10-06-2017 01:02 AM - edited 03-17-2019 11:18 AM
Is there any way to get an email alert if DIRT fails for the CUCM.
I have seen suggestions using RTMT and know were to set email alerting for this, but does the RTMT generate an alert automatically when DIRT fails or does one have to configure something?
10-06-2017 04:52 AM
What are you using DIRT for on CUCM? DIRT was backup solution for legacy Unity.
Did you mean DRS perhaps? If, so yet RTMT alerts would be the way to go.
10-06-2017 06:38 AM
Yes of course. I meant DRS.
I will use the DRF master alert as trigger for email through RTMT.
