12-23-2010 01:30 AM - edited 03-16-2019 02:33 AM
Hi ,
I am using call manager 7 , all the phones when tey restart the defult for them is DND , i cant change it .
can help me
12-29-2010 06:38 PM
Hi Rami,
There is a bug in version 7 that does cause similar issues with DND automatically getting updated. What exact version of 7 have you got? Is it a base version or are you up to date with the ES patches for your version train?
I would suggest considering an upgrade to the latest version of the CUCM in the version 7 train.
I Hope this information helps.
Cheers,
Farbod
12-29-2010 10:26 PM
Thank you Farbod,
the current version is 7.1.5.10000-12 i will update it and try .
thank you again.
12-29-2010 11:11 PM
Hi Rami
I am really keen to know whether the suggested solution solved the problem.
Tohsheen
12-29-2010 11:13 PM
I have seen it in a couple of cases and the upgrade seems to be fixing it.
Cheers,
Farbod
12-29-2010 11:34 PM
Dears,
i will update my system today and tell you ,
