Display Info for SRST mode on 69XX or 8961
mjuch
Level 5
Level 5
                   Hello, is there a possibility to give the 69XX or 8961 Phone a Display Info when the Phone is in SRST mode?
The system messages in voice register global and call-manager-fallback seems to be not supported for this Phonetypes.
br Michael Juch
Bruno Rangel
Looks like this is a limitation of 69XX,,found that in this thread
It's 69xx phone limitation. The display of toast message used by
69xx phone would take almost entire screen to display the system message and
then block all other existing display. It has been removed by design.
Also I found that the Phone 69XX should shows in the screen a SRST Notification  "Service interruption"
For the Phone 8961 look in this Display Survivable Remote Site Telephony Message
What the Firmware version are you using?
Please remember to rate helpful  responses and identify helpful or correct answers.
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Hello, i found the Answers.
With the last Firmware (8961  9.3.2,  69XX  9.3.1) it works.
Thank you for your Answers.
BR Michael Juch
Sound Good!!
Michael Please remember to rate helpful  responses and identify helpful or correct answers.
Renato Russo
Cheers
Bruno Rangel
