Directed Call Park for outside callers hear ringing
jhindmarsh
I have directed call park numbers setup on a 9951 phone.  When an internal call gets parked on one of these directed park numbers, the caller hears MoH as expected.  When an external caller is parked, they hear "ringing" the whole duration they are parked, until the call is picked up.
Is this a setting somewhere on the gateway side where an incorrect alerting message is being sent?
Jesse
6 Replies 6
Aashish Jolly
  Is a Media Resource Group List assigned to the gateway include a Media Resource Group that includes the Moh Server ?
Anas Abueideh
Level 9
Level 9
kindly check your media resource group list assigned to the gateway and device pool
Anas
plese rate if is helpful
Karl Ludwig
I am having the same issue. The media resource group that is assigned to the gateway DOES include the Media Resource Group that includes the MoH server.
Anyone have any idea why else the external callers would here ringing?
Thanks.
Ellen Kennedy
I'm having the exact same issue.... I opened a TAC case and am just looking around on the Cisco forums until I hear back from them... Where you able to get this resolved?
Ellen-You need to set "Duplex Streaming Enabled" to true. This is under System-System Parameters-Call Manager.
Yesss! That was it... Thanks so much!.
and the TAC engineer had just called me back so he took note of the setting!
EK
