03-10-2014 01:53 PM - edited 03-16-2019 10:04 PM
Can you help me undestanting how to uses the calculator?
The first issue I found is how to make it work with PVDM3 or VWIC3, then what do I need to write in each part.
Finally how to interpret the output.
I want to know if whit the below information I can support two E1 (32 channels each)
R1#show inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: XXXXXXXXXXX, Hw Revision: 1.0"
PID: CISCO2921/K9 , VID: V08 , SN: XXXXXXXXXXX
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1 , VID: V01 , SN: FOC17045FDX
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32 , VID: V01 , SN: FOC165248EF
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32 , VID: V01 , SN: FOC17080NSH
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC , VID: V03 , SN: QCS1650H162
I read the help guide, but I dont quite understand this.
Solved! Go to Solution.
03-10-2014 03:38 PM
VWIC3-2MFT-T1/E1 is the card that will allow you to connect 2 seperate E1 circuits to it.
PVDM3-32 will allow conversion from TDM (E1) to voip, depending on which codec you are going to use each call will either use 1 PVDM channel (low/medium complexity i.e. G711), or 2 channels (high complexity, i.e. G729R8).
HTH,
Chris
03-11-2014 12:22 AM
03-10-2014 03:38 PM
HTH,
Chris
03-11-2014 08:37 AM
@Aman Thanks for the link!!! very useful!!
@Chis, just to be sure, becuase I have two PVDM3 I can have a total of 32 calls using g729 and 64 calls using g711? (If I connect both E1)
Rolando Valenzuela
03-10-2014 08:25 PM
03-11-2014 12:22 AM
