08-05-2015 10:23 PM - edited 03-17-2019 03:53 AM
PSTN----H323 VG----CUCM----SIP TRUNK----3rd party IVR
when called form PSTN,IVR is played which ask for different options to be chosen by pressing 1 or 2 or so on. Let say after pressing 1, it again ask for pressing the option as if it does not sense the input.
below is dial-peer and voip ccapi inout
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
voice class h323 1
h225 timeout tcp establish 3
h225 h245-address on-connect
no h225 h245-address setup
no h225 h245-address on-progress
no h225 h245-address on-alert
h225 h245-address facility
h225 h245-address progress
h225 h245-address sync
no h225 h245-address on-setup
telephony-service ccm-compatible
ccm-compatible
dial-peer voice X voip
destination-pattern 0..
voice-class h323 1
voice-class sip dtmf-relay force rtp-nte --- this was not there, I put it later to TS
session target ipv4:192.168.1.1
dtmf-relay rtp-nte---This was h245-alphnumeric
codec g711ulaw
no vad
dial-peer voice 3 voip
preference 1
voice-class h323 1
session target ipv4:192.169.1.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
*Aug 5 12:58:16.951: //21952/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 1 to dstCallId 0x55C1
*Aug 5 12:58:16.951: //21952/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
Check DTMF relay digit begin for 3way conf
*Aug 5 12:58:17.039: //21952/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
*Aug 5 12:58:17.039: //21952/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
Check DTMF relay digit end for 3way conf
*Aug 5 12:58:21.559: //21952/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 9 to dstCallId 0x55C1
*Aug 5 12:58:21.559: //21952/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
*Aug 5 12:58:21.651: //21952/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
*Aug 5 12:58:21.651: //21952/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
*Aug 5 12:58:33.219: //21953/6E3B260898A3/CCAPI/cc_api_call_media_reset_ind:
Interface=0x0, Call Id=21953
*Aug 5 12:58:33.227: //21953/6E3B260898A3/CCAPI/cc_api_call_userinfo:
Interface=0x48BD4A68, Signal Indication=TONES OFF(63)
*Aug 5 12:58:33.227: //21952/6E3B260898A3/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=21952
*Aug 5 12:58:33.231: //21953/6E3B260898A3/CCAPI/cc_api_call_userinfo:
Interface=0x48BD4A68, Signal Indication=NOT PRESENT(255)
*Aug 5 12:58:33.231: //21952/6E3B260898A3/CCAPI/ccCallUserInfo:
08-06-2015 12:33 AM
Please share the output of 'debug voice rtp session named-event'. Also, what DTMF configuration are you using on the SIP trunk. Please share a snapshot
08-06-2015 12:46 AM
with this command no output display. Alrady 2 VGs connected in same and those are working fine so it does not look like sip trunk config issue. Issue must be with this VG itself
08-06-2015 03:00 AM
Mohammed,
It can be H323-SIP interworking problem as there are many restrictions.
Try to generate Session Trace from RTMT and see what is happening on the SIP side when you press DTMF. Do you see digits being sent?
If you can generate trace folder in uncompressed format and send it along with calling/called numbers, I will be able to look at it.
08-06-2015 12:47 AM
On VGW you are using rtp-nte rfc 2833.. Can you please what's the DTMF method is configured in the sip trunk if it's OOB insert MTP to covert inband to OOB and vice versa
08-06-2015 01:41 AM
Hi Nadeem,
You are right. rtp nte is used for sip trunk. In my case its PRI line terminating on VG. I removed those setting and tried with h245 alphanumeric which was before also. One more thing is from debug ccapi inout, I can confirm that the DTMF digits are sent by telco. Some how either they are not getting relayed to cucm or something else. How can we check from CCM traces whether the dtmf is received by cucm? One more thing to be noted is there is MPLS link between this VG and CUCM. Other 2 VGs are in the same LAN where CUCM is and those don't have such issue.
