E&M troubleshoot
My client is using a Avaya PBX to connect to Cisco Router. I am having two sites between which calling has to be set up. I have put the dial-plan in place but the call is not working.. I suspect an E&M issue. Can someone explain me what In-seizure and out-seizure is and can u pls tell me why the out status on second router is showing as seized..
                           IN      OUT
PORT            CH  SIG-TYPE    OPER STATUS   STATUS    TIP     RING
0/0/0:0          01  e&m-wnk     dorm idle     idle
0/0/0:0          02  e&m-wnk     dorm idle     idle
Voice card specific Info Follows:
Operation Type is 2-wire
E&M Type is 1
Signal Type is wink-start
Dial Out Type is dtmf
In Seizure is inactive
Out Seizure is inactive
                                      IN      OUT
0/3/0:0          01  e&m-wnk     down idle     seized
0/3/0:0          02  e&m-wnk     down idle     seized
0/3/0:0          03  e&m-wnk     down idle     seized
0/3/0:0          04  e&m-wnk     down idle     seized
E&M Type is 1
Out Seizure is active
0 Replies 0
