02-13-2009 04:06 PM - edited 03-15-2019 04:13 PM
I have customer in Sao Paulo, Brazil.2801 gw SRST site(CCM 4.1.3). Firstly I search for 2 days to get hold of a RJ45 to BNC, 75 Ohm, Unbalanced cable. I got the part eventually from a Cisco shop. This connects to a VWIC2-2MFT-T1/E1. Something I saw in my configs is a show controller E1 says balanced:
OSANET01# sh controller e1
E1 0/2/0 is up.
Applique type is Channelized E1 - balance
controller E1 0/2/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 1 timeslots 17-31 type r2-digital r2-compelled ani
cas-custom 0
country brazil use-defaults
metering
category 2
answer-signal group-b 1
cas-custom 1
metering
category 2
description link to TELCO
voice-port 0/2/0:0
no vad
cptone BR
voice-port 0/2/0:1
no vad
cptone BR
dial-peer voice 1 pots
translation-profile incoming 5digits
destination-pattern .T
progress_ind alert enable 8
incoming called-number .T
direct-inward-dial
port 0/2/0:0
forward-digits all
dial-peer voice 2 pots
direct-inward-dial
port 0/2/0:1
forward-digits all
dial-peer voice 20 voip
destination-pattern 30...
session target ipv4: X.X.X.X
codec g711ulaw
no vad
When dialling in I get the following on my debug:
Feb 13 19:07:26.135 BRT: //47/1DE6B814804D/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x654666D4, Call Id=47
Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Feb 13 19:07:26.139 BRT: //48/1DE6B814804D/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Feb 13 19:07:26.139 BRT: //48/1DE6B814804D/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
And when dialling out, the phone ring once, and then goes engaged:
Feb 13 19:08:17.803 BRT: //49/004291911100/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x64DA4504, Call Id=49
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Feb 13 19:08:17.803 BRT: //49/004291911100/CCAPI/cc_api_get_transfer_info:
Feb 13 19:08:17.803 BRT: //49/004291911100/CCAPI/ccConferenceDestroy:
Conference Id=0x6, Tag=0x0
Feb 13 19:08:17.803 BRT: //49/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x6, Source Interface=0x64DA4504, Source Call Id=49,
csim start works
02-13-2009 04:15 PM
On dialing in:
The E1 R2 side of the circuit is disconnecting with a normal cause code. Hard to say without looking at painful E1 R2 debugs.
On dialing out:
Your H323 leg is disconnecting with no resources. Check DSP resources, transcoding, and codecs.
Good luck,
-nick
02-13-2009 04:23 PM
I just noticed a possible mistake. I see I have 2 ds0 groups. I have debug voip ccapi's which I could look through if I just knew what to look for. As you say it is just quit bulky. Could send it to you if I had your mail address:) DSP's? I have a PVDM 2-64, and a PVDM 2-32 in there. Can see what that should be an issue. I have 8 transcoding, 6 conferencing, and 250 software sessions sucessfully configured. Somethat bothers me is the fact that the cable is unbalanced, and that when I do a show controller E1, it say balanced. Could this be an issue.
02-13-2009 04:29 PM
There's not really a 'good' spot to look. You have to know the E1 R2 signaling in order to find out who's creating the disconnect condition - which isn't any fun because there are a TON of E1 R2 variations.
debug vpm signal is the one that's going show you the state changes on the E1 R2 circuit. I don't see these circuit very often at all, so it's hard to tell you.
-nick
02-15-2009 10:00 AM
True, but the good news is that in most cases, the circuits are digital/compelled, and tolerant of minor mistakes in customization. If you're interested in a couple of non-cisco docs detailing R2, let me know and I'll send these to you.
02-15-2009 11:00 AM
My IOS ver is c2801-adventerprisek9-mz.124-10a.bin. Please can you send me those docs as mentioned? louis.koekemoer@za.didata.com
Thank you
Louis
02-15-2009 11:15 AM
I would try 12.4(3j).
I've sent you the docs, I hope you will never need them.
02-14-2009 03:49 AM
Ola', for unbalanced E1 configure
controller E1 x/y
line-termination 75-ohm
Also remember to configure network-clock-participate and network-clock-select to give priority to this E1.
I don't think this is the cause of the problem however.
02-15-2009 05:49 AM
Is your carrier Telefonica in Sao Paulo?
I would suggest using just one ds0/CAS group:
ds0-group 1 timeslots 1-15,17-31 type r2-...
I would also suggest adding this to your voice-port:
bearer-cap Speech
Good luck.
02-15-2009 08:22 AM
lagos, very often E1 R2 circuits are split in two sets of channels, to ensure that outgoing and incoming calls never overlap, minimizing the possibility of glare.
Also, bearer-capability is effective on PRI circuits only. There is no bearer capability concept in E1 R2.
