07-01-2011 02:36 PM - edited 03-16-2019 05:44 AM
I am installing the CUE module in the router, to function of the auto attendant and voice mail boxes.
Is it mandatory purchasing the follow licenses?
FL-CUE-PORT-2=
FL-CUE-IVR-2
FL-CUE-MBX-5=
What are differences between these licenses?
Tks
07-01-2011 03:54 PM
when you buy a module like CUE it comes with some default ports (like 6 or 8 dont remember) so you realy dont need to buy additional ports unless the ports are not enough for the number of Mailboxes you have and AA sessions required etc...voicemail and IVR (AA) traffic shares these ports so you need to size them correctly...MBX license is for each mailbox that you need (5 user bundle - gives you 5 licenses)...
07-01-2011 04:02 PM
FL-CUE-MBX-5 are licenses for mailboxes.
CUE modules includes "x" qty of voice ports by default. Additional voice ports can be ordered with the module or at a later date with FL-CUE-PORT-2 and FL-CUE-PORT-2=. These are software licenses that enable 2 ports on the module.
You do not need to purchase IVR session licenses (FL-CUE-IVR) if you are only planning on using voicemail and auto attendant. IVR session licenses are only required if your application contains advanced IVR features such as email, fax database access or VXML scripts.
Hope it helps, please rate if it does.
- Adrian.
11-28-2014 02:02 PM
Hello Adrian
What is the difference between the FL-CUE-MBX--5 and the FL-CUE-NR-MBX-5 licenses? Thanks for your time.
11-28-2014 02:42 PM
Hello Kyle,
Licenses with NR (Non-Rehostable) are licenses that are installed in the factory, or licenses that are issued as a replacement for legacy licenses.
Hope to help, please remember to rate helpful posts.
- Adrian.
11-28-2014 02:51 PM
Thank you!
07-03-2011 02:47 PM
Tks very much!!!
If i understood, if i buy just a interface CUE, i can configure AA without aditional licenses?
i didnt understand the FL-CUE-PORT-2 licenses, are to 2 or more simultaneous calls ?
In my case i have to install 35 mailboxes and configure one message of the AA, i have to buy CUE interface and seven FL-CUE-MBX-5 licenses ?
Tks
07-04-2011 08:07 AM
Yes. Price includes "x" qty of ports. Then you can run AA without additional licenses. You'll need additional licenses if you're running out of ports to answer VM or AA calls.
FL-CUE-PORT-2 will add 2 ports. One call per port, either for VM or AA.
Yes. CUE module depends on the ISR platform. Check this link for hardware compatibility: http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Hope it helps, please rate the posts if it does.
- Adrian.
