Edit Jabber-config-defaults.xml file values in MSI
Is there a way I can edit the jabber-config-defaults.xml file in the MSI file or extract it edit it and repackage the MSI file again.
I am looking at changing values from FALSE to TRUE.
<userConfig name="EnableP2PDesktopShareOverEdge" value="TRUE"/>
  <userConfig name="EnableReverseConnectionForP2PDesktopShare" value="TRUE"/>
  <userConfig name="PreferP2PDesktopShare" value="TRUE"/>
The above mentioned is FALSE by default and I want to deploy it with TRUE by default?
Best Regards
Vishal Bhardwaj
Hi There,
Yes, you can create a custom Installer by opening the msi in orca. Please check the following link and creating the custom installer OR you can edit the jabber-config.xml and reupload and restart the tftp service and that should work as well.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_5/CJAB_BK_D6497E98_00_deployment-installation-guide-ciscojabber/install_client.html#JABW_TK_I30E13DC_00
I Hope it helps !
Hi There,
Thanks for the reply but I have already tried both options. I need to physically edit the jabber-config-defaults.xml file that is installed in the folder C:\Program Files (x86)\Cisco Systems\Cisco Jabber\jabber-config-defaults.xml before it is installed.
I have tried adding these values into the jabber-config.xml file but it does not change my jabber-config-defaults.xml file at all.
I don't want to go and edit this file and then manually have to push it to the clients, I would rather edit the xml file and somehow repackage the msi file with the xml file fields edited.
Best Regards
