Disable SIP SDP modification
mpla
Cisco C8000V. Cisco IOS XE Software, Version 17.06.05.
Trying to implement static PAT to translate SIP traffic between private and public voice gateways.
<172.17.20.36:3002>    <Cisco NAT 1.2.3.4>      <5.6.7.8:5060>
ip nat inside source static udp 172.17.20.36 3002 1.2.3.4 3002 extendable
But seeing SIP payload being modified after message processed by CISCO.
Received
User Datagram Protocol, Src Port: 5060, Dst Port: 3002
Session Initiation Protocol (200)
Status-Line: SIP/2.0 200 OK
Message Header
Via: SIP/2.0/UDP 1.2.3.4:3002;branch=z9hG4bK00B2699857923461da3
To: <sip:5.6.7.8>;tag=SDjpkq999-611519991-1713538972837
Call-ID: 131850216_1293583290@1.2.3.4
[Generated Call-ID: 131850216_1293583290@1.2.3.4]
CSeq: 180544 OPTIONS
Content-Length: 0
Sent
Message Header
Via: SIP/2.0/UDP 172.17.20.36:3002;branch=z9hG4bK00B2699857923461da3
Call-ID: 131850216_1293583290@172.17.20.36
[Generated Call-ID: 131850216_1293583290@172.17.20.36]
Content-Length: 0
Looking for a way to disable SIP payload modifications. Tried following but without difference:
no ip nat service sip udp port 3002
then
no ip nat service sip udp port 5060
then
no ip nat service all-algs
Using PAT or NAT would do this, so it is the expected result and also needed for call services to be operational as you cannot present the internal IP information to the external party as they wouldn’t know how to route the response traffic. You’ll also need to use a SIP profile to modify the required IP information in the SIP dialogue that isn’t modified by PAT/NAT.
Response Signature
Is there any mechanism to disable such modifications? Internal signaling gateway is capable to work behind NAT and doesn't expect changes in SIP payload.
Not using PAT or NAT, other than that nothing that I’m aware of.
Response Signature
