E911 on a shared DN
johnnywan
We are running CUCMBE 7.1.3 and have multiple buildings. One PSTN connection so we are implementing a 3rd party E911 solution. The problem is that we have a handful of DNs that are in different bldgs using the same dn/partition. They require this DN to be a shared DN so my options are limited and they refuse to use exenstion mobility. How can I tag the calls from a shared line with different information for E911 purposes?
paolo bevilacqua
I think your question should go to the 3rd party solution provider?
Then if turns out that is not possible to do, you notifiy in written the management about user's decision, and having done your due diligence, can move on.
