disable auto dial from Missed Calls directory
nestor.gallego1
Hi Guys;
There a way to disable the auto dial feature from the missed calls directory? pick up the handset and the number will be automatically dialed.
Regards;
Jaime Valencia
AFAIK that cannot be disabled
java
if this helps, please rate
Jaime Valencia
java
