Does shoretel ip phone support CUCM using SIP
nikesh.boppana
hi
can anybody pls tell me, does shoretel ip phone support CUCM using SIP.
Hi Nikesh,
CUCM support SIP V2.0, If Shortel follow the SIP V2.0 standard it should work. Just remember Cisco will not give you support with this kind of phone.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
hai leosalcie,
Thanks for your support. the problem is shoretel only support ftp, cisco only support tftp as per my understanding. shoretel keep on tring for FTP server to get config files, firmware.
I doubt Shortel use the same Cisco file to setup their phone but you can try running a ftp server to load the configuration.
