Download file from CUCM
Adrian Saavedra
Level 7
Level 7
I did a utils dbreplication status and return me the location of the file: (i.e. cm/trace/dbl/sdi ReplicationStatus.154933.out)
How can I download or access this file so I can see (if possible) any kind of
problem...
Best regards,
- Adrián.
Jaime Valencia
via CLI
file get
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_1_1/cucos/iptpappa.html#wp1036459
java
if this helps, please rate
java
Jaime Valencia
via CLI
file get
java
java
Thanks Java for the command tip ;)
- Adrián.
