Music on hold not working on cucm
akram.root
Level 4
Level 4
Hello all,
I have installed cucm v11.5 , registered with ip phones 79XX , the problem is that the music on hold by default of the system (sample audio source) not working .
can you help me please
Best regards
Akram
8 Replies 8
Are you getting beeps or complete slicense.
During hold post the output of the command:
show perf query class "Cisco MOH Device"
Are you trying to use unitcast moh or multicast moh
Hi Mohammed al Baqar,
thank you for your answer,
when I'm waiting ( Music on hold), i can't hear anything
i will test this command and i came back to you.
Best regards
Akram
Hi Akram,
You can check the following link. it helped me a lot.
https://www.youtube.com/watch?v=j2GcYQBPThc
Alberto
Thank you orellanas for your reply
Hello Mohammed,
I did the command here is the result:
admin:show perf query class "Cisco MOH Device"
==>query class :
- Perf class (Cisco MOH Device) has instances and values:
MOH_2 -> MOHHighestActiveResources = 1
MOH_2 -> MOHMulticastResourceActive = 0
MOH_2 -> MOHMulticastResourceAvailable = 250000
MOH_2 -> MOHOutOfResources = 0
MOH_2 -> MOHTotalMulticastResources = 250000
MOH_2 -> MOHTotalUnicastResources = 250
MOH_2 -> MOHUnicastResourceActive = 0
MOH_2 -> MOHUnicastResourceAvailable = 250
MOH_4 -> MOHHighestActiveResources = 1
MOH_4 -> MOHMulticastResourceActive = 0
MOH_4 -> MOHMulticastResourceAvailable = 250000
MOH_4 -> MOHOutOfResources = 0
MOH_4 -> MOHTotalMulticastResources = 250000
MOH_4 -> MOHTotalUnicastResources = 250
MOH_4 -> MOHUnicastResourceActive = 1
MOH_4 -> MOHUnicastResourceAvailable = 249
Best regards
Akram
Hello Mohammed,
==>query class :
Best regards
Akram
here is a document that contains screenshots
Best regards
Akram
hello,
it worked fine on call interne but not working on call externe , can you help me pllease
Best regards
Akram
