09-01-2015 09:47 PM - edited 03-17-2019 04:10 AM
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTING]
A Cisco DB Replicator[STARTING]
Cisco AMC Service[STARTING]
Cisco AXL Web Service[STARTING]
Cisco Audit Event Service[STARTING]
Cisco Bulk Provisioning Service[STARTING]
Cisco CAR DB[STARTING]
Cisco CAR Scheduler[STARTING]
Cisco CAR Web Service[STARTING]
Cisco CDP[STARTING]
Cisco CDP Agent[STARTING]
Cisco CDR Agent[STARTING]
Cisco CDR Repository Manager[STARTING]
Cisco CTIManager[STARTING]
Cisco CTL Provider[STARTING]
Cisco CallManager[STARTING]
Cisco CallManager Admin[STARTING]
Cisco CallManager Cisco IP Phone Services[STARTING]
Cisco CallManager Personal Directory[STARTING]
Cisco CallManager SNMP Service[STARTING]
Cisco CallManager Serviceability[STARTING]
Cisco CallManager Serviceability RTMT[STARTING]
Cisco Certificate Authority Proxy Function[STARTING]
Cisco Certificate Change Notification[STARTING]
Cisco Certificate Expiry Monitor[STARTING]
Cisco Change Credential Application[STARTING]
Cisco DHCP Monitor Service[STARTING]
Cisco DRF Local[STARTING]
Cisco DRF Master[STARTING]
Cisco Database Layer Monitor[STARTING]
Cisco Dialed Number Analyzer[STARTING]
Cisco Dialed Number Analyzer Server[STARTING]
Cisco DirSync[STARTING]
Cisco Extended Functions[STARTING]
Cisco Extension Mobility[STARTING]
Cisco Extension Mobility Application[STARTING]
Cisco IP Manager Assistant[STARTING]
Cisco IP Voice Media Streaming App[STARTING]
Cisco License Manager[STARTING]
Cisco Log Partition Monitoring Tool[STARTING]
Cisco Messaging Interface[STARTING]
Cisco RIS Data Collector[STARTING]
Cisco RTMT Reporter Servlet[STARTING]
Cisco SOAP - CDRonDemand Service[STARTING]
Cisco SOAP - CallRecord Service[STARTING]
Cisco Serviceability Reporter[STARTING]
Cisco Syslog Agent[STARTING]
Cisco TAPS Service[STARTING]
Cisco Tftp[STARTING]
Cisco Tomcat[STARTING]
Cisco Tomcat Stats Servlet[STARTING]
Cisco Trace Collection Service[STARTING]
Cisco Trace Collection Servlet[STARTING]
Cisco Trust Verification Service[STARTING]
Cisco UXL Web Service[STARTING]
Cisco Unified Mobile Voice Access Service[STARTING]
Cisco User Data Services[STARTING]
Cisco WebDialer Web Service[STARTING]
Host Resources Agent[STARTING]
MIB2 Agent[STARTING]
Platform SOAP Services[STARTING]
SNMP Master Agent[STARTING]
SOAP - Diagnostic Portal Database Service[STARTING]
SOAP -Log Collection APIs[STARTING]
SOAP -Performance Monitoring APIs[STARTING]
SOAP -Real-Time Service APIs[STARTING]
System Application Agent[STARTING]
Primary Node =true
09-01-2015 10:09 PM
You have got lot of services still starting. SSH comes up relatively faster than other services.
It may take 15-20 minutes for other services to come up. Whats the hardware you are using MCS or UCS?
If the services are still stuck in starting after a while - can you check your NTP status: utils ntp status
Did you do a clean reboot? Try accessing the console (KVM for MCS and ESXi for UCS) and see if there are any messages you see on console?
-Terry
Please rate all helpful posts
09-01-2015 11:13 PM
check ntp status, get a unsynchronised message (NPT Demon OK!)
this Publiser can not access NTP Server that was out of order
* Two Subscriber also unsychronised NTP Server (= Publiser)
- I tried to reboot or system reboot 3~4 time and wait a long time but other service also did't come up .
- hardware is UCS 210 M2
- don't get any strange message on console
09-07-2020 05:24 AM
I am also facing the similar issue, only difference is system was running and in production when we noticed a DB issue while trying to login into GUI.
That time only DB services were in Starting state and all attempts to Restart/Start them via CLI failed, so we went for a node reboot and post reboot we are in the similar issue as yours.
Diagnose says, "Service Manager is stuck trying to start database" and all services are stuck in Starting state only.
Did you find any solution to your problem?
Vishal
