DSP show sccp connections
israel.castillo
Hi there
I have this issue with getting many sccp connections, I know that all I have to do is
ROUTER(config)#no sccp
ROUTER(config)#sccp
71180360 34407856 mtp recvonly g711u 21622 0 0.0.0.0
71199586 34554280 mtp recvonly g711u 16650 0 0.0.0.0
71200616 34560686 mtp recvonly g711u 27908 0 0.0.0.0
71229678 34804110 mtp recvonly g711u 25686 0 0.0.0.0
everything is fine for a couple of days, but then I start getting them again.  My MTP sessions are for 50,  does this means I need more resources? I know if I add more sessions, I´ll be running our of resources.  or why am I getting those sccp connections as 0.0.0.0?
Thanks.
Here is the part of the config.
dspfarm profile 2 transcode
codec g729r8
codec g711ulaw
maximum sessions 30
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
maximum sessions 30
dspfarm profile 3 mtp
codec g711ulaw
codec pass-through
maximum sessions software 50
5 Replies 5
Gregory Brunn
What router and iOS are you using I had a slightly similar problem some time ago turned out to be a bug that was that releasing sessions.
is a
CISCO3945 and  15.2(4)M9 IOS Version.
Not what I was thinking I had
Cisco Bug: CSCvd22910 - Hung Transcoder sessions in complex call flows
I´m not really sure, the bug says
Affected Releases: 15.5(3)S5.1 and IOS 15.5.3M5 or 15.6.3M.
and router Cisco 4400 Series Integrated Services Routers.
that does´t match my hardware and IOS situation. Could you think in something else?
Yeah that is what I was saying, My bug is not your bug.
