Display directory from the CUCM 8.6
Camélia
Hello Every one;
Any one has an idea about how to display directory ( name, first name and number ) from the CUCM 8.6.
Regards.
Jaime Valencia
If you mean you want to change the order in which the corporate directory shows the info, that's not possible, you need to build your own directory script for that.
java
if this helps, please rate
Hi Camelia,
you can do it with 3rd party product like http://aurus5.com/phoneup/directory
