01-24-2011 05:54 PM - edited 03-16-2019 03:03 AM
Hi All,
We've router 3845 show below
Cisco 3845 (revision 1.0) with 219136K/43008K bytes of memory.
Processor board ID FHK1319F3BH
2 Gigabit Ethernet interfaces
124 Serial interfaces
6 Channelized/Clear E1/PRI ports
2 Voice E & M interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
We are planning to add 1NM that have 2 E1 card.
Anyone please advice the DRAM memory that should be used?
Because when show proc mem the memory used is already 80%.
Thanks before.
01-24-2011 06:02 PM
You can max it up to 1 GB and altough likely not necessary, have peace of mind.
01-24-2011 06:13 PM
Hi Paolo,
thanks for your response.
Yeah I know the max DRAM Memory is 1GB and there's 2 slot there for memory.
I mean there's a way / tools to calculate the minimal requirement of the memory?
so when we upgrade the memory there's no unused cost (the memory installed is higher than requirement)
Thanks..
01-24-2011 07:28 PM
To be very honest with you, at $100/GB (third-party, quality proven module), personally I would not waste my time even looking for a tool.
