01.918:  vsacount in free is 5
Sep 10 19:44:01.918: //9404/2D605F1EA49E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4C09E2E0
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : +1562xxxxxx
Called Number            : 1254
Source IP Address (Sig  ): 10.10.10.2
Destn SIP Req Addr:Port  : 10.10.10.10:5060
Destn SIP Resp Addr:Port : 10.10.10.10:5060
Destination Name         : 10.10.10.10
Sep 10 19:44:01.918: //9404/2D605F1EA49E/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.10.10.2
Source IP Port    (Media): 16486
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 127
Disconnect Cause (SIP)   : 422
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4D25AFF8; count=3
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: number=+1562xxxxxx type=unknown plan=unknown numbertype=calling
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1562xxxxxxx rule precedence=1
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1562xxxxxxx rule precedence=2
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1562xxxxxxx rule precedence=3
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_match: No match; number=+1562xxxxxxx rule precedence=4
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_match_internal: No match found
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: No match: number=+1562xxxxxxxx type=unknown plan=unknown
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: number=1254 type=unknown plan=unknown numbertype=called
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: No match: number=1254 type=unknown plan=unknown
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-target number not found
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Sep 10 19:44:01.922: //-1/2D605F1EA49E/RXRULE/regxrule_dp_translate: calling_number=+1562xxxxxx calling_octet=0x0
Sep 10 19:44:01.922: //9403/2D605F1EA49E/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=200, Params=0x489F5F9C, Progress Indication=NULL(0)
Sep 10 19:44:01.922: //9403/2D605F1EA49E/CCAPI/ccCheckClipClir:
   In: Calling Number=+1562xxxxx(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=.T, Called Number=1254, Digit Strip=FALSE
   Calling Number=+1562xxxxxxx(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Account Number=+1562xxxxxx, Final Destination Flag=TRUE,
   Guid=2D605F1E-1988-11E3-A49E-DCD9AA2F00AA, Outgoing Dial-peer=200
Sep 10 19:44:01.922: //9403/2D605F1EA49E/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1254
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep 10 19:44:01.922: //9403/2D605F1EA49E/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=+1562xxxxxx,(Calling Name=ZOTOS SOFOKLIS )(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=200, Call Count On=FALSE,
Sep 10 19:44:01.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 19:44:01.922: :cc_get_feature_vsa malloc success
Sep 10 19:44:01.922:  cc_get_feature_vsa count is 6
Sep 10 19:44:01.926: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 19:44:01.926: :FEATURE_VSA attributes are: feature_name:0,feature_time:1216802256,feature_id:2793
Sep 10 19:44:01.926: //9405/2D605F1EA49E/CCAPI/ccIFCallSetupRequestPrivate:
Sep 10 19:44:01.926: //9405/2D605F1EA49E/CCAPI/ccCallSetContext:
   Context=0x489F5F4C
Sep 10 19:44:01.926: //9403/2D605F1EA49E/CCAPI/ccSaveDialpeerTag:
Sep 10 19:44:01.926: //-1/2D605F1EA49E/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4D25AFF8; count=3
Sep 10 19:44:02.022: //9403/2D605F1EA49E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Port    (Media): 17216
Destn  IP Address (Media): 208xxxxxxx
Destn  IP Port    (Media): 51996
Sep 10 19:44:02.022: //9403/2D605F1EA49E/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 28
Disconnect Cause (SIP)   : 484
Your translation rule to stip "+" and convert number to 4 digit is absolutely fine..
rule 1 /^.131011111\(..\)$/ /12\1/
translate called 2
As per the debugs, it is working as you are expecting..
Your call is hitting incoming dial-peer 100, called party number +1310xxxx translates to 1254 and GW sends the call to CUCM (10.10.10.10)
Sent:
To: <1254>
Min-SE:  1800
CSeq: 101 INVITE
Contact: <>
Expires: 180
Max-Forwards: 69
Content-Length: 241
but CUCM replies with 422 Error due to small Session Expire timer value. CUCM expects this value to be 18000 whereas GW is sending it 1800.
Received:
Min-SE:  18000
Content-Length: 0
CSeq: 101 INVITE
You can fix it either on CUCM or on GW..
To fix it on CUCM, you need to change Min-SE timer to 1800..
To configure CUCM to have a Minimum Session Expires time = 1800:
1. Log in to CUCM.
2. Go to
System > Service Parameters
3. Select
Server
= current server e.g. " (Active)".
4. Select
Service
= Cisco CallManager (Active).
5. Search for
SIP Min-SE Value
and set it to 1800.
Or increase this value to 18000 on GW as below:
Router(config)# voice service voip
Router(conf-voi-serv)# sip
Router(conf-serv-sip)# min-se time
Cheers !!
Piyush
Rate if this helps you..
Thank you for your reply i just changed the SE Timer on the gwy.
I just did some more debugging with the provider and they mentioned that i am sending them back the four digit number the 1254 but my outgoing dialpeer should take care of that and add back the whole 10 digit sequence.
The sip header is the one that has the four digits, however you can see from above that i think im sending the correct one
Any ideas on that?
1254 is the called number...your INVITE is sent to this number..this is not your calling number...your calling number is identified by your Remote-party-I'd header
Please rate all useful posts
Above logs are for incoming calls.. not for the outgoing calls..
Can you collect the debugs for outgoing calls to PSTN?
Also is your incoming call from PSTN to CUCM is working fine now ???
