DSCP, COS, and QOS
What is DSCP and QOS and how is used with switches, phones, etc.  Also, what does it mean by DSCP trust boundaries can I have an example of this?
Jaime Valencia
http://en.wikipedia.org/wiki/Differentiated_services_code_point
http://en.wikipedia.org/wiki/Quality_of_service
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/netstruc.html
java
if this helps, please rate
Just to give you an idea QOS is used to prioritize the network traffic.
We use COS to Prioritize traffic in Layer 2 frames & DSCP to Prioritize traffic in Layer 3 frames.
Refer the below document for brief understanding and configuration assistance:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swqos.html#wp1020443
Venkatesh.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
DSCP is a way of marking packets so they may easily identified for different service level treatments.
QoS is the overall "bucket" that encompasses providing different service level treatments.
Basically some traffic, such as packets from VoIP phones have their packets marked differently so those packets might be treated better, when there's resource contention, on switches (and routers).
As different DSCP marking might be used for different service levels, the issue of trust arises.  I.e. is a marking that denotes better treatment "trusted" to be legitimate.  A trust boundary defines demarcation of a range, within a network, that a DSCP marking is assumed to be valid.
QoS isn't really complex, but it's very broad subject.  You need to know much to understand how it all fits together.
Cisco has some nice information on QoS, you might start with documents off this page: http://www.cisco.com/c/en/us/solutions/enterprise/design-zone-application-performance/landing_cVideo.html
