Disconnect cause=34 H.323 and FXO
Murali Dharan
Hello All,
We are having 8 FXO, inbound calls are working find but outbound calls are getting the busytone along with Disconnect cause=34. I found ISDN with H.323 doc for Disconnect cause=34 which saying no circuit available but im not getting doc for FXO with h323. Any assistance much appreciated.
Debug vpm signal:
001914: Aug  8 11:11:15.724 EDT: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
001915: Aug  8 11:11:15.724 EDT: [0/2/3] set signal state = 0xC timestamp = 0
001916: Aug  8 11:11:15.728 EDT: htsp_timer - 1300 msec
001917: Aug  8 11:11:15.980 EDT: htsp_process_event: [0/2/3, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_proc
001918: Aug  8 11:11:15.980 EDT: htsp_timer2 - 1000 msec
001919: Aug  8 11:11:15.980 EDT: htsp_timer_stop
001920: Aug  8 11:11:16.980 EDT: htsp_process_event: [0/2/3, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_timer2_proc
001921: Aug  8 11:11:16.980 EDT: htsp_timer_stop
001922: Aug  8 11:11:16.980 EDT: htsp_timer_stop2
001923: Aug  8 11:11:16.980 EDT: [0/2/3] set signal state = 0x4 timestamp = 0
001924: Aug  8 11:11:16.980 EDT: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Debug voice ccapi inout:
004468: Aug  8 11:34:43.205 EDT: //12849/00848F09E85D/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
004469: Aug  8 11:34:43.205 EDT: //12849/00848F09E85D/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34) 004468: Aug  8 11:34:43.205 EDT: //12849/00848F09E85D/CCAPI/ccCallDisconnect:
5 Replies 5
paolo bevilacqua
To what are you connecting?
that indicates router cannot detect loop current.
Thanks Paolo, Whether the problem with router or with carrier end?. All 8 FXOs are connect to carrier. We are receiving incoming calls via the same FXOs but out bound calls are dropping with cause code 34 in all the Fxos. Rebooted the router but no luck.
-Murali
Try updating IOS.
I worked with Carrier and they fixed the problem. Thanks Paolo.
You are welcome, please remember to rate useful posts clicking on the stars below.
