Does SIP ip phone 9971 support Unified IP Color Key Expansion Module on CME ?
ievalleyccie
I have IP Phone 9971 with Unified IP Color Key Expansion Module .
Can i Configure it on CME system?
dawid.grote
I heard it is supported since CME 9.1, is that correct?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme91spc.html
But where can I download the firmware? I could find it in the download section.
Can someone help?
Hi David,
That is most correct my friend
Here's the version history note;
9.1
KEM Support for Cisco Unified 8961, 9951, and 9971 SIP IP Phones
Increases line key and feature key appearances, speed dials, or programmable buttons on Cisco Unified SIP IP phones.
from;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
Here's the path for the firmware that is listed in the doc you linked;
Session Initiation Protocol (SIP) Software-9.2(3)
9971 SIP Firmware files only- Compatible CUCM Versions: 7.1(3)+
cmterm-9971.9-2-3-27.zip
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Hi Rob!
Thanks for the quick answer! Probably I think I need an other Firmwareload, cause I use a 8961 IP Phone.
As mentioned in this link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme90spc.html
there should be following Firmwareloads available:
SIP9971.9-2-3-27.loads
SIP9951.9-2-3-27.loads
SIP8961.9-2-3-27.loads
Can u tell if the SIP9971.9-2-3-27.loads also works fine for 8961? Or may you can tell where to get the 8961 Firmware?
Many Thanks!
Hi David,
Sorry about that, I was thinking 9971 for some reason
Here is the similar path for the 8961;
8961 SIP IP firmware files only  - Compatible CUCM Versions: 7.1(3)+
cmterm-8961.9-2-3-27.zip
Cheers!
Rob
