Can someone explain what is the E1 R2 category?
http://www.cisco.com/c/en/us/support/docs/voice/digital-cas/53049-e1-r2-cookbook.html#brazil
Specifies the type of call (subscriber with priority or normal subscriber). ITU default is 1 (normal subscriber). For outgoing calls, the router sends this category. If this is not configured, the router sends the country default category. For incoming calls, the router collects the category from the switch. No special handling is based on the category.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
