E.164 CUCM
We are going to deploy E.164  call routing for CUCM 10.5.2. We will cover whole APAC region for our deployment. Before going ahead with E.164 routing, i want to know below things-
1. Do i need separate translation pattern and called party number transformation for outbound E.164 calls per site ? To make it more clear if i have 10 sites for AUS country then do i need around 4*10 =40 Translation pattern and around 40 called party number transformation for outbound calls ? I know that we just need \+! route patten for each country but i am not sure if we need more than 4-5 translation pattern per country .
2. If our Service provider is supporting +E.164 format then i think there is no need to create localization support for outbound calls as our Service provider understand + E.164 format . Correct ?
3.  Is there any issue while creating E.164 support for Single SIP trunk ? We are going to deploy ACME session border controller as SIP SBC.
Manish Gogna
Hi Madhav,
Please check the "Globalized Dial Plan Approach on Unified CM" section of the following link for design recommendations for e.164 on CUCM
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/dialplan.html#99952
Manish
- Do rate helpful posts -
