Disable missed calls notification on SIP phones and CME 10.5?
nocjallen
After reading through CME documentation I see that it is possible to disable missed call notifications for SCCP phones. However, I am wondering if it is possible on SIP phones?
I am using Cisco 7861 IP Phones and CME 10.5 running on a Cisco 2901.
Any feedback would be helpful.
I second nocjallen, at the moment it is supported on SCCP phones on CME. SIP phones have limited feature sets for CME.
At the moment, there is not such feature for SIP phones on CME, We need to wait if it comes in CME 11.
~Amit
Mohammed Khan
Refer CME Feature Admin guide.
HTH,
Regard,
Mohammed Noor
To report missed calls to directory numbers on an IP phone, use the missed-calls command in ephone configuration mode. To suppress missed-calls reporting, use the no form of this command.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_m1ht.html#wp8771059930
This is the reference for suppressing missed calls, however it applies to ephones and not voice register pools. I am trying to find a solution that is supported on SIP phones and voice register pools.
~Amit
