My client is using a Avaya PBX to connect to Cisco Router. I am having two sites between which calling has to be set up. I have put the dial-plan in place but the call is not working.. I suspect an E&M issue. Can someone explain me what In-seizure and out-seizure is and can u pls tell me why the out status on second router is showing as seized..
IN OUT
PORT CH SIG-TYPE OPER STATUS STATUS TIP RING
0/0/0:0 01 e&m-wnk dorm idle idle
0/0/0:0 02 e&m-wnk dorm idle idle
Voice card specific Info Follows:
Operation Type is 2-wire
E&M Type is 1
Signal Type is wink-start
Dial Out Type is dtmf
In Seizure is inactive
Out Seizure is inactive
IN OUT
0/3/0:0 01 e&m-wnk down idle seized
0/3/0:0 02 e&m-wnk down idle seized
0/3/0:0 03 e&m-wnk down idle seized
0/3/0:0 04 e&m-wnk down idle seized
E&M Type is 1
Out Seizure is active
