08-24-2015 03:55 AM - edited 03-17-2019 04:05 AM
Hi.. i have come to know that CME does not support SIP INFO DTMF method. It supports only Notify and RTP-nte with SCCP phones.
CME currently supports this DTMF internetworking for SIP to SCCP calls:
* SCCP out-of-band-SIP Notify / RFC2833 since 12.4(4)T"
Can you pls confirm on this.
Solved! Go to Solution.
08-24-2015 04:18 AM
Currently CME supports this list of DTMF internetworking for SIP to SIP calls:
* Notify <---> Notify since 12.4(4)T
* RFC2833 <---> Notify since 12.4(4)T
* Notify <---> RFC2833 since 12.4(4)T
* Inband G711 <---> since 12.4(11)T [Requires Transcoder]
CME currently supports this list of DTMF internetworking for SIP to SIP calls:
There is DDTS enhancement opened for the same
https://tools.cisco.com/bugsearch/bug/CSCse50733/?reffering_site=dumpcr
Br,
Nadeem
08-24-2015 04:18 AM
Br,
Nadeem
08-24-2015 04:34 AM
The SIP INFO Method for DTMF Tone Generation feature is always enabled, and is invoked when a SIP INFO message is received with DTMF relay content. This feature is related to the SIP NOTIFY-Basec Out-of-Band DTMF Relay Support feature, which provides the ability for an application to be notified about DTMF events using SIP NOTIFY messages. Together, the two features provide a mechanism to both send and receive DTMF digits along the signaling path.
