EM-4BRI-NT/TE voice port
study_voip
I have one EM-4BRI-NT/TE installed on one 3845 router, what is the actual voice port I can configure for the calls?
looks like the range is from 4/0/0 to 4/0/7, but from 4/0/8 to 4/0/11, they are configurable
4/0/0 -- fxs-ls up dorm on-hook idle y
4/0/1 -- fxs-ls up dorm on-hook idle y
4/0/2 -- fxs-ls up dorm on-hook idle y
4/0/3 -- fxs-ls up dorm on-hook idle y
4/0/4 -- fxs-ls up dorm on-hook idle y
4/0/5 -- fxs-ls up dorm on-hook idle y
4/0/6 -- fxs-ls up dorm on-hook idle y
4/0/7 -- fxs-ls up dorm on-hook idle y
4/0/8 1 bri-voice up dorm none none y
4/0/8 2 bri-voice up dorm none none y
4/0/9 1 bri-voice up dorm none none y
4/0/9 2 bri-voice up dorm none none y
4/0/10 1 bri-voice up dorm none none y
4/0/10 2 bri-voice up dorm none none y
4/0/11 1 bri-voice up dorm none none y
4/0/11 2 bri-voice up dorm none none y
12 Replies 12
paolo bevilacqua
from 4/0/0 to 4/0/7 are the FXS port of your EVM-HD-8FXS/DID that holds the EM-4BRI-NT/TE.
Hence the BRI voice ports are from 4/0/8 to 4/0/11. Note each one is repeated twice for the 2 B-channels in the show command above.
thanks for your input.
my question is
when I configure
destination-pattern xxxx
voice-port ???
right now, I am using 4/0/0 to 4/0/7 because i think they are FXS port, but I can specify 4/0/8 as well, not sure which port is the right port i need to specify
If you use the recommended blackbox patch panel, the BRI ports are marked like 1, 2, 3, 4, so in configuration, voice-port 4/0/8 would be the first of these.
I am using Blackbox, each BRI has two voice ports, and I need give each port one number, if I use the port from 4/0/8, I only can give 4 numbers, which is not very right, but i will try
With ISDN, the numbers are also handled by the connected equipment, not just the router.
What are you connecting to this card ?
For example, if you connect a PBX, you will see that the numbers are the ones pertaining to the extensions behind the PBX.
You can also configure so that a single pattern is distributed across multiple ports, eg calls to 61xx will go out on ports 4/0/8 and 4/0/9. This is called a trunk-group configuration.
Conversely, you can configure so calls to multiple numbers or patterns will go out the same port, this is done configuring more than one DP with the same port.
All really depends on what you are trying to do.
I am connecting a video conferencing device which need 8 numbers. so I am thinking one fxs match one number, and I am confused about the port number range from 4/0/8 to 4/0/11
the router will act as TDM switch
then for outgoing calls to the video device, you configure a DP with a pattern as I mentioned in my previous message. If you cannot or do not want to summarize the 8 numbers, you will configure multiple DPs.
Note that numbers are never tied to ports directly, but only using pots DP.
For incoming calls, the device will specify its calling number in the Q.931 setup message.
I would also configure an incoming DP with direct-inward-dial and the numbers that the device is calling (or a match-all for any number:
dial-peer voice 111 pots
incoming called-number ..
direct-inward-dial
p.bevilacqua
Thanks for your input, however, my question is still not be answered.
I will try it this week and let you know
thanks again for your input
And what your question exactly is ?
I found the answer already, the 1st 8 voice ports is totally different with the rest 4 ports
1st 8 ports are FXS only
the other 4 ports are BRI voice
however, I found new problem
when I connect the module to the video device, nothing shown up, looks like only layer 1 is up, layer 2/3 not up
any idea?
here is config
network-clock-participate slot 4
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
interface BRI4/0
no ip address
isdn switch-type basic-ni
isdn timer T309 30000
isdn protocol-emulate network
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn layer1-emulate network
isdn incoming-voice voice
isdn supp-service name calling
isdn skipsend-idverify
line-power
dial-peer voice 222 pots
direct-inward-dial
port 4/0/8
dial-peer voice 233 pots
destination-pattern 233
information-type video
port 4/0/8
forward-digits all
Good that you foudn the answer, in fact it was in my very 1st message in this thread:
Now, how do you test this connection? How did you made the cable ?
Can you include debug output of "term mon" and "debug isdn q921" and "debug isdn q931" please.
layer 1 shown up, when I shutdown the port then no shutdown, layer 1 is deactived
debug isdn q921, nothing happen
I have one external NT1 device with one U and one S/T interface
i am going to do the test again next week
