Showing results forĀ
Search instead forĀ
Did you mean:Ā
Download Script on CUE module
sameermunj
Is there way to download the script running on the CUE module....
We don't have the Web access ...but we can able to login to the CLI of CUE module....need to check the scripts running on the CUE module
Any one can help in this case
5 Replies 5
hsood
Hi ,
You can utilize the following command:
ccn copy script script-filename url ftp://destination-ip-address
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/command/reference/CUECmdRef/c_cmds.html#wp1015652
Please mark correct if helpful.
Hitesh
Manish Gogna
Hi Sameer,
Downloading an Auto-Attendant Script File
Scripts can be copied from the auto-attendant and stored on another server or PC.
To copy a script file, use the ccn copy script command in Cisco Unity Express EXEC mode:
ccn copy script script-filename url ftp://destination-ip-address/script-filename
Example:
se-10-0-0-0# ccn copy script AVTscript.aef url ftp://10.100.10.123/AVTscript.aef
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/administrator/AA_and_VM/guide/vmadmin_book/AAttnd.html#wp1011823
Manish
Hello Manish,
Thanks for replay...already done with the same command several times but every time getting an error...
CUE4000# ccn copy script main_script.aef url ftp://10.238.202.229/main_script$
(7) couldn't connect to host
Just in case you are trying to download the default script please be aware that the default auto-attendant script provided with Cisco Unity Express resides in the system directory, and cannot be downloaded, copied, or uploaded.
Manish
Hello MAnish,
Thanks for information ...is there any kind of restriction to be configure so that Script can not be download using CLI...
asking this because now i tried for other scripts on same device where getting error Like
CUE
4000# $cript msgnotify.aef url ftp://10.238.202.229/msgnotify.aef
Operation not allowed
