10-30-2012 09:08 AM - edited 03-16-2019 01:56 PM
How is it possible to disable the ABC Softkey on CUCM 8.6. I loaded already the newest dev-pack but there is also no possibilty to disable this key.
It has en impact for the rollout the 9.3.1 firmware.
greetings Phil
10-30-2012 09:37 AM
Where do you see that? What phone model, and which phone state (i.e. on-hook, etc)?
Chris
10-30-2012 09:52 AM
Hi Chris
This feature is new since 9.3.1.
When you enter a number for dialing you will see the softkey. At the moment we loaded 9.3.1 and 9.3.2 just on 89XX or 99XX phones.
In CUCM 9.0 with URI dialing is it a nice feature, if you need it, but you should have the possibility to disable it if not. And in CUCM8.6 it makes no sence to confuse poeple with a feature which is not available.
The user must press the ABC softkey to switch the input method to URI Dialing mode using the keypad.
thx Phil
10-30-2012 10:15 AM
Right now it's not possible, and I just found out about this new feature and also the associated bug.
I already see some cases coming our way about this
Workaround:
Downgrade the firmware to a 9.2(x) version, such as 9.2(4).
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-30-2012 10:47 AM
Thx
This workaround isn't one ;-) We have to upgrade to 9.3.1, because we have many problems in 9.2.x.
Also the speed of the frontend since 9.3.x is much better.
I see I have to go other ways to get a solution for us.
02-07-2014 11:05 AM
Ok, i'm resurrecting a dead thread from 2012 because it appears to be an issue with our current install.
CUCM 9.1.2.10000-28
9971 running FW sip9971.9-4-1-9 upgraded from sip9971.9-3-2SR1-1
I'm looking to disable the ABC/123 button and still cannot find where to do so. We're trying to eliminate extraneous features for the customer experience to minimize confusion in the transition.
Any assistance is greatly appreciated.
Matt
