11-18-2020 10:32 AM
I am using cisco ip phone with the sip protocol internally and i can make calls between them no problems there the problems begin when i go to dial out i am dialing out over an fxo port
voice-port 0/0/0
connection plar 1134
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer voice 9 pots
destination-pattern 9[2-9].........
port 0/0/0
dial-peer voice 1 pots
destination-pattern 91[2-9].........
port 0/0/0
prefix 1
dial-peer voice 9911 pots
destination-pattern 9911
port 0/0/0
prefix 911
The problem is not making and reciving calls the only issue is when i call a number lets say microsoft and i get an auto attendant i cant select any options i cant figure out how to configure that on an fxo port any ideas
11-18-2020 06:54 PM - edited 11-18-2020 06:55 PM
can you try signaling and CP tone commands under voice port and see if it makes any change.
11-18-2020 07:32 PM
Okay can you give me examples of config code?
11-18-2020 07:33 PM
Im not sure what that is im still learning voice
11-18-2020 07:52 PM
I tried both CP Tone which i set to the us due to my recidense being in the US but it does not show up in my show run if i set it and i dont know what signal to use because it is just a standard home phone network
11-18-2020 08:10 PM
That is my full running config if it will help
StudmuffinVoiceRoute(config-voiceport)#do show run
Building configuration...
Current configuration : 8086 bytes
! Last configuration change at 21:29:44 UTC Wed Sep 17 2014 by Studmuffin
version 15.7
service password-encryption
hostname StudmuffinVoiceRouter
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone UTC -6 0
clock summer-time UTC recurring
ip domain name Studmuffin.com
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-2787660014
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2787660014
revocation-check none
rsakeypair TP-self-signed-2787660014
crypto pki certificate chain TP-self-signed-2787660014
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373837 36363030 3134301E 170D3134 30383034 31373538
34335A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37383736
36303031 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A597 CCF77C81 8FA01C71 1ED6469B 37E0AAA5 C03018C6 1A7CF162 8BC33AF0
0AFC05F0 6EE15C3F 853C4AE4 C93ACCD4 C6A5C88D F4E8E501 B06579CB BA872986
721D1508 AE21CC5E 609F229D 276A362D BDF3433B 2FFC5AAA 8E85A1C0 FCA810B3
A29F0338 1414853E 869D715E D91D72C5 B6458176 664F8327 7F5F07D4 E7E477D3
991D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1448A604 B7D4D5D7 3F8823D2 C3946365 E4D500F3 E7301D06
03551D0E 04160414 48A604B7 D4D5D73F 8823D2C3 946365E4 D500F3E7 300D0609
2A864886 F70D0101 05050003 81810098 60B5F919 4C9B2C7D A49E273C BEE93BC0
A15C0B0D 48A13472 8F360F04 34837C32 BF2138CC D884AA4E A425F217 12AA2156
CDCE9E43 88B2A647 7F347285 58AC724D 95A6BFAF E086E0FE 4F13FC9B 298896A9
524CD5D3 8FBBAE71 A49D7CB8 76E5A0F0 19F7E835 2B212C94 D2DE25B5 BC32FF31
968E6BDE D7851415 83321C82 7D97B8
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 86400 min 60
voice register global
mode cme
source-address 192.168.20.2 port 5060
max-dn 50
max-pool 42
timezone 8
time-format 24
create profile sync 0404741354017156
auto-register
voice register dn 1
number 1134
allow watch
name StudmuffinAdmin
label StudmuffinAdmin
voice register dn 2
number 1135
allow watch
name StudmuffinSlave
label StudmuffinSlave
voice register dn 3
number 1137
allow watch
name MOM
label MOM
voice register pool 1
id mac A456.30BB.5301
type 7965
number 1 dn 1
no digit collect kpml
codec g711ulaw
blf-speed-dial 1 1135 label "Studmuffin-Slave" device
blf-speed-dial 2 1137 label "Mom" device
voice register pool 2
id mac A456.3041.8926
type 7965
number 1 dn 2
codec g711ulaw
blf-speed-dial 1 1134 label "Studmuffin-Admin" device
voice register pool 3
id mac 0015.621A.D7E8
type 7960
number 1 dn 3
codec g711ulaw
speed-dial 1 1134 label "Valera"
blf-speed-dial 2 1134 label "Valera" device
vxml logging-tag
license udi pid CISCO2901/K9 sn FTX183582N1
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
username Studmuffin privilege 15 password 7 01340F520B5F575C731F1C5A
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.2 255.255.255.0
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.100.3 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 192.168.100.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.100.1
tftp-server flash0:cnu45.9-4-2ES26.sbn alias cnu45.9-4-2ES26.sbn
tftp-server flash0:cvm45sip.9-4-2ES26.sbn alias cvm45sip.9-4-2ES26.sbn
tftp-server flash0:dsp45.9-4-2ES26.sbn alias dsp45.9-4-2ES26.sbn
tftp-server flash0:jar45sip.9-4-2ES26.sbn alias jar45sip.9-4-2ES26.sbn
tftp-server flash0:SIP45.9-4-2SR3-1S.loads alias SIP45.9-4-2SR3-1S.loads
tftp-server flash0:term45.default.loads alias term45.default.loads
tftp-server flash0:term65.default.loads alias term65.default.loads
tftp-server flash0:Desktops alias Desktops
tftp-server flash0:Desktops/320x212x16
tftp-server flash0:Desktops/320x212x16/Black.png
tftp-server flash0:Desktops/320x212x16/CampusNight.png
tftp-server flash0:Desktops/320x212x16/CiscoFountain.png
tftp-server flash0:Desktops/320x212x16/Fountain.png
tftp-server flash0:Desktops/320x212x16/MorroRock.png
tftp-server flash0:Desktops/320x212x16/NantucketFlowers.png
tftp-server flash0:Desktops/320x212x16/Skull.png
tftp-server flash0:Desktops/320x212x16/TN-Black.png
tftp-server flash0:Desktops/320x212x16/TN-CampusNight.png
tftp-server flash0:Desktops/320x212x16/TN-CiscoFountain.png
tftp-server flash0:Desktops/320x212x16/TN-Fountain.png
tftp-server flash0:Desktops/320x212x16/TN-MorroRock.png
tftp-server flash0:Desktops/320x212x16/TN-NantucketFlowers.png
tftp-server flash0:Desktops/320x212x16/TN-Skull.png
tftp-server flash0:Desktops/320x212x16/Krystal.png
tftp-server flash0:Desktops/320x212x16/TN-Krystal.png
tftp-server flash0:Desktops/320x212x16/AssCreed.png
tftp-server flash0:Desktops/320x212x16/TN-AssCreed.png
tftp-server flash0:apps45.9-4-2ES26.sbn alias apps45.9-4-2ES26.sbn
tftp-server flash0:Desktops/320x212x16/List.xml
tftp-server flash0:Desktops/320x212x16/Krystal2.png
tftp-server flash0:Desktops/320x212x16/TN-Krystal2.png
tftp-server flash0:Desktops/320x212x16/TN-Krystal4.jpg
tftp-server flash0:Desktops/320x212x16/Krystal4.jpg
tftp-server flash0:Desktops/320x212x16/Krystal4.png
tftp-server flash0:Desktops/320x212x16/TN-Krystal4.png
tftp-server flash0:OS79XX.TXT
tftp-server flash0:P003-08-6-00.bin
tftp-server flash0:P003-08-6-00.sbn
tftp-server flash0:P0S3-08-6-00.loads
tftp-server flash0:P0S3-08-6-00.sb2
control-plane
voice-port 0/0/0
secondary dialtone
groundstart auto-tip delay 30
timing digit 50
timing inter-digit 50
station-id name NordstromFamily
caller-id enable type 1
cable-detect
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
port 0/0/0
port 0/0/0
prefix 1
port 0/0/0
prefix 911
gatekeeper
shutdown
telephony-service
max-ephones 5
max-dn 10
ip source-address 192.168.20.2 port 2000
service phone displayOnTime 10:00
service phone displayOn 10:00
service phone displayIdleTimeout 00:01
service phone DisplayNotActive 1,2,3,4,5,6,7
service phone settingsAccess 1
service phone displayOnDuration 05:00
time-zone 8
max-conferences 8 gain -6
moh enable-g711 "flash0:music-on-hold.au"
transfer-system full-consult
create cnf-files version-stamp 7960 Oct 14 2020 03:31:42
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
transport output all
line vty 5 15
login local
transport input all
scheduler allocate 20000 1000
end
