Hello after a recovery CUCM is showing this message:cucm01 login: /opt/CSC0CSA/bin/log_clean: line 8: [ : too may argumentsWhat means this log message?RegardsLeonardo Santana
Hi everyone;I dial from my mobile phone to my customer number and press the extension number for phone inside the company ,The IP Phone rings Now I hang off the mobile phone but the IP Phone still ringing. what the problem and Thank you very much....
Greetings Members,I am configuring a 24 line add-on to a Cisco 7962G phone but it is still shows amber with the Cisco logo!! Any ideas how i can go past this?
Hi ,I am facing problem during SIP SRST. We are using 2921 CME SRST router and SIP phones are getting registered on router in SRST mode.But extn to extn calling is not working. I have attached show run of the router. When i executed, below commands,...
how do i configure CUCM 7.0.1.11000-2 and cisco 2811 version 12.4 for this scenario:CUCM--------SIP trunk--------->2811(without CUBE)--------SIP trunk-------->ITSPthe 2811 sits between the SIP service provider ITSP and CUCM, but the 2811 is NOT a CUB...
Hello,below Scenariophone extension partitions CSS7942 555 Internal landlineUDP 7942 555 UDP GSM CSS configuredInternalGSM When a user is not login on his 7942 deskphone and he login another deskphone (7945) , int...
We have a number of 6941's connected to 3750 switches. The user's computer connects to the phone and they are put on a separate VLan. When a user tries to copy a large file (22gb Vmware Image) via windows networking the copy process fails. If we ...
Hey Guys. I am new to voice.I need to design a network with 18 CO(FXO) lines and 20 Extensions. Kindly suggest router and modules i need . Quick reply appreciated.
Hi!I've been asked to delete the voice mails on an account built in a CUCU 8.6. Is there a way to clear all the messages via the CUUC admin portal without having to delete and rebuild the account?Thank you!
I'm having an issue with External Phone Number Masks in CUCM 8.6Until recently our DID ranges were all in the 301-713-nnnn range. Using the EPNM worked successfully providing CallerID. We have now added some DIDs with the prefix 301-427.I have se...
Hi All,I have new installation for BE6K, some services are not working after i run password recovery to reset securtiy password, i tried to do DRS backup and BAT, but both fail. if i use recovery iso to fix problem, will all configuration lost? any a...
I am working with TAC on some 7841 phone issues and the engineer mentioned it is possible to console into the phone using a DB9 to RJ11 cable in the AUX port.Rather than purchase one of these and wait for it to ship I figured I could take an existing...
I'm not sure how to ask this question but here it goes...We are running CallManager 7.0 using route groups, route list, and route patterns (I assume that this is considered a dial plan). Calls go through our 3845 router (voice gateway) to the PSTN. ...
Hello All,CallManager: 8.0.3.22026-1IP Phone: CP-7941GI was configuring a phone for a user that is located in a separate location then our main location, which is where I am. We have Device Pools configured for ALL of our locations with corresponding...
Hi All,We have a new CUCM 10 setup with a h.323 router (ISDN PRI).Our old setup (CUCM 8.5) still works flawlessly, and settings are mostly the same.However, it seems that the new Callmanager isn't passing all digits to the h.323 gateway.Only 8 digits...
Subject | Author | Posted |
04-22-2025 12:18 PM | ||
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM | ||
04-14-2025 01:50 PM |
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
