10-06-2010 05:45 AM - edited 03-16-2019 01:11 AM
It's similar to this problem https://supportforums.cisco.com/thread/2020752/ I checked the encoding dosn't hold true for my problem, So here is the problem have two offices 1 main with 20Mb down and 20Mb up, the branch office is connected over S2S VPN they have a T1, when you transfer a call from a phone in the main office to a phone it the branch office it rings and you are able to get there voicemail if they pick up then you get disconnected as in the thread i posted above, you can transfer from the attetdant console no problem. If you want me to post the running config of the 2 routers let me know, other wise just tell me what section you want since they are 5 pages in ms word.
10-06-2010 07:16 AM
If the call drops when the user answers, that is almost always a codec mismatch. You need to describe the entire topology of the call flow. Mention how the call comes into the network, and what protocols (both voip and pots) are being used for the call flow.
Then, we can take it from there.
If you post text output, please attach in .txt format and not .doc format.
10-06-2010 08:02 AM
We have 2 T1's one for local and one for long distance, all calls between 8:30am and 6pm go to the attendant console which she can transfer anywhere with success, if you transfer an outside call to a 7962 in the main office and then transfer it to the branch office it get dropped. I attached the config of the main and branch office. Hope this is enough info
10-06-2010 09:01 AM
Since these are h323 gateways, CM is going to use an ECS for a transfer. First, try adding these commands, which should be added on any h323 gateway to CM since it does ECS and doesn't support h450:
voice service voip
no supp h450.2
no supp h450.3
h323
emptycapability
If you still have issues after this, collect these debugs for a failure from both devices:
debug isdn q931
debug vpm sig
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
debug cch323 all
Collect the debugs in this manner:
Router(config)# service sequence
Router(config)# service timestamps debug datetime msec
Router(config)# logging buffered 10000000 7
Router(config)# no logging con
Router(config)# no logging mon
Router(config)# voice iec syslog
Router# term len 0
Router# sh logg
10-06-2010 12:44 PM
The managing party changed the branch office from h323 to mgcp and it seems to all work.
