Disaster Recovery System - CUCM 8.6.1
markah
I'm having trouble taking a backup of my CUCM cluster, I've tried using FreeSSHd and Titan FTP but I keep getting the following error message:
     Unable to contact server. Master or Local Agent could be down
I've tried restarting the services and also rebooted the servers but I'm still having the same issue.
Mark
Rob Huffman
Hi Mark,
It could be this bug;
CSCtq70900 - Tomcat and/or IPSEC Key store corruption causes DRF backup failures
Description
Symptom:
Unable to backup one or more nodes in a cluster
Conditions:
Corruption of tomcat or ipsec keystores
Workaround:
Special root-based commands to re-generate the certificates either on Pub or Sub(s)
(ie tomcat certs have to be generated on a per-Sub basis and
ipsec certs have to be generated on the Pub)
Details
1st Found-in:                          (1)
8.6(1.10000.40)
Status:
Fixed
Last Modified:
Oct 02,2011
Fixed-in:                          (10)
9.0(0.96000.16), 8.6(2.10000.30), 8.6(1.98000.80)
8.6(1.98000.36), 8.6(1.96000.16), 8.6(1.96000.157)
8.6(1.95180.3), 8.6(1.95050.1), 8.6(1.95020.80)
8.6(1.95020.1)
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
2 - severe
Customer Reported:                          (3)
Cheers!
Rob
8 Replies 8
markah
Sorry, I should add that this message is only reported against the subscriber, the publisher backs up fine.
Rob Huffman
Hi Mark,
Description
Symptom:
Conditions:
Workaround:
Details
1st Found-in:                          (1)
8.6(1.10000.40)
Status:
Fixed
Last Modified:
Oct 02,2011
Fixed-in:                          (10)
8.6(1.95020.1)
Product:
Platform:
Dependent
Severity:
2 - severe
Cheers!
Rob
Thanks for you help Rob,
I'll investigate next week and see if I can make any progress with this .
I'm not sure whether to raise a TAC case or try upgrading, although I don't think version 8.6(2a) is listed as fixing the issue.
Mark
Rob Huffman
Hi Mark,
I really think that opening a TAC case would be your best bet here
If this bug is what you are hitting then they can load up a proper "fixed-in"
version for special download for you.
Cheers!
Rob
Thanks Rob,
I've just got to wait until we have the support contract in place before I raise the TAC case.
I'll let you know the outcome.
Mark
Finally raised a case with Cisco TAC on this issue, they advised me on how to regenerate some of the ipsec certifcates on the servers but that didn't fix the problem.
I then noticed that the 'ipsec-trust' certificate on the Subscriber server disappeared and reappeared every couple of minutes.
TAC now want to investigate to see if the CSCtq70900 bug is causing the issue and require root access to the servers.
I'll update as soon as I have more info.
Mark
Rob,
You were correct about the bug causing the issues:
TAC have connected to the subsciber and resolved the issue (repaired the ipsec-trust keystore).
Thanks for your help on this
Mark.
Hi Guys, Looks like i am hitting this bug.. I tried to repair the ipsec trust certs and now have serial no's matching on all three nodes in the cluster but no change..continue to get get the message the local or Master DRF agent is down. Just curious to know if i upgrade the server to version where it is fixed in 8.6 will it fix the issue or i still need TAC to login with root and do the magic
