dspfarm transcoding shutdown
Harald Roessler
Hi all,
i have a problem with the CISCO2921/K9 Voicegateway. I try to configure a dsp transcoding profile but this always shutdown automatically. I do "no shut" and on the next "sh run" this profile is shutdown.
Do you have any ideas? See some configs and show details below.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
sccp local GigabitEthernet0/0
sccp ccm 172.31.0.10 identifier 1 priority 1 version 7.0
sccp ccm 172.31.0.11 identifier 2 priority 2 version 7.0
sccp ccm 172.31.23.10 identifier 3 priority 3 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate ccm 3 priority 3
 associate profile 1 register MAIVGW01
 associate profile 2 register MAIVGW01CONF
dspfarm profile 1 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec pass-through
 maximum sessions 5
 associate application SCCP
 shutdown
dspfarm profile 2 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 1
MAIVGW01#sh dspfarm profile 1
Dspfarm Profile Configuration
 Profile ID = 1, Service = TRANSCODING, Resource ID = 1
 Profile Description :
 Profile Service Mode : Non Secure
 Profile Admin State : DOWN
 Profile Operation State : DOWN
 Application : SCCP   Status : ASSOCIATION IN PROGRESS
 Resource Provider : FLEX_DSPRM   Status : UP
 Number of Resource Configured : 5
 Number of Resources Out of Service : 4
 Codec Configuration: num_of_codecs:5
 Codec : pass-through, Maximum Packetization Period : 0
 Codec : g711ulaw, Maximum Packetization Period : 30
 Codec : g711alaw, Maximum Packetization Period : 30
 Codec : g729ar8, Maximum Packetization Period : 60
 Codec : g729abr8, Maximum Packetization Period : 60
thanks,
stephan
5 Replies 5
D_Lebedev
Level 3
Level 3
Hi Stephan.
It seems there is something wrong with your dsp resources.
Number of Resources Out of Service :4  it should be zero.
Run command "sh dspfarm dsp all"  and show us output
thx 4 ur fast reply.
MAIVGW01#sh dspfarm dsp all
SLOT   DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0      1   37.3.4   UP     N/A  FREE  xcode   1      -         -         -
0      7   37.3.4   UP     N/A  FREE  conf    2      -         -         -
Total number of DSPFARM DSP channel(s) 2
MAIVGW01#sh dspfarm all
 Profile ID = 2, Service = CONFERENCING, Resource ID = 2
 Profile Admin State : UP
 Profile Operation State : ACTIVE
 Application : SCCP   Status : ASSOCIATED
 Number of Resource Configured : 1
 Number of Resources Out of Service : 0
 Maximum conference participants : 8
 Codec Configuration: num_of_codecs:6
 Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Yes,it seems you've not enough dsp recources.
You can try decrease number of xcode sessions from 5 to 1 and no shut.
You can check DSP quanity you need here
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Hope it helps also
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/62959-ccm-ios-dsp-farm.html
Wilson Samuel
Level 7
Level 7
Hi Stephen,
It may be that you are running low on the Codecs, I guess you are oversubscribing it unintentionally.
Just wondering if you could post, show inventory output as well, just wanted to make sure how many DSPs you have in total.
Secondly are you really using G.729br8, G.729ar8 and G.729abr8 codecs? I usually use only the G.729r8 codecs along with G.711ulaw / G.711alaw codecs
thx for your reply.
we've 2 DSP modules inside.
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: FOC19070G6L
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: FOC19102QTQ
i'm a beginner in this voicegateway things. u think its better to use only G.711 codecs?
stephan
