03-17-2016 12:43 PM - edited 03-17-2019 06:17 AM
Is there a way to disable the Ethernet to phone port on the back of the 7965 phones? I know you can use the port to act as a switch but we are looking into disable that port completely. Can it be done?
Solved! Go to Solution.
03-17-2016 12:53 PM
Yes, the way to do that depends on the call control to which they're registered, you need to provide that info when asking assistance.
03-17-2016 01:16 PM
Go to the device config and change:
Indicates whether the PC port on the phone is enabled or disabled. The port labeled "10/100 PC" on the back of the phone connects a PC or workstation to the phone so they can share a single network connection. | |
This is a required field. | |
Default: Enabled |
03-17-2016 12:53 PM
03-17-2016 01:13 PM
We use Cisco Unified Communications Manager.
03-17-2016 01:16 PM
Default: Enabled |
