DX70
j.huizinga
Level 6
Level 6
Quick question:
Can we change the font size of a DX70 running CE software?
JH
pieterh
Change Font Size
1. In the Settings application, tap Accessibility.
2. Tap Font size.
3. Select a font size
Yes, I read that, but this seems not to be true for CE software. Is this feature available in CE software?
Jan
seems not
Before converting to CE software, it is important to consider the conversion requirements and the functionality changes compared to Android-based software.
Last Updated: May 23, 2018
The following features are currently not supported:
  • Standard Android accessibility feature
Yep already afraid of that
The DX70 came with CE software, and Android seems not to be supported anymore by Cisco
